Question about Indesit Washing Machines
Indesit widl102 washer dryer fault
After choosing wash cycle(any cycle) the pump starts then starts filling with water. However the pump keeps emptying and then the red light and the easy iron light start flashing simultaneously.
its done this a number of times but i have left it for a few days then put it on and its been ok.
SOURCE: Indesit WIL143S flashing lights
hi have you unplugged your washing machine for 2 mins then plugged it back in to give the machine a reset..its says it in my WIL 163 MANUAL TO DO IT was wondering if your is the same gl
Posted on Jan 20, 2008
ngfam1
  • 639 Answers
SOURCE: got an indesit wi 133
Dear jwarbonnet,
ngfam at you service!
TRY UNPLUGING IT AND THEN REBOOT IT .IF THIS WORKS THEN YOU ARE SAFE!
OTHERWISE
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Posted on Aug 26, 2008
barkencoa
  • 3463 Answers
SOURCE: indesit washing machine wixe127 has f04 faultcode
Error code F04 indicates pressure switch jammed on empty.
to rectify, do the following
Remove lower rear panel of washer.
Remove large black hose on drum
Remove and clean filter inside hose.
Remove hose onto pump and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Posted on Jan 25, 2010
  • 3 Answers
SOURCE: Hi, we have an Indesit WIXL 143(UK)washing
This probably happens after the main wash has completed and it is just finishing the first rinse. It seems to be a warning that there is a partial blockage on the waste outflow. Empty the wash and use the DRAIN program to get as much water out as possible. From the FRONT of the machine open the lower flap and and then put a large towel on the floor. Unscrew the big black filter cover slowly - some water will come out -about a cupful. Ensuring the machine is turned off, use a cloth to remove any obvious build up of "gunk". Would suggest using an old toothbrush to clean off the surface and the plug.
99% of the time - Job Done!
You may have a blockage in your waste pipe. (If using an extension check any coupling has not "bunged up".
Last, check your waste pipe / grey water connection. Again, this "should" be fine, but it may be bunged up, especially if it feeds into the sink outflow.
Stick back together, plug in and use the 11, fast wash option in cold. Should now be happy, and you should hear water gurgling away noisily down the waste.
Always worth doing a 2 - 90 extra hot wash once in a while even EMPTY of washing just to "flush the system" now and again.
Hope this helps and saves you a £104 service engineer call from indesit :)
Posted on Mar 10, 2010
  • 353 Answers
SOURCE: How do I remove the filter from an Indesit WIDL102
you may have to just pull it out after giving it a turn it could be stuck
Posted on Mar 20, 2010
Will not start cycles
is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Jul 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
WIDL102 indesit washer dryer not working properly
check heater element/ should read about 32ohmns on multimeter if not reading replace,if ok replace stat
Apr 03, 2010 | Indesit W 123 Front Load Washer
Ive got a Indesit WIDL102 washer dryer and it will wash but will not dry any longer. It goes through the cycle but the clothes come out wet. Any suggestions???
This problem is normally caused by either the thermostats not working properly or the heating element is the problem.
Both are normally located in the air tube of the dryer down stream of the blower.
Sep 25, 2009 | Dryers
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Indesit WIDL 102
almost certainly a new module and eprom. these modules have given a lot of problems.
not really worth doing
Jun 25, 2008 | Indesit W 123 Front Load Washer
My Indeset widl102 washer dryer
sounds like a faulty water valve if not pcb or pressure switch sorry cannot be more precise but thats indesit for you regards jason
Jun 12, 2008 | Indesit W 123 Front Load Washer
Not Spinning or Draining !
Hey there
well from what I can understand here you need to check first 2 things
1) Check that the hose that is connected to the machine is empty and that there's nothing blocking the water.
2) another possiblity is that your Pump isn't working.
saince i don't knwo the model I can't tell what kind of pump you have, if you have direct pump is should be abouve the motor, it' pretty easy to inspect it and look at it, it may be blocked from all kind of junk (coins.....) another option is that the pump blades are worn out so it's not pumping ( i don't think its your case since your washer is prettry new)
Hope this helps
Bono
Mar 24, 2008 | Washing Machines
Indesit washer dryer
check heater element first, thats a common fault on these machines, loose connection or open circuit, after that check the pump for same open circuit
the rotating of the timer knob indicates a fault, maybe even a setting fault, to try and reset set to off, turn off and back on again, till light flashes, then turn off again and start again
if you do not know how to test for open circuit then the job is not for you, sorry
Oct 14, 2007 | Indesit W 123 Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
