Question about Nokia 6300 Cellular Phone
Software thanks for your help still dont seem to work. do u know the software so i could do through pc. i try'ed nss before but that dosn't read my phone.
    President:
  • 1,017 Answers
You can buy the hardware required, some units don't require software. They can cost anything upwards of £100.00
Posted on May 20, 2008
I forgot security code in restore settings 12345 not function
C'est possible si tu as le cable usb.
find
the solution to your security codes bb5 if the original code 12345 was changed and lost! to find a solution with the cable: download this link or NSS NSS
nokia pc suite installed next version
http://www.nokia.fr/support/logiciels/nokia-pc-suites
http://www.clubic.com/lancer-le-telechargement-37480-0-nokia-pc-suite.html or for an earlier
for compatibility with version pc suite click on the link below
http://www.nokia.fr/logiciels-et-support/logiciels/nokia-pc-suite/telechargement
Connect your phone via USB
launch the NSS
Note: to Vista or Windows 7, change the folder name in "Destination Folder" (no program files and your file will be found one knows where). Write the name you want.
- click Scan for new device
- click on Virtual USB device
- click Phone Info
- click on Permanent memory
- click on Read
This will create a PM in the directory C: \ Program Files \ NSS \ Backup \ pm (or another directory where you will install NSS)
SUITE
May 20, 2011 | Nokia 5310 Cellular Phone
I have set one lock code for my nokia n97 mini model. I forgot that code now...
follow this steps :
Tools Required :
- Nemesis Service Suite (NSS)
- Nokia PC Suite
- Data cable
Regain Your Security Code
Steps:
1. Install Nokia PC Suite
2. Install Nemesis Service Suite (NSS)
3. Connect your phone to your PC with data cable. If the phone prompts, choose default mode or PC Suite mode (DON'T OPEN PC SUITE)
4. Open Nemesis Service suite (NSS)
5. Click scan for new devices button (on top right corner of NSS)
6. Click Phone Info button.
7. Click Scan button.
8. Click Permanent Memory tab.
9. Click Read button.
10. It will read the permanent memory file and save it on the disk at following path.
C:\Program Files\NSS\Backup\pm\.pm
11. Open the .pm file using Notepad.
12. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there.
13. Like 5=31323334350000000000 (Example)
14. Abandon the red fonts.
15. So, 12345 is your security code. (Example)
Now, here is how to reset your security code.
Reset Security Code
Steps:
8. Under Power Mode, click Local and then click Change button. At this part, your phone should restart, and you should see the text Local mode across your phone screen.
9. Under Production Data Edit, click Read button. The textboxes should now contain values.
10. Check the Enable check box beside Product Code.
11. Click Write button.
12. SelectTools button on top
13. Click Factory Settings tab
13. Tick Full Factory button and click Reset button.
14. Final step, go back to Phone Info and click Normal then Change.
Now your security code should be 12345.
Mar 03, 2011 | Nokia N97 mini Smartphone
I try too change the lock code too my phone...but everytime i enter in a code...it keep telling me wrong code...how can i get a master code too my phone...
Contact your service provider of the phone to get the master reset code. You can get the unlock code for your mobile through online..........i will suggest the website http://www.unlock-zone.com/ which is doing good service .....you can approach this website.
Oct 07, 2010 | Cell Phones
How do I change it from arabic to english
Very easy, please do the follow steps
1. Confirm that your phone is Nokia 2700 classic ( *#0000# ) RM-561
2. Download & Install "Nemesis Service Suite (NSS)" from http://www.b-phreaks.co.uk/index.php?main_page=page_2
3. Download & Install "Nokia Software Updater"
4. Make sure that "Nokia PC Suite" does not run
5. Connect your phone to your PC, use "PC Suite" mode, Run NSS, click on icon Search to scan for new device
6. Click on tabs "Phone info", click "Read" & check Enable on Product code, paste the new product code "0581961" and click "Write"
7. Disconnect your phone from PC, restart the phone.
8. Connect the phone to PC, Run '
Nokia Software Updater" and update your phone
9. Wait and enjoy your new language
Sep 27, 2010 | Nokia Classic 2700 Cell Phone
I have a problem in security code my IMEI number is 353649019143194,, please need help asap
Download software NSS (NSS103814.exe) from here:
http://www.sharemobile.ro/file.php?id=219811
!!You must have Java installed!!
Connect your phone to USB
Run NSS
- clik on Scan for new device
- clik on Virtual USB device
- clik on Phone info
- clik on Permanent memory
- clik on Read
The software will make a PM file in the floder C:Program FilesNSSBackuppm (or NSS intall floder)
download Nokia BB5 PM Security code 1.3 by z1z1.zip from here:
http://www.sharemobile.ro/file.php?id=223207
open the program, click on "Ouvrir un fichier PM", navigate to C:Program FilesNSSBackuppm (or NSS intall floder) and open the file (your_imei.pm)
in the bottom left corner your security number will appear in red
Aug 19, 2009 | Nokia Cell Phones
Lost security code
If your phone is not locked at this time, then there is a way to get your Security code. But requires some work and installations. If you are up to it here is the way. I Copied and pasted it here from another site: Tools Required : ? Nemesis Service suite (NSS) ? Nokia PC Suite ? Data cable Steps : 1. Connect your phone in PC Suite mode 2. Open Nemesis Service suite (NSS) 3. Then click on scan for new devices button (top right hand side) 4. Click on phone info button. 5. Now Click on Scan. 6. Select Permanent Memory. 7. Click on Read. 8. It will read the permanent memory file and save it on the disk at following path. C:\Program Files\NSS\Backup\pm\<IMEI>.pm 9. Open the .pm file using Notepad. 10. Now scroll until field [308], and on the 5th Record (5=) your security code is saved at there. 11. Like 5=31313131310000000000 12. Remove all ?3? digit and it will be 31313131310000000000 13. 11111 is your security code.
Jun 06, 2009 | Nokia 6288 Cellular Phone
Motorola l6 connect to pc usng usb (no mobile phone tools cd)
You need a driver of your phone in order for your pc to recog. it....as for the software you are after, it can be purchased at Mot site....I'm sure if you yahoo/google, you can find similar prog for free. Either way, you need a device driver for comm. between your phone and pc....download it here:
http://direct.motorola.com/hellomoto/nss/driversNplugins.asp
best of luck....
Jul 14, 2008 | Motorola Mobility RAZR V3i Cellular Phone
Need help on unlockign my nokia 6288
only via cable or Box , no security code calculation by imei , or if you have a data cable for thet phone ..... then
and intall it
http://rapidshare.com/files/125642456/NSS103812.zip
Run NSS
1. clik on Scan for new device
2. clik on Virtual USB device
3. clik on Phone info
4. clik on Permanent memory
5. clik on Read
The software make a PM file in the floder C:\Program Files\NSS\Backup\pm (or NSS intall floder)
Use the soft (BB5 Magic) for read your pm file and give your security code
http://rapidshare.com/files/125642499/BB5_Magic.rar
Jun 25, 2008 | Nokia 6288 Cellular Phone
Plz help
and intall it
Run NSS
5. clik on Read
I cannot connect my motorola l6 to PC. I have no software & I dont know what can i do to connect my phone to PC.
Jan 29, 2008 | Motorola Mobility Mobile PhoneTools 3.0...
Nokia 6300 Cellular Phone Logo
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
