Question about LG LRFD22850 Bottom Freezer Refrigerator French Door
Ice maker not working
After the doors were left open for a few hours, we removed the ice box and dumped the partially melted ice down the drain. We then turned the ice maker off and then back on different times to wait 12 -24 hours for ice to be made. No luck. Further, the arm that we're not supposed to touch seems 'frozen' in the up position and we don't know how to get it down without touching (and possibly breaking).
  • mmgorney May 12, 2009
    I tried this, pressing and holding a button that is for the "size" of cube, it seemed to make a noise, hope it was resetting. Will let you know.
What button?
Posted on Aug 14, 2008
    Champion:
  • 210 Answers
If you press and hold the button on the ice maker for seconds it will go into test mode and do a complete cycle. Try this and it should correct the problem. If you think the arm is frozen, you could use a hair dryer on it for a couple of minutes then do the test.
Sgt 48
Posted on Jun 03, 2008
2 Suggested Answers
  • 210 Answers
SOURCE: Ice maker not producing ice
What you can try to do is put the ice maker in test mode. Press and hold the ice size button, on the ice maker itself, for 5 seconds. It should cycle through and this could reset it.
Sgt 48
Posted on May 31, 2008
Whirlpool ice maker quit.
If it's similar to my Samsung, mine did the same. There is a reset button at the front of the box which contains the ice cube tray. If you press it, the ice tray rotates to dump the cubes, then refills. Hope this helps.
Sep 03, 2017 | Whirlpool Refrigerators
Manitowok ID0452A-161 water not draining one water tray is filled causing water to over flow into ice bin melting ice. Need to know where the float switch is and dump valve solenoid. FOR TROUBLESHOOTING
Remove side panel on left. Dump valve and drain hose usually blocked with silt, but may be dump valve coil open circuit. No float switch, water level sensor above tray.
Mar 04, 2014 | Manitowoc ID0452A-161 Dice Cube Air Cooled...
Freezer not freezing
Red light on for High Freezer Temperature Warning
or freezer not cooling, but fridge is and a lot of noise from compressor.
Also, fridge drain hole blocked, water in bottom of fridge.
This is a common fault in Hotpoint Fridge Freezers and can also happen if the door has been left open or has been a power cut.
1. Turn off fridge freezer, or at least turn down the freezer temp to minimum, though not ideal.
2. Open freezer door and remove all drawers.
3. Remove the back panel on the inside of the freezer. This is held in place with 4 screws, which might be 6mm hex head or star allen head. Pull the panel out.
4. Behind where the panel was, there is a cooling element for cooling, pipes, and below this a temperature sensor. If the fridge freezer is not switched off, then fold together a few layers of tinfoil and wrap around the sensor.
5. Use a hairdryer to slowly melt the ice. Melt it around areas where it appears to be hanging on, such as the corners of the cooling element or bolts, as well as any thin sections below the main block of ice around the cooling element, which will be supporting the main block. Use a plastic ice scraper to remove ice but not near pipes or sensor.
Warning: Be careful using electrics around water & melting ice & drips.
6. Below the cooling element, there is a drip channel & drain hole. If this hole is full of ice, pour a small amound of warm water down, leave for 10 seconds and pour a bit more until clear.
In the fridge, clear the drain hole in the same way.
Warning: Do not pour a lot of water down, as this water drains onto a tray above the hot compressor at the rear of the fridge freezer to be evaporated by the heat of the compressor and the tray will only hold a small amount.
7. When all ice is removed, dry all moisture. Put the shelves back. Close door. Turn on fridge freezer. Turn up the freezer temperature to your normal setting. Turn on fast freeze if available. After 1 hour, check with a thermometer. It should be cold enough after 1 or 2 hours.
Oct 30, 2013 | LG LFX25971ST Bottom Freezer French Door...
Freezer is all frozen
One solution:
This can happen if door has been left open. To solve:
Oct 28, 2013 | Samsung RF265AA Bottom Freezer French Door...
Hotpoint FZ175G red warning light comes on freezer still freezing after reset light comes on again after a couple of hours
Sep 17, 2013 | Freezers
Fridgidaire freezer warming up
Sep 09, 2013 | Freezers
Freezer compressor is short cycling
Sep 06, 2013 | Electrolux Refrigerators
Warning light
Aug 04, 2013 | Bosch Classixx KGV28323 Bottom Freezer...
I keep getting water at the bottom of the fridge, under salad boxes on my Hotpoint fridge
Jul 03, 2012 | Hotpoint-Ariston HS3022VL Refrigerator
Where is the reset on my refidgerator wont get cold enough kid left it open
May 09, 2012 | Hotpoint-Ariston HSS25GFT Side by Side...
LG LRFD22850 Bottom Freezer Refrigerator French Door Logo
242 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
