Question about HP Pavilion dv1000 Notebook
Intermittently switching off
Hi Guys
I have a HP dv1000, it boots into windows then after a few minutes or sometimes seconds it switches off. I then have to remove my Adapter plug it in again and then it will start up again. My batt doesnt work.
    Champion:
  • 207 Answers
Is it doing tht thing continously???
chk it in bios or safe mode if it is doing bios also
then the computer will go for repair
if not perform recovery
and do check there should not be device sply phone connected to it
Posted on May 20, 2008
Panasonic Ag-DV1000 mini DV deck shuts down after inserting tape
When there's a problem with the drive mechanism of a VCR it will shut down to prevent damage. All operations of a VCR are controlled by a computer chip. This is told what mode the mechanism is in by a Mode Switch. If this is faulty it can cause the machine to play up. Sometimes a spray of Video 40 on the mode switch can restore operation. However it will not correct the problem if the mechanism has any damage on it.
Feb 25, 2014 | Panasonic AG-DV1000 Mini DV VCR
Hp pavilion dv1000: When I turn it on, it does not boot up and I get a blank screen. I have tried hard reset by taking out the battery and holding the power button for 30 seconds, and then turning it back...
I just want to know if you see any power indicator on the machine? If you see any power indicator try to check if you hear any sound that it boots up to windows or try to check if there are any beeping sounds when you turn on the machine. If you hear the windows boot up sound try to use external monitor and see if the machine gives any display. If you hear consecutive beeping sound it means there are hardware that's faulty inside the machine.
Apr 03, 2011 | HP Pavilion dv1000 Notebook
When i start it doesn't start sometimes. sometimes it starts but after a few secs a noise comes and system switches off
There's a similar problem with the DV6000 that is caused by the built in graphics card overheating and telling the computer bios to turn it off and stop it overheating the whole motherboard. unfortunately once this has happened the system can stop the laptop booting even from cold. I've temporarily fixed a couple of them by removing the CMOS battery for 24 hours and puttin a shim between the graphics card and the heat sink. In the end you're probably need a new motherboard though
Jan 16, 2011 | HP Pavilion dv1000 Notebook
Laptop lid actuator switch is loose
This is common problem. To get to that you'll have to take everything apart including motherboard. It's part of the top case. You'll have to bend it up for it to work or completely disable it permanently.
Apr 13, 2009 | HP Pavilion dv1000 Notebook
Web cam freezes while watching a site on bald eagles nesting
I think you may have the wrong web-cam drivers - i reccomed uninstalling al web-cam divers and using drivermax to download the correct ones:
its free, easy to use and really GREAT.
Hope i could help
CBZ
Comment if you need more assistance
Mar 28, 2009 | HP Pavilion dv1000 Notebook
HP dv1000 will not boot, no power. Is this a hard
No Power at all sounds like the Internal DC Power Jack that is soldered onto the motherboard is bad. Send it to these guys www.generalsystemsconsulting.com
Mar 08, 2009 | HP Pavilion dv1000 Notebook
Hp DV1000 backlight flickers on then off on button press
If you go to this site you can get step by step instructions. The lamps and inverter aren't really that hard to replace if you can follow directions and have patience. Good Luck, hope this helps.
Jan 17, 2009 | HP Pavilion dv1000 Notebook
Screen problem Hp dv1000
The main two causes for this, are the inverter, which supplies the screen with the proper amount of power in order to function correctly, or the screen. If the inverter isn't puting out enough power it will cause the screen to darken or black out completely. Start by checking the screen connections. If all the connection are properly seated, the it's either the inverter or the screen it self.
Jun 20, 2008 | HP Pavilion dv1000 Notebook
Screen goes dim intermittently
By defult this is a power saving option. click on yr batt on toolbar to see more options
Dec 05, 2007 | HP Pavilion dv1000 Notebook
HP Pavilion dv1000 Notebook Logo
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
