Question about Intel D845GLLY Motherboard
Hello i am nadeem
My motherborad is d845glly destop board my problem is system turn on but moniter led bilinking and hard disk light display continue on processor fan is normal work but systme is not go in bios please help me what hapine
I had the same problem
check the pin & socket of the cable that connects ur monitor with CPU (data cable, not power)
If this doesn't work change the power supply (worked for me )
Posted on Oct 12, 2008
At fist power off, open the cabinet and carefully open the RAM and
clean the RAM pin as well as RAM slot. Again put the RAM on it slot. Your problem may be solved.
Posted on May 27, 2008
Mac osx display
If your laptop appears to boot up and the hard disk LED flashes, then the problem is probably a back light fault. This can be a faulty inverter or a faulty CCFL lamp. Please click on this link and follow my instructions to identify the fault and possible fix :-
http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
May 02, 2013 | Computers & Internet
One day, when i clean my system box that i take out the pannel wires from the board .these are power led,hd led etc....after that when i set up those wire i can not use my computer computer .my destop...
Hello aunglina6
As i can see from the picture of your motherboard the connections are at the bottom close to the battery. it looks like this
o o o o 1 2 3 4
o o o o o 5 6 7 8 9
this is just to give you the idea how it is set up.
9 is no connection
8 + 7 is reset switch, 6 + 5 is hard disk LED with 5 the positive of + side.
1 + 2 is power LED with 1 the positive or + side, 3 + 4 is the power switch.
with the reset and the power switch don't worry about the positive or + side. it makes no difference.
good luck.
please leave comment if this was helpful
Jan 01, 2011 | ECS RS400-A (V1.0) Motherboard
D845GLLY mother board unable to detect 250 GB SATA seagate hard disk
have u installed sata raid driver in Win XP ur system might not contain the driver for SATA drive pls download and install
http://downloadcenter.intel.com/T8Clearance.aspx?sType=&agr=Y&ProductID=2300&DwnldID=17268&url=/17268/eng/iata87enu.exe&PrdMap=&strOSs=45&OSFullName=Windows*%20XP%20Home%20Edition&lang=eng
pls rate me FIXYA if ur problem is resolved
Oct 16, 2008 | Intel D845GLLY Motherboard
Green light continously blinking in samsung sync master 753s
1. cpu problem. why because of there is no signal output from cpu to monitor. the led blinking means there is no vertical, horizontal signals from cpu to monitor.
2. your monitor connected to another system.
3. neck board dry points.
4. cheak the display cable. 13&14 pins are horizontal, vertical signals.1, 2, 3 pins , R G B , 6 ,7, 8 pins R G B ground ( coaxiler cable used , meshed wire is ground )
Oct 13, 2008 | Samsung SyncMaster 753S 17" CRT Monitor
Intel 845 glly board please solve the problem
Hi Nadeem Nawaz,
No board will show display without memory. Your motherboard must run memory type;
Two DIMM sockets supporting 3.3 V (only) 168-pin 133 MHz Single Data Rate (SDR) SDRAM DIMMs with gold-plated contacts.
Unbuffered non-ECC DIMMs only.
Maximum total system memory: 2 GB; minimum total system memory: 64 MB.
Serial Presence Detect (SPD) DIMMs only.
Intel link showing memory specifications.
Intel Desktop Board D845GLLY
http://www.intel.com/support/motherboards/desktop/d845glly/sb/cs-012825.htm
If your memory is within Intel's memory specifications & you are not getting display on your monitor. It is possible that the integerated on board graphics (Shown on page 13 in your user manual), may be defective.
You can add a PCI video card to the PC. The Intel D845GLLY will auto detect the PCI video card. No need to enter the bios & make changes.
Please keep this in mind. The integrated video card is PCI, if it has failed, there is a good chance it will not see the PCI add in video card. If you can find a used (Working) PCI video card to test in the PC.
Intel Desktop Board D845GLLY main website link.
Luck!
Apr 19, 2008 | Intel D845GLLY Motherboard
The power on my pc keeps recycling
remove all hardware except RAM n CPU and then try it if the system gives you a disply then add all hardware 1 by 1 and keep checkin this way you can find the problem with the harware compatibility if the system wont disply then check the mobo for RAMs and CPU respectively if the problem presists then you have the BAD BOARD.-
Jan 16, 2008 | Intel D845GLLY Motherboard
No display on moniter but cpu is running
change the RAM(RANDOM ACCESS MEMORY) of your pc.
Dec 12, 2007 | Intel Motherboard
Intel D845GLLY Motherboard Logo
60 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
