Question about Actiontec GT704WG Wireless Router (gs583ad3-01)
Dropping wireless connection
Just installed Verizon fios TV and broadband. The broadband has never worked properly. The router is dropping the connection even though everything looks like I am connected and working ok. I have changed the settings from automatic to channel 11, but that did not solve the problem.
When I had Verizon broadband before, I had a d-link router and never had a problem, but this actiontec router is a real loser. I would appreciate any suggestions from anyone.
Glad that I am on a mont-to-month, because I am cancelling soon.
Wayne
  • gi93010 Jul 27, 2008
    I constantly get dropped connection. Verizon has had me change phone & ethernet cords, moved to a different phone jack. The problemstill persists.
    Never know if I can make or even stay connected.
The problem may not be with your router. I had a situation a year ago with the modem dropping the signal everyday. I spent hours on the phone with verizon tech support to no avail. They sent someone out to my home and he put a filter on the main line coming into the house which didn't resolve the issue. Then verizon insisted the modem was bad so they sent me an actiontec. Turns out that the problem had nothing to do with me. They try to squeeze as much bandwith at their switching stations as they can. They switched me over to another hub and viola no more problem.
Posted on Aug 17, 2008
    Champion:
  • 221 Answers
The service is AMAZING from the FIOS. I would dump the actiontec router, and use a d-link or linksys. Verizon will be able to help you set it up
Posted on Aug 06, 2008
Can I use Belkin 802.11g Wireless G Range Extender with virgin broadband?
This is a highly technical question. The technician that installs your fios can help you with an answer. If i'm not mistaken your new fios will come with a special router designed to change the data your recieving to acceptable format and communicate with your other devices. As I stated the tech who installs your fios can further instruct you as to the exact configuration. Hope this helps.
Sep 02, 2012 | Computers & Internet
Can't get on line with my Linksys wireless router
you can daisy chain ..but you will need an eithernet run from the fios router to the linksys...
Jun 25, 2010 | Linksys Wireless-G WRT54G Router
Westell A90-9100EM wireless router cant make it work
Hello angiegall366,
The Westell A90-9100EM wireless router should be able to connect to the Motorola 2210. Follow the instructions in the Motorola 2210 User guide:
http://broadband.motorola.com/consumers/products/2210-02/downloads/2210-02-10na-usermanual.pdf
If this solution is helpful please click a thumbs-up rating below.
Have a great day,
martyshaw152
Feb 02, 2010 | Computers & Internet
Dkt-410 wireless router keeps dropping connection
Make sure that your computer works properly when connected directly to the modem without the router.
If that is working properly and not dropping the connection then the Internet service is working.
If it is dropping, then you will need to check the modem or call ISP.
If your computer works properly when connected directly to the modem then you will need to check the settings of the router. I think you will need to upgrade the Firmware of the router.
For this you will need to connect a computer to the router and open the set up page of the router. After upgrading the firmware, you will need to reset and reconfigure the router.
Click here
for more information about the routers and networks
Jan 31, 2010 | D-Link (DI-711) Router
I suspect that Verizon is degrading service to forcr users to mig
Anything is possible but it would take a lot of work to jam wireless signals. As a communications company, Verizon, if caught would be in hot water with the FCC. I have an idea. Are you able to change channels on your wireless and try it. Also, is there anyway you could try a different wireless router? If FIOS is coming in, there may be maintenance changes in the infrastructure that effect your internet performance.
Aug 14, 2009 | Westell Wirespeed VersaLink...
Cannot Network printers on FIOS system
If both computers are connected to the router. Try turning off the firewall on both computers first. normally its firewalls blocking file and printer sharing that block the connection.
Mar 07, 2009 | Westell Wirespeed VersaLink...
I have Verizon Fios install in my home. I use to have Comcast. This is the situation, before the Fios my linksys wireless router was connected directly to a modem. Now my linksys wireless router is...
Your IP address for you linksys router needs to be changed.  More than likely there using the same IP address such as 192.168.0.1.
You have to convert your linksys router to a switch and change the IP address range it uses to on that doesn't conflict with the Verizon router.
10.150.1.1 should work.
Oct 08, 2008 | Computers & Internet
The battle: Acer Vs. Verizon FiOS
Verizon needs to apply a firmware update for the Atheros wireless adapter in your notebook. I work for Acer and I end up having to tell people this all day long. If you take this to a wireless router that is not from verizon you will have no problems with your connection. Maybe if enough Fios customers complain they will provide a firmware update for this.
Mar 06, 2008 | Computers & Internet
Actiontec GT704WG Wireless Router (gs583ad3-01) Logo
366 people viewed this question
Top Actiontec Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you an Actiontec Computer and Internet Expert? Answer questions, earn points and help others
