Computer is saying Boot from CD
The computer screen is black and it says Boot from CD
  • 813 Answers
U need to change your boot secvance form the cmos
restart your pc press F2 or Delet key to enter a cmos setup go in boot manu ther is a boot device prority otion change ther do hard disj or HDD-0
thnx using fixya
hope your problem will solve
Posted on May 20, 2008
4 Suggested Answers
knotbeerdan
  • 413 Answers
SOURCE: My computer seems to be
You have to change the boot settings in bios Follow this link and it will give you the keystrokes needed to enter bios and show how to change the order
http://whitecanyon.com/how-to-change-boot-order.php
Thanks for using fixya and please don't forget to rate the solutions
Posted on Jan 26, 2009
mdavinci
  • 20 Answers
SOURCE: my computer won't start up or get passed the boot up stage
If its the screen I am thinking, it may be because it cannot detect the Hard Driive, so no windows files to load.
- Reboot
- Enter the BIOS menu (usually F1, but think F2 on Dell;s)
- Click on the summary page, under IDE or HD can you see a label with a size e.g. HD1 800000 or does it say none - you can also see other devices from the suammry such as CD ROM ..etc Can you see all thse correctly?
- If not seeing the Hard drive you will need to remove the PC cover and check the IDE/SATA connectors are firmly in, in your harddrive and the other end to the mother board (could of come loose). If they are, there are still more things that can be don - but let us know if this is what you are experiencing first.
Posted on Mar 18, 2009
sandro_monte
  • 72 Answers
SOURCE: I turn my computer on and it just has a black
maybe you are experiencing dumping of physical memory. start your computer in safe mode, press power button then press f8 then select safe mode then try to uninstall the most latest software installed in your pc.
Posted on Oct 10, 2009
My acer desktop computer screen is black, the power says it is on but no pic, keeps cutting off, tried to back up and restore, cut off, says problem with windows and it shut off as well, HELP!
  • When the computer will not boot up, it sound like it is booting as the CPU fan is running and the lights are on. It also finds the CD ROM but it won't boot from a CD either.
  • Sometimes when you have a computer black screen on startup and the power switch light will be green and then turns to orange or amber. Everything is running.
  • Everything seems to be running but you can't see anything on the screen, not even a flashing cursor. Your black screen in Windows has occurred before the Windows logo screen:
  • 1- adapter or video card
  • 2-RAM
  • 3-and Black screen on startup with an amber flashing light
  • Not enough power getting to the motherboard.
  • A dead power supply.
  • A bent pin or shorted out USB port causing a problem.
Apr 09, 2013 | Acer AX1430-UD30P Desktop Computer With...
It keeps asking for current password i dont know it
You can remove or change the Window's User or administrator's password and privileges. You need access to a computer with Internet access to download the Hiren's Boot CD and burn it onto a CD. Then insert this CD into the laptop/computer and boot up the laptop/computer with the Hiren's CD and follow the instructions. There are very useful utilities CD and it a Linux boot CD which contains quite a lot of Utility programs including a password removal program. Click on one of these links to download HIREN'S BOOTCD :- http://www.hirensbootcd.net/ http://67.20.82.163/
Mar 22, 2013 | HP Mini 1000 Netbook
I have this problem. My computer ACER ASPIRE ONE cant log in and i dont know what i have to do. The problem says: Check cable conection..! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert...
It may be a problem with the hard disk drive. To check, try to boot to the BIOS. Turn the computer on and tap on F10 before the Acer splash screen. Once you are in the BIOS, check if there is any hard disk drive being detected by the computer. Look for any SATA device that will have a storage capacity. If it does not show such, then you have to replace the hard disk drive of your computer. Unfortunately, the data goes together with this device. It will be very expensive to retrieve it from a damaged hard disk.
If in case the hard drive is seen, then it is just an OS problem. The MBR is corrupted. To fix this issue you need to boot from the installation CD.
For XP: boot to the WinRC.
Tap on F12 on before the splash screen. You will have an option to boot from the CD. Load the WinXP CD and choose onboard or usb cd rom drive.
On the setup screen choose R to repair. The follow the prompts until you get a black screen.
On this black screen, type fixmbr then press on return. That should do it.
If it does not work, then you just need to have your Hard disk replaced.
Jul 02, 2011 | Acer Aspire One PC Notebook
My computer starts up with a black screen saying bootmgr and it was working like 2 days ago I need help fast and I dont know what to do
you need to boot your computer with your windows or recovery cd
put cd in drive restar computer press F12 select boot from cd read instuctions on screen there should be an option to fix startup
Jun 26, 2010 | Computers & Internet
After installing Vista SP2 update computer wont reboot from HDD or CD w/ vista CD
ok boot the computer and as soon as you see the black screen hit f1
or delete to enter bios go to boot menu and configure the cd-rom to be your first boot option. you can also hit f12 when you first see the black screen to enter boot menu. choose to boot from cd .
ok now install the disk and choose repair system .
Nov 13, 2009 | Dell Dimension E521 AMD Athlon 64 X2...
Acer 1360 black screen cant get start menu
If you are getting a Blue screen repeatedly and you can't start up to windows in any custom setting ( from f8 start up menu ) one way to solve the problem is to Use the restore disc or windows installation cd or dvd to install windows into the computer or perform a repair installation if a windows already exists on the computer and the setup can find it.
how to perform a repair installation
this is for xp, but its similar on 2000 and on vista.
insert your Windows XP Setup CD, and restart your computer.
1.When the Press any key to boot from CD message is displayed on your screen, press a key to start your computer from the Windows XP CD.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter boot menu or bios, it will very likely be button F12 or similar, it should say on the screen when you power on.
if it doesn't, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
after that you should be able to start from the cd and install the OS (Operating system, eg.Windows)
here's some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Repeat step 1 when you have changed the boot order.
2.Press ENTER when you see the message To setup Windows XP now, and then press ENTER displayed on the Welcome to Setup screen.
3.Do not choose the option to press R to use the Recovery Console.
4.In the Windows XP Licensing Agreement, press F8 to agree to the license agreement.
5.Make sure that your current installation of Windows XP is selected in the box, and then press R to repair Windows XP.
6.Follow the instructions on the screen to complete Setup.
7.Ones windows is working you will need the drivers for your computer, they are at the makers website, for hp and compaq. www.hp.com for acer http://support.acer-euro.com/drivers/downloads.html for all other brands go to google and write Brand drivers. Should get you to the right place. Dell is most likely www.dell.com and so on.
May 18, 2009 | Acer Aspire 1360 Notebook
Computer
Get the discs that came with your computer and boot off them. When your computer is on the dell screen when you first turn it on it will say something like "hit f3 for boot menu". You need to hit the button it specifies and select your cd drive. It will say press any key to boot from cd, and as you may have already guessed you want to hit any key. Then when a windows screen comes on you need to hit r and follow the onscreen instructions from there.
Apr 05, 2009 | Dell Dimension 8400 Desktop P4 630 3G 1GB...
My eurocom wont boot pass bio screens
Hi
few possible problems:
The hard drive is not detected or not working
Or the operating system is corrupt or missing
Or the computer is not set to boot from the hard drive.
if not then the computer is not set to start up from a cd, you can either enter the setup / bios to change that setting OR right when you power up the computer look at the screen it will say what button to press in order to enter bios thats one way to solve the problem but look for Boot menu, it will very likely be button F12 or similiar, it should say on the screen when you power on.
if it doesnt, then you need to go into the bios and change the boot order so that the computer starts from the CD first.
heres some info on how to work the bios: http://www.whitecanyon.com/how-to-change-boot-order.php
Change the boot order so its CD ROM, optionally FLoppy drive here if your laptop has one of those, then Hard drive.
save and exit the bios, use the above link to get info on how to work the bios.
Test and see if the computer starts up normally, if not then you need to use the windows installation cd to install windows into the computer again.
if you get any errors or problems on installing windows let me know.
Mar 16, 2009 | Eurocom 888es Notebook
Can't get past black screen and mouse
Power off your computer, then power on hitting F12, del or whichever key it states to go into setup. From the setup menu, select change boot order or boot menu. Set the CD ROM to the first boot device. Save changes. Restart. Your computer should boot to cd starting the installation.
Feb 06, 2009 | Dell Inspiron 1501 Notebook
Computer says disk boot failure when I turn it on.
hard drive failed or you have a cd in or floppy in the drive.
Jan 07, 2008 | Philips 170B5CB 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
