Question about D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point
Can't connect to configure password through web address 192.168.0.50
Dear Sir or Madam,
My friend gave me his D-Link DWL-2100AP, H/W Ver: A2 F/W Ver. 2.00. I reset the unit so it can go back to its default settings. I have a wired router in my office (NetGear) that I can connect this unit to one of the pc's that is not being used and then I can have internet access using 'default' network with my MacBook Pro. My problem is that i need to set up a password to give it some security because when this unit is plugged in, anyone can use it to access my other office computers and it could be disastrous.
I don't know how to connect it so i can access it's menu to configure. I tried directly connecting the unit to my pc and also directly connecting it to my Macbook Pro laptop. Of course, no luck. Any ideas would be greatly appreciated. Thanks.
  • 18 more comments
  • roygbiv28 May 20, 2008
    Thanks tech curly for your very prompt response. You helped me connect to this access point. It wasn't displayed in the same way as you had seen because I probably had an older version. I did have to type 'admin' for username but i had to leave password field blank. Thanks again for all of your help. I just found this web site today.
  • roygbiv28 Jun 09, 2008
    Dear Tech,
    Thank you for helping me secure this access point, but now i find that when I try to use it to surf the net, it takes a very long time to connect to various web sites (almost like using a dialup modem) even though i have a cable connection. Sometimes it even times out. Any suggestions would be appreciated.
    When I reset the access point back to it's default, it connects quick.
    Thanks for your help.
  • Anonymous Sep 24, 2008
    wireless
  • abor Sep 28, 2008
    Ineed
  • Anonymous Oct 29, 2008
    dont have any idea regarding this device and kind a misfortune i got this device to be installed for the laptop
    any advice or help would be gladly appreciated. thanks
  • HAZEM794 Nov 27, 2008
    same Problem
  • reekko Dec 03, 2008
    how to put a passwword on the access point ?
  • trace7 Dec 27, 2008
    i have a eh100 router and was given this code to setup my laptop...but it just keeps saying cant find server,yet all the rest of the internet is working!
  • Anonymous Jan 13, 2009
    hi sirs
    i have a problem with connecting the acces point DWL-2000Ap 802.11g/b the internetis working but i couldn't configure or set my username and password
    i need ur help plz
    best regards
  • ancelcleetus Jan 16, 2009
    when i type http://198.162.0.50 i am not able to connect. it says check your connection.
    Regards
    Ancel
  • ramwar Jan 25, 2009
    i have th same probelm with a dwl-8200 ap i cant access it.
    i have even tried to make a ping ot it and it does not work.
    I have reseted the device and i have assigned and IP address to the computer from whih i tried to access it and yet nothing
    any ideas?
  • roger7 Jan 29, 2009
    I am tring to reset my dlink dwl-21oop i tap in the usual http:// code but to no avail. No logo pops up, no set up wizard. Any ideas?
  • Anonymous Feb 11, 2009
    Sami mawon mboten saget di password. Pripun niki mumet mas!!!
  • Anonymous Feb 16, 2009
    fgh
  • jaschweizer Apr 09, 2009
    same problem, have access to the Internet but I can't get to 192.168.0.50 to configure router security. thanks!
  • nicky769 Apr 13, 2009
    cannot connect to configure password through web address 192.168.0.50
  • Markhutt Apr 25, 2009
    can't connect to configure password through web address 192.168.0.50
  • Projak May 06, 2009
    I have a D-Link DAP-1522 Wireless Bridge and can't connect to the Configuration Utility at DLINKAP or 192.168.0.50: both addresses will not access the needed web site?? What is the problem with this address?
  • licovski May 15, 2009
    Struggling to set it up
  • singhbablu27 May 11, 2010
    need add passwerd
  • 298 Answers
Here is what you can do. You need to access the setup page of your Dlink Access Point.
1. connect a computer directly to the access point (via ethernet). Then assign an IP address on the computer (IP: 192.168.0.10 Subnet Mask 255.255.255.0 DG: 192.168.0.1 ). It is necessary for you to assign an IP address because your access point does not have the ability to assign an IP address to the a computer, its is not like a router.
2. After you assigned an IP address, you can now access the Dlink Access point's setup page. To do that open your browser in the address bar type http://192.168.0.50 (this is the address of your access piont) and it will ask you to put a username and password. Just type admin for both username and password field. And it will take you to the setup page of the access point.
3. To enable a wireless security, just click the tab on the left hand side that says Advanced, it will populate the options under Advanced and select security. On the main screen you will now have an option for security modem, you can select wpa-psk, then on the Key box you can type any password that you want (8-63 characters). Then click update there at the bottom of the page. If you also want to change the name that the Access point is broadcasting you can go to the on the left hand side that says Wireless and put any name that you want on the box that says SSID. After that click updat button again.
4. Now after updating the settings, You can reconnect to the network. And this time you will now be asked for the network key. Just type your network key. That's it.
Just reply to this post in case that you need more help.
Posted on May 20, 2008
  • 2 more comments
  • Jeffrey Pedimonte
    Jeffrey Pedimonte May 20, 2008
    You're welcome!
  • Jeffrey Pedimonte
    Jeffrey Pedimonte Jun 09, 2008
    there is alot of possible reasons why its happening... it may run a bit slower if you have a security but not same as a speed of a dialup connection. Have checked if you are getting at a good or very signal? Try to change the channel try channels 1,11. check if there is an interference like cordless phones running on 2.4 ghz. Does all of your wireless computers is experiencing the same problem?
  • emmanuelmesh Sep 24, 2011
    Very nice info. Work like a talisman
  • Karan Garg Oct 14, 2012
    Hi Jeffrey, I have one problem. I cannot connect to 192.168.0.50. I did everything that you have mentioned. But the bloody browser wont open the link. without the link i cannot configure my AP. Please help. thanks in advance. Cheers
In order not to need to change any settings on the computer, simply connect the AP to the internt via an ethernet cable connected to the router.
And then proceed by writing 192.168.0.50 on the computer, etc.
After saving settings of the AP, disconnect ethernet cable.
Hence, no need for any changes in the computer`s settings, even if we are talking temporary changes!
Otzenklotzen
Posted on Nov 09, 2008
  • 3 Answers
Posted on Nov 19, 2009
Hi there!
Any one has an idea why I can't connect to website http://192.168.0.50 ?
It directs me to ICQ Search site, so it means can' find site...
Thank you!
Posted on Nov 15, 2008
Dear Sir or Madam, I Have a D-Link DWL-2100AP, H/W Ver: A4 F/W Ver. 2.20. I reset the unit so it can go back to its default settings. I have a wired router at home that I can connect this unit to my pc and a notebook that is not being used and then I can connet to the internet. But I'm failing to get to the we address given in the quick setup.
Posted on Oct 01, 2008
I can't configure my accesspoint from private default ip to secure one ?how can i secure it and make it a repeater at where the siginal ends to extend the signal to where i stay at about 120m?
Also this problem
Posted on Sep 29, 2008
2 Suggested Answers
SOURCE:
  • 10 Answers
SOURCE: can't connect to configure password through web address 192.168.0.50
When you reset the AP, how long did you press the reset button? To reset the AP to factory defaults, the reset button should be pressed and held for at least 15 seconds. Also, once reset, the AP should have the following settings:
IP address: 192.168.0.50
Subnet Mask: 255.255.255.0
Default admin username: admin
Default admin password: <blank>
When connecting your PC, either set an IP address within the same subnet (192.168.0.51 255.255.255.0) or choose "Obtain address automatically".
I hope this helps.
Dave Grannas
Posted on Jan 25, 2009
Wizard admin dap. i reset the dlink airplus xtreme g dwl 2100ap but i cannot get into it with the default ip that is 192.168.0.50
Connect your computer to the router.
Under Windows 7, click the "Start" button.
Type 'cmd' into the search-box, and press ENTER.
Enter 'IPCONFIG /ALL'.
Look for the IP-address of the "gateway" (or "DHCP-server").
Type that IP-address into your web-browser.
Dec 11, 2013 | D-Link AirPlus Xtreme G DWL-2100AP...
How to set password
if your router doesn't have password yet, you need to get inside of the router configuration.
follow this steps. open an internet explorer at IE web browser type this default IP address,
192.168.0.1, then put this username ADMIN and leave the password blank.
when you get inside you can see the all configuration that you want.
note: the ip address that i give is the default ip. you cannot use this ip if your router is configuered already, unless you reset it.
hope it will help you.
Jan 13, 2011 | D-Link AirPlus Xtreme G DWL-2100AP...
Unable to connect D-link Air plus xtreme g wireless access point from pc for making configuration
Under Windows 7, press the "Start" button.
Type 'ipconfig /all', and press ENTER.
Look for the IP-address for the "gateway" (or "DHCP-server").
Jan 10, 2011 | D-Link AirPlus Xtreme G DWL-2100AP...
Can't open DAP-1150 configuration utility
The DLink URL WEB configuration uses an IP address not //dlinkap
Try http://192.168.0.1
The default ligin = admin
The default PW = blank ie. nothing
Jan 04, 2010 | D-Link AirPlus Xtreme G DWL-2100AP...
what you were missing is the fact that if you directly connect router to pc you will have to change ip on pc to match router i.e you are trying to connect to router through ip listed above then you should make ip on pc 192.168.0.***.
May 11, 2009 | Computers & Internet
Configure dwl-2100ap
yes you can do it put access point dricetly to the modem then you get it
Mar 31, 2009 | D-Link AirPlus Xtreme G DWL-2100AP...
I hope this helps.
Dave Grannas
Jan 25, 2009 | D-Link AirPremier DWL-8200AP 802.11a,...
D-link dwl-2100ap in WDS mode Received Deauth: WLAN 1 11G STA
I have had similar problems with DWL-2100 and (much less often) with DWL-3200. I have no solution, but a workaround: changing the authentication mode. For example, if the units are using WPA-Personal, I change it (on both) to WPA2-Personal or WPA-Auto-Personal. It doesn't seem to matter which mode is used, it's just the fact of changing it that helps (eventually). You may have to go through the process more than once. Also, realize that although the web interface comes up 30 seconds or so after a reboot, it may take another 30-60 seconds before a link is established, so don't give up too soon while trying these changes.
Dec 03, 2008 | Computers & Internet
I need help on how to use setup wizard
hat type of connection do you have? if you connect everything and put 192.168.0.1 in the address field in the browser you will be taken to the dlink router setup page. the default username is admin and the password is admin. from there you should see a setup link.
Oct 29, 2008 | D-Link AirPlus Xtreme G DWL-2100AP...
Hi blanx - don't rate this yet. Are you just trying to access the D-Link to secure the network? Have you determined your setup and simply need to secure the D-Link? Thanks.
Jeff
May 21, 2008 | D-Link RangeBooster G WBR-2310 Wireless...
D-Link AirPlus Xtreme G DWL-2000AP 802.11g/b Wireless Access Point Logo
48,456 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Ekse
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
