Question about Linksys Wireless-G Broadband Router
Cannot change ip address
I have wrt54g and cannot change the ip on my laptop...computer
plz help
  • 298 Answers
What is the Operating system of your computer?
And what is the IP address that it is currently getting?
Posted on May 20, 2008
How do I change the IP address on my laptop?
Simply you can change it by follow the steps below..
Do this:
go to start > run type "cmd" hit enter
in the black box type "ipconfig/all"
record all information
get out of that
go to Control Panel > (classic view) Network Connections > go to your connection and right-click, Properties, TCP/IP settings then Use the following IP address and enter all that info. Except for IP address, change the last part to 254. If it already is 254, then pick any random number below 254.
You can also go in and Repair the connection. Click on the connection, go to the Support tab and click Repair. This will reset the IP but will not necessarily give it a different number.
Finally you can check your ip address at Ip-Details.com
Jan 20, 2011 | Linksys Wireless-G WRT54G Router
I am not able to connect to the internet using my Linksys WRT54G V8. When I connect the cable directly to my laptop, I am able to access the internet, so it is definitely a problem with the wireless...
Title: Setting-Up a Wired Computer to Obtain an IP Address Automatically Article ID: 4033
Configuring a wired computer to get an IP address automatically will enable it to get an IP address from a DHCP server. Instead of manually entering the IP settings which will consume much time, performing this procedure will ensure that the computer will get the correct TCP/IP settings.
Configuring a computer to get an IP address automatically is useful when:
  • Connecting a computer to a network with a DHCP server. Ensuring that the computer is getting the correct TCP/IP settings.
To configure a computer to automatically get an IP address, you have to check the TCP/IP properties of the Ethernet Adapter installed on the computer. Follow the steps below for instructions.
NOTE: Make sure the wired computer is properly connected to a network with a DHCP server.
Checking if the Computer is Set to DHCP
NOTE: The instructions provided below only apply to Windows 98, ME, XP and Mac operating systems. If you are using Windows Vista, click here for instructions. For Windows 7 users, click here for instructions.
Windows 2000/XP
Windows 98/ME
Mac OS
Sep 29, 2010 | Linksys Wireless-G WRT54G Router
Im tryig to piggyback my wrt54g router to another part of the house. I have a cable coming from my linksys e1000 n router which is my main router. When i plug the cable into the 54g i can access the router...
What is the IP address of the E1000 router ?
If the IP address of E1000 router is 192.168.1.1, Then change the IP address of WRT54G router to 192.168.1.2. Connect the Ethernet cable from the Ethernet port of E1000 router to the Ethernet port of WRT54G router ( port 1 of E1000 to port 1 of WRT54g). Disable the DHCP server.
You can do it in a different way also.
If the IP address of E1000 is 192.168.1.1. then change the IP address of the WRT54g to 192.168.2.1. Do not disable the DHCP server of the WRT54G. Connect the E1000 to the Internet port of WRT54G.
Click Here to know more about router and network
Sep 03, 2010 | Linksys Wireless-G WRT54G Router
How to obtain my password and add another laptop to wrt54G
To access the router's web-based setup page using Mac, click here. Step 1:
Open a web browser such as Internet Explorer.
Step 2:
Go to the Address bar and enter your router's IP address ("192.168.1.1" is the default IP of most Linksys routers) then press [Enter].
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank then enter your router's password ("admin" is the default password), then click OK.
If you forgot the router's password you need to reset the router. For instructions, click here.
NOTE : For WRP400, the default IP address would be "192.168.15.1" and if you place the router behind a primary router with the IP address of "192.168.15.1", then the router will automatically assume a new default IP address, "192.168.16.1".
The router's IP address can be changed by:
1. Running the router's setup CD.
2. Changing it on the router's web-based setup page.
If you forgot the router's IP address you can:
1. Check the router's IP address. For instructions, click here.
2. Press the Reset button at the back of the router for 30 seconds.
Aug 23, 2010 | Linksys Wireless-G WRT54G Router
Wireless-G WRT54G Router: how can i fine my ip address...
To check for the local ip address of your computer:
Go to Start -> run. Type cmd. In the command prompt, type ipconfig.
To check the Internet IP address of your computer:
Go to an internet browser, in the address bar type whatismyip.com.
I hope this helps!
May 15, 2010 | Linksys Wireless-G WRT54G Router
I took my laptop to London Drugs for a photography course and I couldn't log in to their network so they computer guy changed a bunch of stuff and voila, I was in. Now that I am home, I can't get the...
sverigin
Most likely what he did was manually set the IP address on your laptop so it would connect to their network.
With most home networks they are set to obtain IP addresses automatically. The links below will help you configure it back to obtain IP addresses automatically.
How to check and change you computer IP address in Windows XP
How to check and change you computer IP address in Windows 7
Let me know if you have any more problems or questions.
Issken
http://www.fixya.com/users/issken
May 01, 2010 | Linksys Wireless-G WRT54G Router
2 Pc's with same IP
AT either desktop or laptop:
[Start]
[Run]
[cmd]
A dark "DOS" windows will appear
At the prompt, type: ipconfig
press [ENTER]
Note the "IP Address" (probably 192.168.1.2)
type: ipconfig /renew
press [ENTER]
Note the IP Address
If it has changed, then you are ok. Type: exit and press [ENTER]
If it did not change, then try this on the other computer.
If that didn't change either, the go to the Control Panel
[Network Settings]
Find the wireless or wired network adapter and Right-Click
Choose "Prpoerties"
In the Properties window, double-click "IP Address"
See the IP Address assigned? change the last digit by one number.
Example: if the IP Address is 192.168.1.2 then change to 192.168.1.3
[OK] [OK][OK]
It should work now...
Let us know!
Sep 17, 2009 | Linksys Wireless-G WRT54G Router
Linksys WRT54G can't connect 3rd wireless computer
log into the WRT54G wireless router and ensure that you do not have it set up for only handing out 4 IP addresses also check the laptop to see if it is set to have a DHCP or static IP address, if it has a static IP and your network is dynamic then this is why it wont connect.
if this resolves your issue and you are happy with the answer please grade me accordingly.
thanks
Aug 25, 2009 | Linksys Wireless-G WRT54GS Router...
Having problems with linksys connection
Please check if the router needed IP address?
- if yes? ( goto Network Settings and add the IP address.
- if not? ( obtained you Network Settings do not input IP address.
Double check also if your Router is properly configured?
Sep 21, 2008 | Linksys Wireless-G WRT54G Router
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Linksys Wireless-G Broadband Router Logo
35 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
