Question about Sony KP-57WS500 57" Rear Projection Television
Antenna signal disappeared--a mystery! Help
Came home to SW Florida from a trip and a weird thing hapenned I just can't get a grip on.
I have a series 2 Tivo and a Sony HD XBR. I'm new to the area so for now all I've been using is rabbit ears and the five basic channels I've been getting has been just fine.
It looks like in mid-recording of something all went blank, so no wires or anything were adjusted and, besides, I was away at the time....
anyway, here's more details:
*Obviously, the antenna is hooked into the TIVO
* I can still see previous programs recorded on the Tivo so that connection from Tivo to TV is working fine
*The Tivo looks for a signal when I unplug the antenna and doesn't when I have it plugged in, so it recognizes the antenna.
*When I plug the antenna directly into the TV it registers "no signal".
*I went out and bought new rabbit ears thinking it had to be that piece of hardware. It wasn't. Everything stayed the same.
All I can imagine now is that all the broadcast stations in the area aren't delivering signals over the airwaves! Not likely.
Help.
  • mystic100 May 20, 2008
    Thanks!
    I actually hit the thanks for trying button too soon!
    Sorry about that. after re-reading your comments I just went ahead and re-set the TIVO and that did it.
    The TV still doesn't pick up a signal directly, however, but at least it works now through Tivo.
    Thanks again
    Mystic 100
  • 3,037 Answers
Well if multiple devices are unable to find a signal, then I would definitely try calling the broadcasting stations and see if anything happened at that time when you lost the signal. Since it was during a show you should be able to narrow down the time easily enough. An antenna is so basic that it really shouldn't ever have problems, you could use a wire or coathanger and get a tv signal. If you have a second tv or a friend who can bring one over and test it with the antenna, then that will further narrow it down to which I believe the stations are out. We had a station out for 3 days up here once but the rest still worked. I've never heard of anything like this before. I could understand if one device can't find the signal. Stations don't always realize they aren't broadcasting until someone calls in. It wouldn't hurt anyway and I would be very interested to find out what is wrong once you get it working. The only other possibility is that you had a powersurge while you were gone or a power outage. Try resetting all devices by unplugging them (the tv for 8 hours). Also, did the Tivo continue to record when the signal was lost or does it seem like it was shut off, that would be a big indicator of what happened. Please update me on this, thanks and good luck
Posted on May 20, 2008
  • Benjamin Patri
    Benjamin Patri May 20, 2008
    yeah, if you reset the tv by leaving unplugged over night maybe it will start working on its own too, let me know how this goes
Using hdtv antenna (not cable) but get no signal when scanning channels on my Insignia 19 inch tv
You may be using the wrong type of antenna. Apparently there is a lot of mystery and fiction in the advertisement of these antennas. Read this article and see if it doesn't clear up some issues for you.
Sep 09, 2014 | Televison & Video
Nothing but static on all bands
There may be interferences from electrical appliances fridges, TV. Move the radio to some other place. For AM rotate the radio to get the best signal. For FM and SW deploy the telescopic antenna. For SW you may use an external antenna. For SW, to tune in on a station you need to know the broadcast time and the frequency.
Dec 12, 2013 | Sony ICF-SW77 AM/FM/SW Radio
Won't connect to cable? No signal detected.
Make sure on the main menu, you have it set for cable and not air antenna.
Nov 23, 2011 | LG 42 42LK450 42 LCD TV
XM Receiver: When hooked up to the home kit it will show antenna and will not pick up a signal. When hooked into the car jack it works ok. I replaced the receiver mount about 3 weeks ago and it worked ok...
Hi Kldeaton,
If you can do it, try your car mount in the house, as long as you can supply power via the car plug (12-volts DC). If it does the same thing as the home kit, then you more than likely have an intermittent antenna connection on your home antenna.
Also, check the location of your antenna vs any obstructions, such as trees. You may have the reception worked out so that you have signal from the antenna, but it is "breaking up" from a connector or cable short or open condition. Check the coax for any chaffing also. Let me know if you need more help. Thanks.
Regards, Bill
Sep 28, 2010 | Delphi Roady XT XM Radio Receiver
Could my Terk XM antenna be bad right out of the blister pack?
Yes, it is possible, but go outside and face the SW and try it that way to make sure. If you have an unplugged or bad antenna, if will usually say "CHECK ANTENNA". Make sure you don't have a chunk of metal, or even your hand over the top of the mini antenna, or you WILL block the signal. Let me know how it works for you. good luck!
Jul 02, 2010 | Terk XM Commander Satellite Radio Receiver
My 1997 toyota 4runner mysteriously lost most of its fluid on a recent interstate trip. I filled it up with anti-freeze, drove back home 35 miles and it has not used a drop of anti-freeze. Is the...
The thermostat wouldn't use up the fluid, it may leak around it but you would notice that it would have left residue behind. You will know when the thermostat is bad it will start overheating. As for the disappearance that is a bit mysterious unless of course you did overheat the you may have lost the fluid via the reserve.
Apr 18, 2010 | 1986 Toyota 4Runner
Acquiring signal
Even with the antenna looking like it is in good shape, it still may be the problem here. Physical damage may not be present, but there could be electrical damage (power surge) or corrosion on the antenna if it is in a moist environment. A quick trip to a local stereo shop can confirm this as new antenna can be plugged in to the unit to test. Also, the problem is more evident when the antenna is mounted inside the vehicle. For best reception, it is recommended that the antenna be mounted to the exterior of the vehicle and have a clear view of the sky. Make sure that there is plenty of metal underneath the antenna and you should be fine.
Aug 01, 2008 | Sirius SIR-STRC1 Satellite Radio Receiver
Sirus radio
I had the same problem and I replaced my car antenna. That resulted in immediate signal improvement. But three months later, the same thing. So, another dot micro car antenna. Three months later, the signal went out again. The home kit worked perfectly. In my case, I bought a Sirius outdoor home antenna and replaced the standard indoor/outdoor antenna that came with the home kit. I took the home kit antenna and connected it to my S50 car kit and positioned the antenna on the front of the dash. No problems since then. Not one. Those dot antennas are horrible. I'd check that before getting a new radio.
Jan 13, 2008 | Sirius Satellite Radio S50-TK1 Satellite...
External antenna
You can get good assistance at the DX 398 Group at Yahoo! The DX 398 is the same radio as the ATS-909. It was the name used by Radio Shack when they marketed it. Here's the URL for the DX398 group: http://groups.yahoo.com/group/DX398/ They will definately welcome your questions and will likely provide some valuable answers.
Nov 15, 2007 | Sangean ATS 909 AM/FM/SW Radio
Sony KP-57WS500 57" Rear Projection Television Logo
55 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
