Question about HP PSC 1410 All-In-One InkJet Printer
No printing I have three documents in a waiting list and the printer doesn't work. Why? and how can I getr the out?
  • Anonymous Jun 07, 2008
    my HP PSC 1410 is not printing, incompatible with winows vista what should i do
  • adamqatar Jun 25, 2008
Click on control panel.
click on printer
click on the printer with the jam
right click over each of the documents in the jam and press delete this will cancel the operation....most likely if you only delete the top document it will solve the problem.
Turn the computer off....Turn printer off. This should clear the que.
Turn computer and printer on and you should be good to go.
Posted on Apr 23, 2009
  • 28 Answers
If you have 3 documents waiting in queue and still you cannot take it out.. follow the following steps:
• try to go to run, type services.msc then enter
• then services local page came out
• theres a list and look for print spooler
• right click and go to properties
• then click on stop and after the service will stop, clik on start again
• then go to control panel
• then go to printers
• then right click on the printer icon and cancel all documents
• then refresh or restart your printer if still the printer did not response.
Posted on Jun 12, 2008
I have 2 documents waiting to print offline. If I ask the printer to print, it just adds another document to the list. How do I print or cancel the job
Hi there
Thes instructions are based upon Windows 7.
Your best procedure would probably be to open >Devices and Printers. Then double click on your printer and amongst the selections available will be "See what's printing". Click on this and a small box with the list of documents will appear. Highlight a document and click on the Documents menu and then cancel. The document will be deleted from the list. Do this for every document in the list until the list is empty. They will be deleted more quickly if the printer is turned off while you are doing it.
Turn the computer off and disconnect from the mains, disconnect the printer from the mains. After a couple of minutes plug them back in, turn on the printer and then reboot the computer.
You should now be able to print but before you retry make sure that the computer finds the printer and labels it as "Ready" by going to >Devices and Printers again, double clicking the printer in question and checking that "Ready" is against the printer at the top of the page in the blue border, otherwise the same problem may occur.
Hope this is helpful, if so would you please register that with Fixya
Cheers
Nov 29, 2014 | Office Equipment & Supplies
Printer keeps saying busy printing another document
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Feb 10, 2012 | Lexmark X4580 InkJet Printer
Doesn't print the whole page
Try to re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
1. Disconnect the printer from your computer.
2. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
4. Reboot your pc.
5. When your pc turns on, reconnect the printer.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print a document again to verify that the problem is fixed.
Oct 21, 2011 | Lexmark All-in-One Printer with PictBridge
My Lexmark z2300 sends to the printer & it says it's printing, but it doesn't actually print. I've tried several file types & programs to print from but none of them work.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer. Reboot your pc. Unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer. Then try to print again once the computer fully recognizes the USB connection.
2. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
4. Reboot your pc.
Sep 14, 2011 | Lexmark Z2300 InkJet Printer
Print document system responds document is printing system responds that document is printed but no document is printed. Used troubleshooting for alignment and that works with printer?
4. Reboot your pc.
6. Wait until your pc fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, then try to print/scan again.
Aug 23, 2011 | Lexmark Z816 InkJet Printer
Sir my printer T13 cannot print the power is steady cannot turnoff. please help me thans
Unplug the printer and plug it back in.
Reboot your computer.
Open the list of documents waiting to be printed (double-click on your printer to get the list), right click on the first document and delete it.
May 06, 2011 | Office Equipment & Supplies
Just installed new KODAK ESP3 I find the print program page has over 74 documents to be printed how do I clear this unwante backlog
Click on your printer (Icon in the Systray) A window will open with a list of the documents waiting to be printed. Delete them. You may have to look around in the window for this feature.
If that doesnt work, delete the printer, reboot and reinstall the printer.
I hope this works for you
a
Sep 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print Job Not Listed
Is it your default printer? Whot trianglass appears standart windows notification? Try to restart computer, also if you can find print spooler is running in services? I can correct you printer with remore support if need contactme in skype suxia03
Jul 30, 2009 | Office Equipment & Supplies
Printer DeskJet 820Cse didn`t work
test page printing but doc files not printing....
HP DeskJet 6940
Sep 26, 2008 | HP Deskjet 6940 InkJet Printer
HP PSC 1410 All-In-One InkJet Printer Logo
113 people viewed this question
Seeker5211
Seeker5211
