Question about Sony STR-DE197 Receiver
Need help why does my sony receiver when the volume is turned up the music stops and the word protect starts flashing
  • mrc174 Jun 17, 2008
    speakers were outdoor, and over time the volume had to keep going up to render any sound as the speakers became unusable.  the speakers were replaced with new ones, but I cannot reset the unit from the "Protect" mode. any suggestions at this point?
  • Anonymous Sep 24, 2008
    Disc 1 of a set CD will suddenly stop playing and "PROTECT" appears.
    Another Disc 2 of the same set will play through.
  • 38 Answers
Have you connected an extra pair of speakers?. (Thereby loading the amp stage beyond it's capacity)
Are the speakers connected to the unit the original ones the system came with or different? ( Speaker impedance, usually displayed at the back of the speaker cabinet must not be less than amp's specifications....6 ohms, 8 ohms)
If you're driving the unit excessively you're lucky this piece is equipped with protect mode, else your speakers and amp would have been fried by now.
One last possibility comes to mind: High volume causes vibration causing loosely fitted mains plug to rattle in wall socket calling "protect" due to improper feed voltage. Move the unit to another wall socket and ensure a tight fit into mains receptacle.
Posted on May 20, 2008
Why did amp indicate error and turn off?
SONY ' eSupport - PROTECT or PROTECTOR is flashing in ...
https://us.en.kb.sony.com/.../protect-or-protector-is-flashing-in-the-displa...
Aug 15, 2015 - Turn off the home audio device, and remove all speaker wires from ... If a cord is frayed or in contact with another terminal, an error will occur.
How to get my receiver to stop flashing protected - Sony's ...
https://community.sony.com/t5/Home...to...receiver...stop.../182577
Sep 15, 2013 - intermittent video ... How to get my receiver to stop flashing protected ... is below the rated impedance range indicated on the rear of the home audio ... D.If the home audio device still displays a PROTECT error or does not turn ...
My AV receiver says OVERLOAD and shuts off, what should ...
Dec 26, 2015 | Pioneer Audio Players & Recorders
I was playing some music pretty loud today on my Sony STR-DB790 and then no bang no crackling just strait to protect mode turned stereo off thinking nothing of it and now every time I turn it on strait to...
There is an output load causing the protect to engage, turn unit off and dis-connect the speaker wires from the back of the receiver, this will reset the processor ic. Now power on and turn volume right down, if the word protect stays off it means there is a short in the wires or one or more of the speakers. But if the word protect comes on with the "speakers and wires dis-connected" it indicates a short in one or more audio output ic's and will need a tech to address the extent of damage and cost.
Feb 06, 2011 | Sony STR-DB790 Receiver
I have a Sony receiver STR-DG510. I was playing music through the receiver when it suddenly stopped and displayed/flashed protect. After unplugging everything and trying a different power outlet it still...
Most likley it is a bad channel. Needs output transistors and a couple of resistors. or it may need a pre-amp voltage ic.
Not a repair for your average do it yourselfer.
Jun 30, 2010 | Audio Players & Recorders
Yes I have a problem with my sony str de 525 receiver its stuck on Protecter every time i turn in on it flashes protecter and i cant get it to stop what do i do
Disconnect the speaker wires from the rear panel, turn the volume down, and see if the receiver still goes into protect when you turn it on. If it doesn't, you need to check your speakers and wiring. You may have a speaker that's gone bad, or a wire that's shorted. Likely causes are too much insulation removed when you stripped the ends and now they are touching, the wire's been pierced by a mounting nail or staple, or it's been damaged somehow.
If the receiver still goes into protection with no speaker load, it's the receiver at fault. I have seen this problem caused by bad solder connections on several areas, bad components in the power supply, and trouble in the amplifier section.
I can't point you toward any specific "most likely" cause, but the bad soldering is something you can check by eye. Any other cause is probably going to require service by a technician who has the test equipment and service information to do more in-depth troubleshooting.
Good luck, and thanks for using Fixya!
Mar 05, 2010 | Sony STR-DE545 Receiver
On my Sony Surround Sound tuner, if I raise the volume up to a certain level (not that loud), I get a flashing sign ''protect'' and the sound to the speakers are cut.
Sony has protection in these receivers for two main reasons.
1 - Checking for DC voltages on the outputs to speakers. Not your particular problem.
2 - Excessive current being drawn from receiver on one or more of the speakers.
Number 2 should be your starting point in finding a solution. Put the volume level on Medium - 35 to 40 on the front panel. Now listen to all you speakers in turn. Any scratching noise will indicate a defective speaker. Remove this speaker from the receiver output and check again if the set goes into protection on high volume.
If you could not find any strange noises on the speakers, remove them one by one and test the set on high volume.
Never - attempt to disengage the protection on this amplifier. The only times we have found the amplifier to be defective with this protection error, it has done so no matter the volume level. Therefore I believe your problem to be a speaker or speakers.
Sep 13, 2009 | Sony Audio Players & Recorders
"Protect" Flashing
In all likelyhood, one or more output transistors have failed. Please confirm your model as STR-DE335 and I'll post the probable parts that need to be checked.
Dan
Jan 22, 2009 | Sony STR-DE335 Receiver
My Sony STR - DE310 flashes PROTECT
remote volume control is broke.
Dec 22, 2008 | Sony STR-DE310
My sony str-d1o15 says protector
I got this from Sony site, I am doing it to mine now, unplugged it first.
Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  1. Check the speaker wires and speakers for proper connections.
  2. Reduce the volume level. IMPORTANT: If the receiver is played back at maximum volume level it may enter the protect mode. Maximum volume listening will cause the receiver to run very hot and may drain the output capacitors.
  3. Disable the surround sound option if both the A and B speakers are being used simultaneously.
  4. Ensure the top of the receiver has proper ventilation to keep it from overheating.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Some receivers provide compatibility with the higher sampling frequencies through alternate connections. Consult the owners manual for specific information.
  6. Unplug the AC power cord for about 1 to 2 hours to reset the output transformers.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Dec 20, 2008 | Sony STR-D1015
My reciever is flashing the word PROTECT and will not function. It's a Sony STR-DE445
Dec 15, 2008 | Sony STR-DE545 Receiver
Flashing message on my reciever
PROTECT, PROTECTOR or the letter P is flashing in the display of the A/V receiver. Solution
sp.gif sp.gif Follow the steps below to troubleshoot if the word PROTECT or PROTECTOR is flashing on the A/V receivers display.
  2. Reduce the volume level. IMPORTANT: Ifthe receiver is played back at maximum volume level it may enter theprotect mode. Maximum volume listening will cause the receiver to runvery hot and may drain the output capacitors.
  5. If the message only occurs when using a DVD player, the sampling frequency may be set too high. IMPORTANT: Somereceivers provide compatibility with the higher sampling frequenciesthrough alternate connections. Consult the owners manual for specificinformation.
Sony STR-DE197 Receiver Logo
262 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
