Question about GE Washing Machines
The knob on my new GE washer is very hard to pull. What can I do to loosen it ?
    Genius:
  • 1,073 Answers
Replace the timer call 800-386-1215 for factory service it is under warranty if less than a year old
Posted on May 20, 2008
The knob is not working. It just turns without starting the washer. I have to press down hard to get the knob to turn to the cycle I want. Is there a way to fix this? GE Top Loader WHDSR109J
This is a common failure. The teeth on the knob have worn off. If you pull the knob out you will see a small clip that can be pulled off this will release the knob. Usually both pieces of the knob need to be replaced. For diagrams and illustrations enter your model # at www.appliancehelponline.com
Jul 22, 2010 | GE WVSR1060A Top Load Washer
I have an older ge prfile washer & the cycle knob does not work. how do you take it off. i have pulled it & tried to unscrew it but neither works
pull knob out and look behind it. You should see a white plastic clip. You have to pull this out and then knob comes off. When replacing knob, put clip on knob first and then just push knob on to shaft.
Jun 10, 2010 | GE Profile WPRE6100G Top Load Washer
GE Spacemaker Washer/Dryer wont start only washer or only dryer
Did you figure out a solution to this problem? I just bought a brand new Frigidaire and it is doing the exact same thing, except it never worked properly. I thought it was the unit and had HH Greg bring another out but the 2nd one did the same as the first.
Feb 09, 2010 | GE WSM2700W Unitized Spacemaker Washer and...
The timer knob spins freely and I can't start the machine or set the timer.
"Can I replace it with a new knob or do I have to buy a new timer?"
It sounds like the knob is rounded out where it fits on the timer post, or It may just be loose. Pull the knob off and inspect it. If damaged, yes, you can buy another one.
May 04, 2009 | GE WDSR2080D Top Load Washer
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
Ge washing machine pull knob
Replace the knob...The teeth on the back of it have broken.
Dec 01, 2008 | GE WBSR3140DW Top Load Washer
Timer replacement
the knob, actually, unscrews. pull out the knob as if you are starting a wash cycle, and use needle-nose pliers to hold the back, and unscrew. i learned the hard way when i pulled on it like it was one of the other knobs and yanked the post out.
Oct 27, 2008 | GE WSM2700D Top Load Stacked Washer /...
Timer Knob
The clip pulls straight up off the shaft directly behind the knob. You can use a small screwdriver or a pair of needlenose pliers to pull it out. Once the clip is removed the knob will slide off the timer shaft.
Apr 21, 2008 | GE WDSR2080D Top Load Washer
GE washer timer knob
I can not set the timer on my GE washer. The knob just turns with out stopping.
Mar 04, 2008 | GE WDSR2080D Top Load Washer
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
