Question about Ricoh CL4000DN Laser Printer
Prints a couple of pages - then jams
My Ricoh has been printing with no problems until just about a week or so ago. It will print a few pages and then jam. I have to open the front cover and take out the piece of paper - then it prints a page or two and jams. I have not changed the paper I use - it's Hammermill Copy Plus. It is driving me crazy! Any suggestions out there?
Well, for now it seems to be fixed - I opened up the paper tray and there is a little part that grabs the paper on the front of the tray - kinda sticky - I just took a paper cutter and put a couple of scratches on it and it is grabbing the paper for now. I do have some of those to use for replacements - but I had just changed it about a month ago and don't think it needed to be changed out again - they usually last quite a while. So, we'll see how long this lasts. We do a lot of printing on this thing and it has been a great printer - maybe we are just wearing it out!
Posted on May 22, 2008
Aficio 1027 only print first couple of pages
Could be several things. I would start by eliminating the easiest things. Try another cable, decrease dpi settings (less memory usage), try a USB cable to see if theres a difference if a port is available. Update the print driver from Ricoh website.
Nov 20, 2013 | Ricoh Aficio 1027 All-In-One Laser Printer
Printer ignores white space at beginning of document
by dragging the black bar on the left with your mouse when
the cursor changes for resize
Nov 30, 2007 | Office Equipment & Supplies
Printing blank pages
Try printinf from file tab.
When you get to #of pages, print exact numbers eg 1-5
check if ok
Aug 14, 2013 | Konica Minolta magicolor 4750EN Laser...
Ricoh SP C410 DN jam from bypass
If you can take off the bypass unit, two screws and a harness, you may be able to check the shaft, bushings and rollers. Sometimes removing jammed paper cause parts to get out of normal position. The grinding noise for example, gears not meshing together correctly. If it worked before the jam, then that is where I would look.
Apr 20, 2017 | Ricoh Aficio SP C410DN Laser Printer
I bought the printer a couple of weeks ago and have only printed a maximum of 20 pages. Now when I try to print, the "error" light keeps coming on but I've looked and it doesn't say what the...
Try opening the printer and checking for a paper jam.
It's also worth removing the toner cartridge and placing it back again, therefore forcing the printer to go through the diagnostic cycle again. Sometimes that solves the issue.
Hope that helps!
Mar 14, 2011 | Brother HL 2140 Laser Printer
I have a Brother 5370DWT. I replaced the drum about 5 weeks ago and just yesterday I started having jamming issues. Every couple of pages the printer is jamming. I have to pull a page from the drum and...
I have had the same problem on these machines, try cleaning the paper pickup rollers, ive also found that some remanufactured cartridges causes this problem, I dont know how or why but they do.
Dec 09, 2010 | Brother HL-5370DWT Laser Printer
Print function is not working properly. I have a Ricoh Afcicio 1013F. It prints a few pages then has an error msg.
Does the machine copy okay? If you copy several pages, do they all come out normally, or do you get an error message like when you print?
What is the error message that shows up? If the machine prints a few pages before the error comes up, and it works fine when you are copying, the problem is likely either with your network or with the application you are trying to print from. Depending on what the error message says, it will help to isolate the problem.
It could also be the print driver itself. You can go to to the Downloads section and either update or reinstall the print driver if nothing else works.
Jun 05, 2010 | Ricoh Aficio 1013F Copier
Incomplete copying/printing. Full page not copying, just 3/4 of the page, whether b/w or colour. when photocopying or printing only a thrid of the text or image is printed.
Check wether the transfer belt cleaning unit inside the photoconductor unit have wrong cleaning cycle due to the defective cleaning clutch.
Oct 02, 2009 | Ricoh Aficio 1232C Color Copier
'1) Lost' Black print 2) Can no longer scan more than one page
Lost Print solved by repeated cleaning. No solution to the single feed problem yet.
Jun 22, 2009 | Brother MFC-5440CN All-In-One InkJet...
My ricoh printer is not printing straight!
Make sure the guides in the paper tray are snugg around the paper..
Apr 30, 2009 | Ricoh Aficio 1018 Printer
Ricoh CL4000DN Laser Printer Logo
96 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
