HP w1907 LCD Monitor Logo
Posted on Sep 21, 2010
Does the Hp w1907 have a built in monitor microphone? If so, how do I activate it for an online meeting?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Oct 02, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
1260
Points
I'm sorry but it does not. I also wanted to find this out a long time ago. If you use skype or some other type of chatting. It will only output what is happening on the computer like watching a video or anything else. The only possible way for you to make a cheap and inexpensive mic is using the headphones that you have, and put them in the microphone slot in you PC and or Laptop.
Anonymous
Level 1:
New Friend:
  • Posted on Apr 18, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1322
Points
There is a mic built into the monitor, I muted it once and then I just recently found it on my own after a long time of people telling me there isn't one even though I know I used it. First right click the speaker icon on the lower left screen and select recording devices, if your mic doesn't show up in the recording devices, right click the area where it is suppose to show and select show disabled devices. Your mic should show up there and then right click and select enable. If the right clicking doesn't allow you to enable it, just click the properties button on the bottom right of the window. Once there click on the device usage on the bottom and select enable.
How can i hard reset my hp w1907 monitor
Thurn monitor on as its powering up press Ctrl+ F11
to do a system recovery.
Also go to www.manualmonitor.com/hp-w1907
That will let you download free manual.
2helpful
My monitor occasionally blacks out. I turn just the monitor on -- wait a few minutes then it works ok for a while until it blacks out again
There are controls that turn off the monitor, both in Windows control panel and the monitor itself. The system should know if activity is happening, and should not blank if active.
Look at screen savers, too.
1helpful
Does w1907 have built in speakers?
no it doesn't have a built-in speaker, but you can buy a sound bar that can be fitted at the bottom of the screen or use a regular speaker
1helpful
Does this monitor w1907 have built in speakers? If so how can it be hooked up?
it doesn't have built-in speaker, you can use a sound bar or a regular speaker and connect it to the audio port available on your computer
How do I open the case? How is it to open mechanically?
Get a flat bladed screwdriver and go to the corner where the black rim meets the silver back and lever the black rim off gradually working all the way round
A center line on hp w1907
you need to change the monitor...
Hp w1907 - web pages too large for monitor. I
You need to increase the resolution of your desktop.
Goto Display Properties->Settings
5helpful
2answers
Headphones
Welcome to the computer age. I looked up your HP W1907 monitor. It comes with a built in microphone and speakers but no audio jack for plugging in headphones. You will need to find an audio jack on your computer tower. Most new computers have audio and microphone jacks on their front face. In most cases there will be a picture of a microphone or headphones next to the jack to tell you what it is. If you can't find one on the front, look in the back. The audio jack is usually color coded green. I hope this helps you out.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
