Question about Dell Computers & Internet
Battery will not charge
Battery replaced and it still will not charge. System works fine on the AC adapter.
  • beachfellow May 21, 2008
    Dell Laptop (Inspiron E1505).Contacts cleaned, but NO lights on battery. Is there a manual that shows how to open it without destroying anything?
  • Glenn Rogers
    Glenn Rogers May 11, 2010
    Is this a laptop? Yes? Have you cleaned the contacts off with a pencil eraser? Are the charging lights blinking, but the laptop won't run on the battery?
    Worldvet
    Guru:
  • 859 Answers
Beachfellow,
Don't try to open the battery. If you are still under warranty seek support from Dell. Opening up your Laptop will kill any warranty your have.
If you have a bad charging circuit you should seek out an authorized Dell repair shop for the work.
If you are a qualified Electronics Technician and can troubleshoot digital circuit and realize what you will be doing to the potential of your machine to ever charge a battery again, then be aware of the challenge and the pitfalls. Only then, give it a go, and I wouldn't suggest anything higher than a 10watt soldering iron and use every static precaution in the book including groiunding youir soldering iron if it isn't a three prong plug as many are not.
Regards,
Worldvet
Posted on May 21, 2008
    Problem Solver:
  • 8 Answers
What kind of dell model? it could be badcapacitors on the mobo. it's. common. have seen and fixed it numerous times. crank that puppy open and bust out the multi meter and get to testing. after that a 25- 30 watt soldering iron will be ur best friend
3 Suggested Answers
  • 22 Answers
SOURCE: DELL note book Model 5150 no power using AC adapter
you can buy a new ac jack on ebay.
ac/dc jack
Posted on Dec 26, 2008
  • 184 Answers
SOURCE: Hp nx6320 does not power on with ac adapter,no power indicator or battery charging indicator.I tried with 2 differnt batteries which work well with other laptop
According to your description, there is a big chance that you charger need to be replaced.http://www.chargerbuy.com/replacement-hp-compaq-nx6320-smart-ac-185v-35a.html
Posted on Feb 13, 2012
Compaq nx6125 is not charging even though the adapter is working fine and the battery is fine too
Firstly, try the following steps to check the problem:
Turn off laptop.
Unplug AC power adapter.
Remove battery.
Replace AC power adapter.
Turn on laptop, allow OS to boot.
Once logged in to the machine, perform a normal shut down.
Replace battery.
Turn on laptop, allow OS to boot. The battery should once again be charging as normal.
Oct 25, 2012 | Computers & Internet
Dell latitude e6410 chargin fault ,will run on dc adapter but shows not chargin ,battery not conected
  1. If the motherboard has ever been replaced, check the service tag section of the BIOS. If it is blank, enter the service tag off the bottom of the system. (The charging circuit will not work without it.)
  2. Also in the BIOS see if the AC adapter is identified or is listed as UNKNOWN. If the system cannot ID the adapter as a Dell Branded AC adapter 90w or larger, then the charger is again disabled. If unknown, check the barrel end of the DC jack of the adapter for the fine wire in the center, if broken or bent, then the adapter is not identified.
  3. Try with a different Dell branded 90w or larger D or E series adapter.
if all the above make no difference, and the Adapter is recognized, the battery may be at fault.
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
if the adapter is unknown, replace the adapter, unless it works normally on another system, and the other system's adapter has the same issue, in that case the motherboard is likely the issue.
Note: a 65w Auto/Air adapter will only charge the battery if the system is OFF
Jul 27, 2011 | Dell Latitude E6410 Notebook
Dell PC losing battery very fast
hi
turn off the computer , then remove the battery . reboot system and try rebooting the notebook with the AC adapter only.
this is to ensure the Ac adapter is working fine, and if it is, it should be charging the battery properly when its installed.
now, turn off the system again. re install the battery and try booting it up with the battery only
if the battery hasn't enough charge, then attach the AC adapter. If you have allowed the computer to charge the battery (while the computer is powered off) and it is not charging the battery, then you need to replace the battery definitely.
you can get a new battery (if you are in North America) from www.compluscominc.com
please send me 4 thumbs up
Jun 06, 2011 | Dell Vostro 1500 Notebook
My Acer aspire 4935 is not recognizing the AC adapter. When ever I shutdown the system and connects the AC adapter, it works and the charging LED lights up. Once I press the power button to boot the...
Problem description:The battery charges only when the laptop turned off. The battery charge LED lights up as normal and the battery gets charged to 100% while the laptop is off.
When the laptop is turned on, the battery charge LED goes off even if the adapter is still plugged in.
Possible cause:1. AC power adapter failure.
2. Battery failure.
3. Broken/loose power jack.
4. Motherboard failure.
Possible troubleshooting steps and repair solution:1. This problem could be related to a faulty AC power adapter. It's possible that the AC adapter doesn't provide enough power when plugged into the laptop. To find out if this is your problem, you'll have to test the laptop with another working adapter.Replace the adapter if needed.
http://www.chargerbuy.com/replacement-acer-aspire-9400-ac-adapter-19v-3-42a.html
2. There is a slight chance that you have bad battery. Test the laptop with a know good battery and replace the faulty one if needed.
3. The battery charge problem could be related to the power jack. Maybe the jack is broken or not making good contact with the motherboard. It is necessary to remove the motherboard and take a closer look at the power jack. Resolder or replace the jack if needed.
4. If the power jack is in a good working shape and new power adapter with battery do not fix the problem, most likely you have a faulty motherboard. Replace the motherboard if needed.
Feb 09, 2011 | Acer Aspire 4730-4947 Notebook
Dell Latitute D610 is no longer working under AC Power
Please check the AC adapter with another system and confirm if it is working fine. Else get it replaced.
Thank you for using Fixya
Oct 08, 2009 | Dell Latitude D610 Notebook
Dell inspiron 1300 does not see the battery
remove battery check if laptop works fine with ac adapter, if not then download the latest bios version first if fails then replace ac adapter. If laptop works fine with ac adapter. but cannot work with battery alone, download the latest bios then charge the battery for 6 hrs. if still batt not charging then replace batt. but as you mentioned you already replaced the batt and your still getting the same issue. replace motherboard.
Sep 24, 2009 | Dell Inspiron 1300 Notebook
Hp compaq nx7400 - battery died and power cord will not turn comp
Some laptops will not power up with a completely discharged or faulty battery. Remove the battery from the laptop, plug in the power cord and try to boot the system. If the system boots, your battery needs to be replaced. Replace your battery as soon as you can, it's not a good idea to run the laptop for extended periods with an open battery bay.
May 07, 2009 | HP Compaq Presario V2000 Notebook
Charging problems
Hopefully the battery is just confused and needs to be reset. Drain the battery down until the system shuts off automatically, then take the battery out of the laptop for two minutes and plug it back in, and connect the AC adapter, let it charge without turning the laptop on, then turn it on and hopefully it should work fine again. If not then you may need to buy another battery. Try again with another AC adapter just in case because you don't want to replace your battery (expensive!)
Please rate, thanks!
Mar 31, 2009 | HP Pavilion dv6000z Notebook
Power
You may have to use the battery and the ac adapter at the same time. it could be that your battery is not yet charged that's why its not working.
if you want to know if there's something wrong with one of the components of your system..you can try this...
turn your computer on with just the ac adapter plugged in - if working then try both ac adapter and battery.
if your system will not turn on with just the ac adapter plugged in, it could be there's something wrong with the ac adapter or with the motherboard of the system
Oct 05, 2008 | Toshiba Satellite A65-S1065 Notebook
Charging Led issues
So, in other words, The system works fine with the AC adapter and battery installed. Have you tried a different battery? Ray CompuGuy44
Jun 20, 2007 | Gateway MX7118 Notebook
Computers & Internet Logo
108 people viewed this question
Alun Cox
