Digital conversion next year
I was told I will be able to use my current vcr next year with the converter box for my analog tv to pick up a digital signal, but will have to set the converter box to the channel I want to tape before each show.
Is this correct ?
  • Terbor Dec 07, 2008
    From what I am finding out is the conversion channels are numbered like this 2.1, 2.2, 2.3
    Well the VCR does not recognize this. Aparently it only likes channels numbered 1-99.
    If this is true can you guess how many VCRs are going into the trash?
    I for one am not going to drive 50 miles to a recycling facility.
    Yea, go green.
  • 476 Answers
This is correct.
The convertor box is used to tune into the digital channels.
Posted on May 21, 2008
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
I have a Sylvanis VCR/DVDcombo and a Standard TV.
The converter box receives hte digital signals and converts them into either channel 3 or 4, or into direct video (red,white,yel). The output of the converter box must go into the VCR input for recording to work. Before the conversion, the tuner of hte VCR would receive the RF signal the same as the TV. The tuner inside the VCR is an analog tuner not digital, so it needs the conversion too. Most converters will provide both the A/V signal (R/Wh/Y) and RF (coax connector).
Hope this helps,
Dan
Sep 30, 2009 | Sylvania 6720FDG 20" TV/VCR/DVD
Ambiuous Information out there
I kind of think the people that wrote the manuals didn't bother hooking up a unit. Here is some help.
The converter box is nothing more then a tv tuner that picks up a digital signal and converts it into analog so your tv can view it.
The vcr, to record programs has to be set to channel 3 or 4 (whatever the converter box is broadcasting on) to record. The converter for the vcr will have to set to whatever channel you want to record from every time you use the vcr and left on as this is the only was the vcr can pick up a signal. Make sure the power saver on the converter box is set to off.
If your tv converter box has digital pass through, all you have to do is turn the tv converter box off and it your tv should pick up the singal from your vcr when you play tapes. You also use this method to access the menu on the vcr.
Jun 04, 2009 | Insignia Digital-to-Analog Converter for...
Is it digital? will I need a converter box?
The conversion to digital affects off air reception. Since you have Comcast analog cable, you will not be affected until Comcast decides to discontinue analog cable, which is not likely any time soon.
When that day comes, your old VCR will probably grace a landfill anyhow, and you will need a converter box from Comcast.
May 13, 2009 | Mitsubishi HS-U446 VCR
Wish to record on analog VCR and not affect digital TV reception
I don't think it will affect the digital TV reception, but if you try to use the VCR built-in tuner it is still analog and you won't be able to record digital channels that way. If your digital TV converter has video-out and audio-out connectors, then you can connect those to the corresponding connectors on your VCR to record.
Dec 28, 2008 | Insignia Digital-to-Analog Converter for...
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Converter box
the digital box has to hooked up the rca plugs on the bac of the vcr if you want to use the vcr (you will only be able to pick up channels throught input and the box will have be set on the channel you want to record. You need a switch to hook the vcr and dvd player both up. the atenna cord can be attached to the back of the convertor box then attached to the tv.
Jun 15, 2008 | Insignia Digital-to-Analog Converter for...
HITACHI ULTRASCAN 53FDX01B TV- do I need analog to digital conversion box ?
you do not have a digital tuner if that is what you mean. if you have a cable box you do not need to worry about this stuff but if you want to pick up over the air signals sometime next year you will need some type of hd to sd converter
Mar 19, 2008 | Televison & Video
Philips CCB130AT02 TV/VCR combo
Is this an Analog TV? Does it have a picture tube and not an LCD or plasma screen? Most likely this is a Analog TV.
If it is an Analog TV (and I would bet that it is), then no, it does not have a digital (QAM) tuner to pick up DTV broadcasts. The fact that it has a VCR also indicates that its an Analog TV.
If you are picking up your TV signals from an outside antenna and not cable, then yes, you will need a converter box to convert the new digital signals to Analog so that you can continue to use your TV set.
If you are using cable to receive your channels, the cable company already provides the conversion for you and your TV will continue to work as before.
The government is giving out coupons to help consumers defray the costs of purchaing a converter box. The following sites are good places to obtain more information.
www.ntia.doc.gov/dtvcoupon
www.DTVanswers.com
- Jim
Feb 06, 2008 | Televison & Video
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
