Question about Proscan PS32500 32" TV
ProScan PS35160 - channel will not change
Cannot change channel. TV is stuck on same channel and will not advance via remote control or by manual selection with button on TV face. Picture is fine. Also, the Menu will not display but volume control works.
Can tuner be replaced? Not ready for new TV.
  • nochannels4m Jun 08, 2008
    32 in proscan cable on this tv only gets 12 channels. why cant i program all the channels?
  • Anonymous Mar 06, 2009
    I can't get past the first set up question
5 Suggested Answers
techman
  • 3130 Answers
SOURCE: Proscan PS35123-horizontal line only,sound ok
You have whats called a verticle swep falure. Its probably just the verticle output IC but if you dont know much about soldering or circuit troubleshooting ,you should leave this to the pros. Theres way to much Hi voltage inside these sets to twiddle around inside them. Also there are no consumer serviceable parts inside these sets as well, as they are all solid state, and my advice is spend a few bucks and get a pro to do this job for ya, as it can, and will, kill ya if your not careful.. Is it worth saving a few bucks??? Naawww Call a pro.. Good Luck
Posted on Jun 13, 2006
jomaru
  • 337 Answers
SOURCE: Cannot access menu
The tv has lost the menu,in order for the menu to come up in the screen it needs horizontal and vertical sync,the syncs come from the secondary of the flyback and from the vertical Ic.Is rare but We have seen it happen,sometimes you also have an Ic called character generator and it could be bad.You will need the assitance of a servicer for this problem because there are voltages to measure and signal to trace.
Posted on Oct 02, 2006
Noggin
  • 944 Answers
SOURCE: Lost the manual. Can't re-program remote control. Need step-by-step
http://www.rca.com/documents/15128800_201059_25.pdf Hope this helps :)
Posted on Apr 08, 2007
BMW Rider
  • 232 Answers
SOURCE: proscan ps35160 powers off
Hi, thank you for posting make and model number, I`m afraid it`s all bad news for your set, the flyback transformer is getting ready to fail and because of the age of the set it is no longer available from RCA, heres the part number " 227318 " you can try calling some of your local shops to see if they have one sitting on the shelf but I wouldn`t hold my breath, sorry to give you bad news, if you have any questions feel free to e-mail me back, BMW Rider
Posted on Jan 05, 2008
  • 47 Answers
SOURCE: 32" proscan dual hd tv can't get universal or direct tv remote to work what now
Get a universal from big box and program. If you can find a rca remote, it should be programmed already.
Craig www.classtorations.com
Posted on Jun 08, 2008
Proscan tv input without remote
Without its remote control, you can't select the inputs. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" view, will make surf easier.
http://electrohelponline.blogspot.com/
Apr 03, 2014 | Durabrand DWT1905 TV
Connected DVD player to Sanyo DS27930 TV via input
According the manual for this TV the remote control has an input button, it is left of the power button. Make sure that the remote mode slected for TV not VCR or DVD and press input button to make a selction, make sure that the power to the DVD player is on. If yours is different try stepping through the channels buttons, some TVs input is selected through the channel buttons.
Jan 02, 2010 | Sanyo DS27930 27" TV
No input instrucs for wii setup combo, no remote
Tune it to channel 90 - S-video, 91 - input 1 or 92 - input 2.
tom
Dec 28, 2008 | Proscan PS27108 TV
My tv is stuck on a channel
You have a problem with a internal circuit.you can try by, powering off the tv for about one day. then turn it on again
Dec 15, 2008 | Proscan PS32125 32" TV
PROSCAN PS35130
I got an old (1995) 36" proscan without a manual, and it's been a pain to get it working. Nice enough TV once you do, though.
The weirdest thing is that S-video shows on channel 91, and the AutoProgram function won't find it. That's right; they just randomly picked 91, and you're stuck with it.
Pressing Menu on the front brings up the menu. Pressing it again cycles through choices, and the plus and minus buttons to the left of it activate the choices.
Good luck finding any more info; hope this helps
Sep 04, 2008 | Proscan PS36500 36" TV
Remote control problems
Feed cable signal directly to tv(no BOX) activate auto-program for channel memory.
Oct 02, 2007 | Toshiba 20AF44 20" TV
Apr 08, 2007 | Proscan PS35660 TV
Proscan PS32500 32" TV Logo
142 people viewed this question
Top Proscan Televison & Video Experts
matt martin
matt martin
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
