Hitachi 61udx10b changed stk392-110 with stk392-150 went to do manual dcam. now no pic no power button on tv. red light in back dp06 3green lights on in tv.
  • 8,617 Answers
Check the resistors near the Ics especially the 3.9 ohm 1 watt resistors often one or two will be open then when you install the higher wattage Ics which run cooler you can actually wipe out all the convergence resistors which are 3.9 2.7 and 4.7 ohm 1 watt resistors
Posted on May 20, 2008
Hitachi 43fwx20b Convergence Problems
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Another common problem is dull or washed out video.
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 25, 2010 | Hitachi 43FWX20B 43" Rear Projection...
Magic Focus broken
Use sanyo ICs, also I think you have the wrong number for your tv. The best thing now would be to have a tech. repair the tv since it seems to be more than you can handle, you probably damaged the digital convergence board and if you continue to mess with it, will cause irreparable damage to it.( sorry but I will not be able to respond to any further questions)
Jan 04, 2010 | Hitachi 53UWX10B 53" Rear Projection...
Hitachi 61udx10b
Replace Both of your STK ICs they are your convergence ics they are big black ICs will have Part# on them for example STK392-110, if they are 110s use 180s, if 020s use 040s other wise replace with exact same number. To get Parts call Electronix 1-800-223-3205
Dec 30, 2008 | Hitachi 61SDX01B 61" Rear Projection...
Hitachi 61UDX10B
I would check for burnt resistors as the 150s are interchangeable with the 110s however in alot of hitachis I have seen resistors blow after upgradeing to the higher wattage ICs. I Usually switch out the convergence resistors whenever I go to a higher wattage IC just to be sure. If you need more help let me know.
May 18, 2008 | Hitachi 61UWX10B 61" Rear Projection...
Reset Magic Focus
i think your problem might be Convergence amp ic bad
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
http://www.hdtvoice.com/voice/showthread.php?t=28929
Feb 01, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Power button Flashes
the flashing light often shows malfunction ,check the wire connection of your devices something must be wrong .the surge protector you have is for overpower or low voltage too?Ask your neigbours if they have shame problems
Nov 18, 2007 | Hitachi 46F510 46" Projection HDTV
My 50" hitachi ultravision won't turn on
i got a 62VS69A model type hitachi tv.... and it was thunderin and lightning outside all day .... and i left it on ... and when i woke up ... it was off..... and when i went to turn it back on.... it blinks blue,, then the light below it blinks red.... and the light below that light blinks red .... and then the first blue one again ... and over and over again ... untill finally it juss stays red... i donno whats goin on with this tv... im assumin it was the bad weather outside that did it but im not sure..... can someone PLEASE help a brother out ? lol
Nov 16, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Bad Convergence circuit , replace 2 STK392-110 & fuse will take care the problem
Jul 18, 2007 | Hitachi 43FDX15B 43" Rear Projection...
Televison & Video Logo
99 people viewed this question
Top Televison & Video Experts
Electro Med Services...
