Question about LG LRFD21855 Stainless Steel French Door Refrigerator
Ice maker not producing ice
After the doors were left open for a few hours, we removed the ice box and dumped the partially melted ice down the drain. We then turned the ice maker off and then back on different times to wait 12 -24 hours for ice to be made. No luck. Further, the arm that we're not supposed to touch seems 'frozen' in the up position and we don't know how to get it down without touching (and possibly breaking).
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 210 Answers
What you can try to do is put the ice maker in test mode. Press and hold the ice size button, on the ice maker itself, for 5 seconds. It should cycle through and this could reset it.
Sgt 48
Posted on May 31, 2008
Mine is doing the same thing, I can put it in the "test" mode & it is ok, but after one tray of ice it must be put into test mode again ... should I replace the ice maker, filter is new & water supply is good.
Posted on Jun 02, 2009
2 Suggested Answers
  • 210 Answers
SOURCE: Ice maker not working
If you press and hold the button on the ice maker for seconds it will go into test mode and do a complete cycle. Try this and it should correct the problem. If you think the arm is frozen, you could use a hair dryer on it for a couple of minutes then do the test.
Sgt 48
Posted on Jun 03, 2008
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
I had the power out on my refrig for about 8 hours. Now the ice maker has stopped making ice. Water in the door works, but no water going to the ice maker and not dropping ice. Do I need to defrost the...
There is a dual acting water valve that feeds the ice maker and door water seperately.
If your power went out - chances are good the solenoid on the icemaker side of the valve has failed - so it will not open the valve on the demand of the icemaker timer.
To find out - you will need to check that there is voltage at the valve.
With a model #, I can help you better.
Thanks!!
Feb 20, 2010 | Refrigerators
Ice maker will not make ice. no ice is being made. no water appears to be in ice cube making area. can hear a ticking noise from icemaker area
Carefully pour water from small glass into ice maker, until the cavity is near filled. Wait a few hours. If it dumps ice, you can usually rule out the ice maker.
If ice maker dumps, then it will be either a bad water valve, Ice building up in fill pipe going into the icemaker, or blocked water line that runs from your water source to the machine.
Caution. If the fill tube going into the ice maker is filled with ice do NOT
use heat such as a hair dryer to melt it. It will melt things you do not want to melt. If it is this problem, you must also replace the water valve because it is leaking slowly causing your problem.
Lastly, in rare cases, the microswitch in the ice maker fails and does not allow water to enter the icemaker.
Oct 22, 2009 | Kenmore Refrigerators
Ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
Aug 26, 2009 | Samsung RS2578BB Side by Side Refrigerator
Kenmore Elite, Ice maker will not produce.
Try taking the ice despenser out and carefully melt any ice in the freezing tray. Sometimes the ice doesn't fully eject, leaving behind residue that will eventually become too full to produce ice. You can melt it by slow running hot water or hair dryer low speed.
Aug 07, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
Water coming out of the freezer compartment into main unit
I believe the drain is blocked behind the panel wall inside freezer. You will need to unplug the refrigerator and remove panel and inspect drain at bottom of evaporator. There is a tray with a drain hole on the low end. Also check around area that water enter from back of refrigerator to ice maker. Let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 26, 2009 | Whirlpool Gold White-on-White 21.9 cu. ft....
The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
Hello jitkagardner,
Welcome
You said, The ice maker in my whirlpool gold refrigerator Model No, GR2FHTXTBOO, is not working.
How old is the fridge?
When have you last changed the water filter.
Should be down below at the front grille!
Try these tasks!
If the ice maker is not producing ice or not enough ice
Refrigerator connected to a water supply and the supply
shutoff valve turned on? Connect refrigerator to water
supply and turn water shutoff valve fully open.
• Kink in the water source line? A kink in the line can reduce
water flow. Straighten the water source line.
• Ice maker turned on? Make sure wire shutoff arm or switch
(depending on model) is in the ON position.
• New installation? Wait 24 hours after ice maker installation
for ice production to begin. Wait 72 hours for full ice
production.
• Freezer door closed completely? Firmly close the freezer
compartment door. If the freezer compartment door will not
close all the way, see "The doors will not close completely."
• Large amount of ice recently removed? Allow 24 hours for
ice maker to produce more ice.
• Ice cube jammed in the ice maker ejector arm?
Remove ice from the ejector arm with a plastic utensil.
• Water filter installed on the refrigerator? Remove filter and
operate ice maker. If ice volume improves, then the filter may
be clogged or incorrectly installed. Replace filter or reinstall it
correctly.
• Reverse osmosis water filtration system connected to
your cold water supply? This can decrease water pressure.
Let me know how it goes!
Huuum
Please remember to leave a rating!
Oct 21, 2008 | Refrigerators
Sgt 48
May 20, 2008 | LG LRFD22850 Bottom Freezer Refrigerator...
Kitchenaid superba side by side ice maker stopped producing ice
This is a picture of an ice maker module.  Which is behind the white plastic cover.  The cover just pops off.  Look at the two little tabs in the center of white wheel.  If yours is twisted, pressed together, or one is broken then the module is bad.  If not, take the icemaker out and let it set for a few hours to let it defrost.  Put it back in and see what you get.  The ice maker won't cycle and fill with water until it gets below freezing so you will have to wait awhile.  It can be started manually by inserting a jumper wire into terminal T and H.  Let it start to cycle for about 10 sec. then pull the wire out.  At the end of the cycle it will fill with water then wait for it to freeze.  Also, if door was left open check all vents in fridge for ice build up.  This cause cooling problems of they are plugged.  Let me know what you find.
Oct 21, 2007 | KitchenAid Superba Architect KSCS25INSS...
LG LRFD21855 Stainless Steel French Door Refrigerator Logo
376 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
