Question about Panasonic PV-C2061 20 in. TV/VCR Combo
Remote cotrol does not work except in close range.
My remote control for PanasonicPV-m2023 does not work except in close range. I have replaced new Batteries too? can you help.
Thanks
Pitchai
  • Pitchai May 23, 2008
    Thank you for your help. I cleaned the remote control and TV 's infra red receiver. It does not work from a distance. However the remote control has been working at cloe quarters even befoe.
    Thanks anyway.
    Pitchai
  • 38 Answers
Clean both red filter plastic windows, 1 at the remote control end and 1 at the tvs InfraRed receiver end, with window cleaner on a soft cloth. If this doesnt work you need to confirm operation with another working remote. Either the transmitter(remote) or receiver (tv) could be faulty.
Anything obstructing the IR path to the receiver located at the bottom edge of the tv bezel?
Posted on May 20, 2008
  • Jango Fixit
    Jango Fixit May 27, 2008
    Fault could lie with either the remote or the receiver, you need to make a confirmation with a working unit.
Only the multi function control panel opens/closes garage door. Remotes and keyless entry do not work.
There's a lot of things that can cause range issues. Wireless routers to close to the garage. Bad LED or CFL bulbs. Faulty circuit board. A faulty motion detector on a light. Sometimes if you turn all of the breakers off except to the garage you can isolate it. If that doesn't help call a garage door company to come out.
Jan 13, 2016 | Chamberlain 1/2-HP Whisper Drive Belt...
Remot cotrol # 2 not working propaly and bettery dischge within two days, progaraming runnig it salf do not sotop,
I saw your post, hmodi, and wanted to provide some assistance! It sounds like you need that remote replaced with a new one. In the event that you haven't yet spoken to someone about that, please let me know so I can get it taken care of for you!
Aug 24, 2011 | DISH Network IR Remote Control
I have a Craftsman 139.5399OD opener. It has worked fine for a year. None of the remotes will now open the door. They work fine to shut the door but will not open it. I have checked the door sensors and...
Here is some information. Some pertains and some doesn't.
Limited range of your remote controls could be related to radio frequency interference that comes from something in your home or in the surrounding environment. Certain electrical devices can radiate interference; this could be almost anything that is plugged into an electrical outlet.
Please keep in mind that the device can be brand new, or can be an item that has been in use for quite a while. Also, the item may continue to function properly as far as you are able to tell. The only problem with the item may be that it has started to broadcast the interference, with no other symptoms noted.
Some devices are more likely to generate interference than others. This includes TV cable, cable amplifiers, surge protectors, fluorescent lights, battery charging devices (power tools, golf carts, etc.), anything that utilizes a timer (sprinkler systems, lights, alarm systems, etc.), and a myriad of others. If the problem seems sporadic, we can safely assume that the device responsible for the interference is only being operated during these times. Again, please keep in mind that the age of the device does not determine if it is capable of broadcasting unwanted interference. Any electrical device can be the source of the problem.
The first step is replacing the battery in your remote. If the range on your remote does not improve, remove the wall control wires from the overhead unit. If the range does not improve you will likely need to replace the remote control. After replacing the remote, or if you have other remotes programmed in to the opener, and the range problem still exists, please proceed to the Power Down test.
Multiple garage doors:
If you have two garage door units and one is working just fine, you will need to start by unplugging the good unit. This will help determine if the unit with no range starts to function properly. If the range comes back to the bad unit then you will need to replace the logic board on the unit that was unplugged as it is emitting an RF signal that is over powering the other garage door opener. If the range does not improve after the “good” unit has been unplugged, replace the batteries and try programming some additional remotes to determine if the existing remotes are the issue. If the extra remotes do not have any range then you would need to replace the receiver logic board in the “bad” unit.
Power Down test:
To isolate potential sources of interference, turn the circuit breaker off to the garage and plug the garage door opener into an extension cord from another room. If the range improves, then the interference is coming from a device in the garage. If no improvement is seen follow the same procedure, this time turning off the circuit breakers to your home, with the exception of the garage and test the remote controls. If improvement is noted, turn the circuit breakers back on, one by one, until the range problem resurfaces. This will allow you to narrow down what room the problem device is in. You will have to go from there to isolate it further, by unplugging and re-plugging the items in that room.
If you are unable to determine any source of interference, then the receiver logic board in the overhead unit will need to be replaced.
Sep 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Craftman 1/2 garage door. Model 13953879. RF intereference issue
Power Down test:
Apr 17, 2010 | Sears Craftsman LiftMaster Chamberlain...
Remote Control Problem
Are Both TVs Vizio TVs? If not it means it has droped the code to the set it is not turning ON
Jan 08, 2010 | V, Inc. VIZIO RP56 Rear Projection...
Tv remote control
Chk this out guys http://www.novii.tv/ .....
Apr 01, 2008 | Sony Ericsson K550i Cellular Phone
Manual code to program remove for panasonic pv m2023
The remote control for Panosonic model 2023 does not work from a distance. But it works close by
Can you help?
Soundar
Nov 15, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
TV/VCR PV-M2023-R or PU-M2023-R 1995
if u stick ur bowo in it then it should do the job
Oct 27, 2007 | Panasonic PV-C2061 20 in. TV/VCR Combo
Panasonic PV-C2061 20 in. TV/VCR Combo Logo
149 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
