Question about Panasonic Microwave Ovens
Door misalignment causing microwave to stop. Panasonic nns951bf
  • cindynsg May 22, 2008
    door switch needed adjusting and a switch looks like it may need to be replaced. The upper switch plug is burnt.
  • Panasonic Master
  • 9,098 Answers
This is a common problem.
Either the door hinges need to be realigned, or the door switch mounts need to be adjusted. I suspect the latter.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2008
  • William Miller
    William Miller May 22, 2008
    Please refer to my file on door switches, and the sources mentioned in it will probably also have new terminals / connectors needed to replace any which are charred or overheated at the ends of the wires.
    See that file at http://www.microwavedisplay.com/doorsw.t...
    Hope you'll consider this for a FixYa! rating.
    Happy to help!
MY 27 INCH VIKING PROFESSIONAL BUILT IN MICROWAVE OVEN ALLOWS ME TO SET THE TIME, BUT JUST COUNTS DOWN SILENTLY INSTEAD OF MICROWAVING WHEN PUSH START. CAN THIS BE REPAIRED? OR IS THERE A RESET?
Your bottom door switch is probably defective, or its mount is loose, misaligned, or broken.
This is usually caused by opening the door while it's cooking (instead of hitting "stop" first) or slamming the door.
See my help files on safety here, disassembly here, and door switches here.
More questions? Contact me directly here.*
* always include the full model number and FCC ID number from the label on / in your microwave (or a clear photo of the tag)
Jan 27, 2018 | Viking Microwave Ovens
Keypad works but turntable and fan do not. any ideas? Kenmore Microwave 405.72123310
This is likely a problem with the upper or lower door switch or its mount is loose, misaligned, or broken.
See my help file on door switches here.
Jan 27, 2018 | Kenmore Microwave Ovens
Panasonic NN-CT585S Microwave Oven - door seal melting on inside - only 2.5 years old. Has anyone else had this fault or just please check where the glass meets the plastic on inside door.
The door seal is called the reflector cover. It stops particles of food from being left in the reflector, the square waveguide that is under the plastic seal.
The only thing that I think can cause that is particles of food or grease/oil sticking to it and melting the plastic. I don't think it is a fault from my experience of working with microwave ovens since 1993 for Panasonic and many other brands.
Jan 06, 2018 | Panasonic Microwave Ovens
A GE model wes1450dm1bb microwave cooks and stops,but starts when you open door.The only way to stop it is to unplug it then open door. What could be the problem?
You may have a loose, misaligned, or broken door switch mount, or an intermittent door switch.
Door switch trouble is caused mostly by slamming the door or openng the door while it's cooking instead of hitting the "Stop" pad first.
My help file on door switches is here: http://031d26d.namesecurehost.com/mwd/doorsw.txt and you can visit my helpp site at http://www.microwavecontrol.com.
You can e-mail me at pupista@gmail.com and include your full model number and FCC ID number from the tag in the cooking cavity.
I'll be happy to help you.
Dec 31, 2016 | GE Microwave Ovens
Panasonic microwave door is misaligned? does not close without slaming it, then sometimes the light still stays on and msg displays that the door needs to be closed. other times, the light goes out but...
could be a bent or broken pin in the door - its a safty issue since microwaves are harmful when the door are not shut - return the microwave to the store you purchased it from or get a new one
Jan 05, 2014 | Sharp R-1480 Microwave Oven
Jennair Microwave Shuts Off after 3 seconds
This is usually a defective or loose bottom door switch or that switch's mount is loose, misaligned or broken.
It's usually caused by opening the door while it's cooking instead of hitting "stop" first) or slamming the door or both.
My help file on door switches is here.
May 19, 2013 | Jenn-Air JMV8186AA Microwave Oven
Panasonic invertor slimline combi
The main fuse in the microwave oven has blown, usually caused by one or two defective door switches.
Mar 30, 2012 | Panasonic Microwave Ovens
I purchased a Panasonic NN-AW554W Combi Microwave from Amazon on 18/09/2007. On 15/9/2008 I started the microwave and it immediately stopped working and tripped the circuit breaker in the fuse box. I...
Something about that model number doesn't look right. It's not showing up...
Since it failed just inside the warranty period, I would waste no time in contacting Panasonic to verify the warranty and find an authorized service center to fix it free.
You can find their contact info in your owner's manual or reply back with what country you're in and i can give you a link.
Otherwise, please visit this site and pick out your country, then look for the Support link.
I would say you have an issue with a bad door switch or misalignment of the door switch holder or hinge.
Sep 19, 2008 | Panasonic Microwave Ovens
I have just bought a NN-CS596S. I followed the unpack and startup instuctions without amy problem. It will now work consistently on microwave thogh. It works fine on grill or oven, but seems to have an...
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
It may have been damaged in transit. A loose door may leak microwave energy.
I'd return it to the dealer since it's so new and under warranty.
Jul 17, 2008 | Panasonic Microwave Ovens
MICROWAVE TURNS ON WHEN DOOR IS OPENED.
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
Door switches are most often damaged by opening the door while it's cooking (instead of pressing Stop / Clear first) or food
/ grease debris in the switch.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Nov 05, 2007 | Panasonic NN-S254BF Microwave Oven
Microwave Ovens Logo
223 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
