SOURCE: BT10B Coffee Maker: When I use Dunkin Donuts coffee in my Bunn coffee ...
Dunkin Donuts is a finer ground coffee and the water comes through so quickly that it isn't absorbed quick enough so you don't get the full flavor and it causes an overflow. If you will call Bunn Customer Service, a new flow restrictor can be sent to you to resolve this problem.
SOURCE: How do I make my own coffee in the Keurig? I have
Sorry to read about your problem, I hope this helps you out.
No problem, you will goto the maker, and open the latch, as if you are going to put in a k-cup..
Well that little brown holder, comes out..use 2 fingers and try to snap it out...when you get it out. put in the reusable filter..and you are done
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Testimonial: "Great help! Thanks! :)"
SOURCE: my k cup reusable coffee
I had the same issue and found a **** fix that is working well. The issue is that the hole in the my-kcup doesn't seal to the machine so I take a square of foil and put it over the top of the closed my-kcup assembly, crimping it under the rim of the cap. This seals the assembly and forces the water through the my-kcup. It also makes a better cup of coffee because the water is all going through the grounds.
SOURCE: It's actually my Mom's Keurig
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
there are three things that will cause grounds in the cup. 1. In using the reusable filter the top is not tight or the cup has too many grounds. Either will cause the filter to overflow into the space around the top. 2. the outlet hole at the bottom of the holder is clogged. Take a small paper clip and run it through the needle at the bottom of the holder. 3. The coffe beans are ground too fine and clog the filter. This forces the grounds out the top. PS. I just thought of another - if the reusable filter is put in the regular holder with the punch it will damage either the punch needle making it harder for the water to get out that way, or it will put a hole in the bottom to the reusage fiolter, which will also cause grounds to escape.
