Question about Gateway 507GR PC Desktop
Gateway OS Restore for Win XP Home fails.
I aquired a set of recovery discs from Gateway. I try a full destructive system recovery and get an error during the Intel Chipset install. The error states that the process could not install Com1 and I get a box for troubleshooting. I am able to close the box (after trouble shooter didn't offer help) and continue install. Once the install completes, the computer restarts. I get the Windows XP screen with the scrolling bar at the bottom. The bar scrolls halfway and stops. The PC then sits there without doing anything else. I let it sit for about an hour and then restarted the machine. The machine then asks if I want to start in safe mode. I can go into safe mode, and the Com1 port is enabled. I can disable the port, but I get the same results if I try to restart and go into XP in normal mode that I get after the recovery. It just sits there. I have reset the CMOS, tried a new hard drive, tried other SATA ports on the board, reconnected all cables/wires, etc. The problem started with a fried modem. Do I need a new motherboard? If so, what kind? I have LGA775 w/Intel 915G chipset. Gateway doesn't support this model any more. Help, please.
  • JBro May 27, 2008
    I went out to the intel website download center, but I didn't find a download for the Intel 915 Chipset. I attempted to download the INF utility zip file, but the download never started. I assume the IT dept here at work is blocking the site through our proxy server. I didn't find a driver download on intel's site for the chipset though. Since the chipset is a few years old, its no longer supported by Intel. Do you have any other suggestions?
    Problem Solver:
  • 6 Answers
Try alternate drivers for the intel chipset install dont load the ones on the cds
Posted on May 20, 2008
Messed up the set and want to restore factory settings and start again
Try to reboot and press F8. -repair your computer- restore to factory.
Apr 03, 2015 | Computers & Internet
Hooking up a Internal Hard drive
You probably need to give more details. If it's a replacement drive, did you reinstall Windows from a CD? Did you copy from the original hd? It's simple enough to remove the two cables from the original drive, physically remove and replace the drive, and hook up the new drive. But then you'd need to boot to a Windows CD in the CD/DVD player to format and install Windows, if that's what you're attempting to do.
There's possibly a recovery partition on the old drive )or a recovery CD). If so, you'd connect the new drive to a second power cable, and data cable (which might not be included in the tower) :
(from http://support.gateway.com/s/Manuals/Desktops/8510406.pdf)
To restore system software from the Recovery discs:
1 Insert the Recovery disc #1 into the CD or DVD drive.
2 Restart the computer, then press and hold
R when prompted to display the restore process options. The
Options menu appears.
3 Select a restore process option:
- Press R to boot from the hard drive recovery partition
or CD. If no recovery partition is found, go to Step 4.
- Press F to format the hard drive and perform a full system
recovery, then go to Step 5.
4 Click a system restore option. For more information, see
"Restoration options" on page 5.
- Non-Destructive System Restore (Recommended)
- Full System Restore (Destructive)
- Full System Restore (with Backup) (Advanced Option)
5 Follow the on-screen instructions to complete the system
software restoration process.
Oct 29, 2013 | eMachines ET183105 PC Desktop
How to restore toshiba l300 to factory setting
Just before the computer boots, press F8, this will give you a sub menu and allow you to restore your computer to factory setting, IF the recovery partition on drive E is still intact. If it isn't, use the two DVDs that you made when you first aquired the laptop. Place them in the DVD drive one then two to restore settings.
If you haven't got those either, purchase a Vista or Win 7 OS disc and boot from that choosing replace system when prompted. Afterwards go to toshiba.com and download the required updated drivers.
Hope that helps.
Jan 27, 2011 | Computers & Internet
Bootmgr is missing
Run a Chkdsk:
Take the Windows XP disk. Boot from it, then DO NOT select F2 (automated system recovery) but continue through the procedure until you get to the point where you can choose between installing Windows XP and entering the Recovery Console. Once you get into the Recovery Console, do chkdsk and fix potential errors on your disks! Chkdsk C: /R
OR:
Perform an XP repair:
When you boot with the Win XP install CD-ROM, it loads a minimal operating system, similar to DOS, but compatible with Win XP. At the first screen you select install Win XP (not Recovery Console) and at the next screen it will find that you already have Win XP and offer to attempt a repair. This repair should not touch your Applications or data; it just reinstalls the Windows files. This is great because when it works you don't need to reinstall all your software.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 07, 2009 | Gateway MT3705 Notebook
How can I make my machine do a destructive system recovery?
Just use the XP home disk and any drivers that you need either get the from Gateways website or download everest (lavalys.com) and get them thru that...
let me know...
Matt
Jan 21, 2009 | Gateway GT5056 PC Desktop
System Restore (Destructive) GM5084 Gateway Media Center w/ XP
what operating system disk do you have? xp, xp pro, vista?
Dec 26, 2008 | Gateway GM5084 PC Desktop
Can't reformat hard drive
If recovery is not possible by using recovery cd; you have to depend on a full version XP cd -- either for repair or new installation.
Dec 17, 2008 | Gateway GT5014 PC Desktop
Can't extract files on System Recovery Disc 4 for Compaq Presario model 6350US
At this point, you can try to clean your disk # 4 and see what happen,
or try to make a copy of disk # 4 (if you can copy the disk) and try again.
or
1) Contact your customer support and ask for a new set of disks.(or only # 4)
or
2) Boot your computer with another OS disk (win XP)
or
3) Boot your computer with some utility disk
Oct 19, 2008 | Gateway MX6421 Notebook
Gateway 507GR PC Desktop Logo
597 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
