Question about Mitsubishi VS-60603 60" Rear Projection Television
Big screen won't work
I have a Mitsubishi 50" VS-60603 and when I turn it on the only thing that happens is the green light on the timer comes on and then it goes off.
  • 5 more comments
  • contagious Jun 08, 2008
    I have the exact same problem and it sounds like it could be a bad switch in it or possibly blown fuses
  • Anonymous Sep 08, 2008
    When I turn on the TV the green light comes on then it shuts off.
  • brians799 Sep 17, 2008
    samething. I was told the lamp leaked on the board. $500 to fix??
  • jacktone9 Oct 01, 2008
    I have the same problem. The green light comes on then clicks off.
  • rubentheahol Oct 04, 2008
    When the TV is turned on a green light blinks and there is a clicking sound.
  • deamar1 Feb 15, 2009
    My power light is green, the screen is black, some guy said it may have leaked a small amount of antifreeze on the board which may need to be replaced, any ideas? Thanks
  • Anonymous Apr 05, 2009
    i try to turn my tv on the green timer light goes on for a sec then goes off again, that's all it does
Test
Posted on Aug 13, 2008
  • 4 Answers
Also a color wheel that has gone out ..replace it.
Posted on Jul 18, 2008
Posted on Nov 13, 2008
Mitsubishi vs-50609 green timer light comes on no
Unplug the tv and leave it unplugged for a couple hours. Plug tv back in press reset button. TV led may flash for a day but should come on. I did this last night to mine and it came on at 11am today.
Mar 29, 2010 | Mitsubishi VS-50609 50" Rear Projection...
Big Screen Televison problem
1) pull chassis ( requires un-hooking extensive wire runs)
2) turn chassis upside-down
3) solder any / all bad connects,esp. regulator pins
Look for electrolytic capacitor leakage evidence =
dark,discoloration of trace material
4) replace any bad capacitors
5) re-install chassis and test
Nov 05, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Tip
VZ5 Chassis mitsubishi VS-60603 With excessive brightness
If experiencing excessive brightness in the VZ5 chassis mitsubishi's it usually can be traced back to a leaky transistor on one of the CRT PC boards. Check Q6R1 on Red PCB, Q6B1on the Blue PCB and Q6G1 on the Green PCB one of these transistors will most likely be leaky
on Feb 23, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mitsubishi VS-50609 won't turn on
What a great tv this is Mitsubishi did a fine job making this one, but......only an authorized mitsubishi servicer should repair it. This set records diagnostic led codes that the technician receives to help determine where the problem might be, not the problem, but in which circuit it might be. The one thing to try is, unplug the tv , let it set for a minute, plug it back in , turn it on and hope it reset the micro. Next , call for mits. service.
Jun 11, 2009 | Mitsubishi VS-50609 50" Rear Projection...
Mitsubishi VS50605 rear projection TV won't come on
The power supply caps in the light engine power supply were faulty when they were installed. You need to remove the power supply and take it to your local electronics shop where they can remove the (7) faulty 1000uf 16v electrolytic capacitors and insert new ones. If you remove the power supply yourself (takes only a philips screwdriver) and reinstall it yourself, the electronics shop shouldn't charge you for more than an hour worth of time. The caps would be about $10.
Here's a photograph (thanks Don Crawford).
Nov 13, 2008 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi vs-60603 lamp replacement
the VS 60603 has picture tubes three of them called CRTs you can get replacements at the following link.
http://servicemanuals.vstore.ca/
Aug 17, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Mits VS-60603
the light bulb has gone out....
Jul 18, 2008 | Mitsubishi VS-60603 60" Rear Projection...
No picture mitsu 60603
its about 3/4 of the way up that board on the left hand side its the vertical output ic mounted to a aluminum heat sink
Apr 27, 2008 | Mitsubishi VS-60603 60" Rear Projection...
Televison & Video Logo
256 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
