Question about Kenmore 4292x Front Load Washer
Kenmore Elite Model 45992
Leaking water slowly into washer. Has been consistant for two or three days now. Usually a gallon or so of water in drum in the mornings. Turned off water valves today. How can we fix this ourselves?
  • suimard Jul 11, 2008
    Water slowly leaks into tub when the washer is off. I have to turn of supply in order to stop leak. What causes this and what part do I need to replace. Full model number is 110.42926 202
  • robertskb Jul 24, 2008
    Same as posted above.
    I have a HE3 #45872 dripping water from fill tube. Looks like I need a part# for a water inlet valve.
    Thanks in advance!
  • 5,911 Answers
This is usually an indication of a defective water inlet valve (also known as a fill valve or mixing valve). This is a fairly simple repair that you can perform yourself. If you can post back with your complete model number (located around the door opening), I can track down a part number for you.
Posted on May 22, 2008
Our Kenmore Elite 45992 is making a loud squeaking sound when it spins clothes. We've checked the belt and shocks and they are okay. Any ideas?
Had same problem mine was the yoke thatheld inner drum tobearing was broken. Lucky it was covered by Sears warrenty. Over $1,000 to repair without warrenty..
Sep 30, 2012 | Kenmore Elite Washing Machines
Code LOC
Take three screws out of bottom panel have something to catch water and loosen two inch plug on bottom right slowly and catch about four gallons of water then clean change and whatever else is in compartment
May 01, 2012 | Kenmore Elite 45986 Front Load Washer
Kenmore washer 110.44832200 When machine is setting, water slowly fills to door level in 2 or three days. Any idea on solution?
If it is filling up with water when the machine is not on, it sounds like the water inlet valve is leaking. Normally no water should enter the machine if it is not running. It is a relatively easy repair. Just remove the hoses from the back, remove the back panel and it the part where the hoses attach. You can get a replacement part from your local appliance supply house or online such as www.repairclinic.com. Hope this helps you.
Feb 12, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite filling w/ Water when not running
your water inlet valve on the back where the water supply comes in is leaking. It needs replacing.
Jun 03, 2010 | Washing Machines
Kenmore Elite HE4t washer won't spin
The motor controller board is likely bad.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jan 06, 2009 | Kenmore Elite 45986 Front Load Washer
While not in operation dishwasher slowly fills up.
water valve is clogged try to turn your valve to dishwasher under sink
Nov 29, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
Water is collects in drum after a few hours after cycle is complete
no your inlet water valve is defective, youll need to repalce it, part number 8181694. in the mean time just turn off water in beween usages.
Oct 29, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he4t
really need the whole model # ?
1 pressure switch
2 flowmeter
3 CCU
4 hose
he F33 means that the CCU has not received a signal to shut off the water which would be sent by the pressure switch, the flowmeter has signaled that the tub has received 10.5 gallons the CCU then shuts off the water and pumps the water out, giving the F33 error code.
May 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Sedona Elite 3.8 Cubic Foot HE4t Washer (Front-Loading) 45089
open lower front with a starshaped bit(screwdriver) three small screws, to get to white plastic cleanout (easy to turn by hand)may have someting stuck in it. about a gallon of water is there so have two big towels ready to soak it up.
Dec 28, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore 4292x Front Load Washer Logo
143 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
