Question about Toshiba 42HP83 42 in. HD-Ready Plasma Television
Picture..... rarely used, not that it matters. tv lost red; then went black and white; then lost picture. wasn't sure if it was related to hd dish network box or not. then realized dvd was fine; full color. so, i watched some dvd's. then went black and white; lost picture. am i screwed???? am heavily disappointed that tv may be dead after 2-3 years max; and rarely watched....... if screwed, obviously plasma is not a good choice. can you recommend technology to go with? thanks.
  • Anonymous Aug 11, 2008
    plasma tv picture went black and white
  • Anonymous Mar 15, 2014
    I was watching TV and the picture lost all of it's color
    Sergeant:
  • 300 Answers
I'd still go with plasma it has true black where LCD does not and cheats you out of bits.
much better for gamming.
can you say WARRENTY :->
Posted on Sep 12, 2008
I'd still pick plasma , because it has true black where LCD does not.
better for gamming by a long shot.
Sd dish reciever not recognized by hdtv tuner
Hey dgrines81!
I would need more information to provide an accurate solution including what model of receiver, but it sounds like you have an SD receiver hooked up to a HD TV.
Our SD receivers can show picture on an HD TV, they just need the correct cable. If your TV has the spot, I would recommend using RCA (Red, Yellow, White) cables. Plug those in to the receiver and the TV and then change the input. If the problem continues feel free to reach me here, or at thomas.faust@dish.com.
Tommy Faust
DISH Social Media Representative
Feb 12, 2012 | DISH Network 311 DTV Receiver
How do I connect my LG TV to my dish network
Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
Dec 31, 2011 | LG 42PG20 42 in. Plasma HDTV
Today, while watching tv on the Dish, tv suddenly started powercycling. I unplugged it, waited, and then tried a DVD -- worked fine. Tried Dish again, power cycled again -- on off on off, 1/2 second of...
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities.
Daniel Busa
DISH Network
Customer Service
May 16, 2011 | LG 47LD520 47 in. HD-Ready LCD TV
Installed a new set top box last night and all the channels are black and white - no colour at all - confused!!
vron63
Check your cables between the receiver and your TV to make sure the colors match. If you are using a component cable (green, blue, red, white, red), not matching colors at both ends will give you what appears to be a black and white picture. I hope this helps.
Ray Calo
DISH Network
Mar 09, 2011 | Televison & Video
My Samsung DLP HD 46" TV just went Black &
Defective Color Wheel- Encompass parts Distribution 1-800-638-3328
Mar 06, 2011 | Samsung HLP4674W 46" Rear Projection HDTV
Black and white viewing
It's probably the new technology.Do you have a cable box or basic cable with a straight wire?If you have a box it should work.Sounds like you don't though.The cheapest fix would be a digital converter box.If you buy one and don't like the results,make sure you buy it at a place where they will accept the return.A dish digital box should work though.Do you have just a wire from the dish?It seems like a dish requires some sort of converter.How long have you had this problem?If you had a picture when they first went to digital,it would be the TV.That's all i can say.
Jul 27, 2010 | Philips 60PP9601 60 in. Rear Projection...
Picture settings
Colorimetre HCFR software
AVC HD 709 calibration disk
Spyder2 colorimeter (I know most prefer the Eye-One meters, but the Spyder2 was available from my job at no cost)
Here are the settings:
PS3 Blu-Ray player
Output Format (HDMI): Y Pb/Cb Pr/Cr (important!!! NOT RGB output)
BD 1080p 24hz Output (HDMI): On (this TV can reproduce video at 48hz for accurate 2:2 pulldown)
Y Pb/Cb Pr/Cr Super White (HDMI): On (not sure if this matters)
42LG50 Settings
Aspect Ratio: Set By Program (Personal Preference)
Picture Mode: Expert 1
Backlight: 50 (Personal Preference)
Contrast: 54
Brightness: 54
Sharpness: 40 (Personal Preference)
Color: 50
Tint: 0
Fresh Contrast: Off
Noise Reduction: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 10 Point IRE
10 (-3,8,-16)
20 (15,24,-21)
30 (20,36,-22)
40 (3,19,-40)
50 (8,34,-41)
60 (10,50,-20)
70 (-5,50,-8)
80 (-16,50,18
90 (-14,50,30)
100 (-22,38,21)
Red Color: -3
Red Tint: 0
Green Color: 10
Green Tint: 0
Blue Color: 14
Blue Tint: 0
Yellow Color: 0
Yellow Tint: 1
Cyan Color: -11
Cyan Tint: 0
Magenta Color: 0
Magenta Tint: -2
Take time to get used to the settings, you may think the screen looks dull at first. The truth is most people have way too much contrast on their TVs.
These settings will also work for Cable or Dish hookups, in which case you may change the Noise Reduction option to Medium to reduce signal noise.
OR....
2POINT IRE
Backlight: 65
Contrast: 55
Brightness: 45
Sharpness: 50
Color: 45
Tint: 0
Fresh Contrast: Off
Gamma: Medium
Black Level: Low
Real Cinema: On
White Balance: Warm
Method: 2 Point
Red Color: 3
Red Tint: 0
Green Color: 9
Green Tint: 2
Blue Color: -1
Blue Tint: 0
Yellow Color: 6
Yellow Tint: 5
Cyan Color: -1
Cyan Tint: 1
Magenta Color: 2
Magenta Tint: -1
Sep 15, 2008 | LG 42LG50 42 in. LCD HDTV
Hooking up Xbox 360 to JVC TV 20 inch 1 year old tv from Luxembourg
change the plug on the back of your xbox 360 from hd to tv unless of course your tv is hd then change it to hd :]
Jan 27, 2008 | JVC TV-20241 20 in. TV/VCR Combo
Lg 32lc2r, only showing picture in black and white
Make sure that the color control level is set to the default or 50% to start with. This should be in the Video menu.
The colour for the tuner and for the encoded base-band video uses a circuit area called the colour demodulator. It is possible that this cirucuit area has failed and needs servicing.
Jerry G.
Jan 08, 2008 | LG 32LC2R 32 in. HD-Ready LCD Television
Quasar SP-3233 TV
well it's not a wide screen tv show it won't really matter but if it is H/D you will find a red/green/blue connection in the back for picture and red/white for sound
Aug 10, 2007 | Quasar SP-3233 TV
Toshiba 42HP83 42 in. HD-Ready Plasma Television Logo
194 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
