Question about Panasonic NN-P294WF Microwave Oven
NNP-294 Dead Hi, Microwave was dead, no power/lights/fan/display. Circuit fine. Took unit down, checked fuse, its good. Put unit back together, plugged in WORKED! Reinstalled, ok, woke up this morning, no display, dead again. Tapped under door open button, display came up, working. Door is not opening as it used to, have to hold button in, slow to desengage. Appears a little greased up. Can one of the door safety switches actually cut power to everything? If not, is there anything else that will cut power to everything? Any help appreciated. Dave
  • Panasonic Master
  • 9,098 Answers
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you suspect the fuse at all, it's best to replace it.
With the microwave unplugged, if you can easily turn the fuse with your thumb & forefinger while it's in the holder, it has overheated and fatigued and the holder should be replaced.
Simply squeezing the holder's terminals together with pliers is not really a good solution.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
An intermittent door switch will not make the unit intermittently dead, it will only make it not heat, and depending on the model, it will also likely make the turntable and inside light not come on. But again it depends on the model.
You may need to clean and/or realign the door mechanism or door switch mounts.
This is especially true in case a user opens the door while it's cooking without hitting Stop first or slams the door. Both are big no-nos for a microwave.
The main parts that will kill the power are the fuse, fuse holder, or thermostat or thermal cutout, which are usually located on or above the magnetron and on the top of the cooking cavity.
Please feel free to contact me directly if you need more help.
We're happy to help and we appreciate your thoughtful rating of our answer.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 22, 2008
Used the microwave last night. Later I noticed no light display for the clock. Come to find out microwave lost all power. Model number smh9207st
If there are no fuses or circuit breakers, the unit could be down and out. Check you power box for any tripped breakers.
Dec 09, 2014 | In Microwave Ovens
Hi I have a Samsung SMH9187 micowave that is dead (no display, light, fan, mirowave).
Sounds like the main fuse blew. It's either near where the power cord enters the cabinet, or behind the control panel (if an over the range unit).
You may also have some type of failure in the high voltage circuit; based on your description of the symptoms.
Aug 16, 2014 | Samsung SMH9187ST Microwave Oven
No power, no display power to unit
Blown fuse inside of unit. Must find out why fuse blew, something shorted or bad connections.
Oct 21, 2017 | Jenn-Air JMV9169BAS Convection Microwave...
Unit went dead. No fan, display, light, oven. Is there an internal fuse or reset?
There is an internal fuse. Be careful high voltages present even if the microwave is unpluged.
Good luck
Jan 03, 2014 | GE Spacemaker JVM1640SJ Microwave Oven
The built-in microwave went dead as I attempted to screw in a new light. It arc'ed, then there was zero power to the unit. Is there an in-line fuse or circuit-breakers?
was cooking on the stove below the microwave and had the fan on. the nicrowave went out all together and will not come back on. it did not blow a fuse in the breaker box. is there a reset button or something to turn back on
Aug 05, 2008 | Microwave Ovens
Replacing the fuse of a MCO160UW
A microwave can be dead for many reasons.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There may also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
We're happy to help you and we'd appreciate your thoughtful rating of our answer.
Jul 15, 2008 | Magic Chef CMV1000B Microwave Oven
My R-1870 microwave oven is completely dead. No display no response to keypad entries. No fan, No light below the oven. No light in the oven. Checked the circuit and there is 110v to the plug.
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can probably find exploded views and order parts by entering your model number here at the Sears parts site.
The best place to order Sharp parts is Tritronics.
We have the full service manuals for this series of ovens and have uploaded them to our site here and here.
Jul 05, 2008 | Sharp Microwave Ovens
GE Over the Range Microwave/Convection won't start
So it's dead - that is to say no display, no lights, and no response from the keypad?
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the thermostat to open. When it cools, it closes the circuit and allows power through again.
If the fuse is good, it may be an open thermostat or thermal cutout on or near the magnetron or on top of the cavity / body of the oven.
If you or a friend decide to look into it, we have critical safety information and disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We appreciate your thoughtful rating of our answer.
Nov 25, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Maytag microwave - mod# mmv5100aaw
CHECK MAGNETRON RELATED CIRCUIT, HIGH VOLTAGE CIRCUIT, CONTROL CIRCUIT,AFTER CHECK MAINS FUSE.
Aug 29, 2007 | Maytag MMV1153A Microwave Oven
Panasonic NN-P294WF Microwave Oven Logo
255 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
