Question about Sony VAIO VGC-RA710G PC Desktop
Power switch does not work
Hello, my power switch on the front of the case does not work on this sony. I was hoping maybe to bypass the switch. The case, being a sony, is of course nonstandard... Anyone have any experience with this?
Thanks
    Problem Solver:
  • 29 Answers
I think the wires of power switch is disconnected or not connected properly better to check it once but becareful turn off all the connection & remove the cpu cap...tc
Posted on Jun 06, 2008
I have a Toyota Highlander 2005 Limited. I have two problems on 1. the front right & both rear windows won't resp ond on there own switch but all work from the master switch on the drivers door. Fuses are...
Have you checked each individual door switch
for voltage? If there is voltage and a good ground try jumping the switch with a bypass wire to see if the window responds. It could be a bad master control switch which you can bypass to check to see if its working properly. Drivers door switch module. They are known to be a problem. Hope this helps.
Oct 16, 2013 | Cars & Trucks
How do I bypass the power switch on a Gateway DX4822-01 PC
I went through this same scenario.Motherboard,power supply, ram, Couldn't figure it out.Turns out it was the Power button itself.Put all the components in a new case an viola everything works
Feb 18, 2012 | Gateway DX482201 (PTGA002002) PC Desktop
How do you reset playstation 3
Hard Reset procedure for the PS3 (as instructed by Sony CS). Be sure to backup your settings/games saves by doing a System > Backup on your PS3 or you may lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
1. Power Off the PS3 via the power switch in back and power back on w/switch.
2. Hold Power Button on the Front until you hear 3 beeps.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn't detected after initial reset).
4. Restore your backup you made prior to doing factory/hard reset (optional, if you created a backup).
I hope this helps
Mar 26, 2011 | Sony Playstation 3 (PS3) Console
Switches on all i get is the wavey line and coloured background, nothing else.
Hi
First try the ps3 reset where you hold the start button until your hear the two beeps (about 5 seconds).
this this does not work then pleaee try the following
Please note you will lose your game saves! Also, this is a last resort procedure prior to exchanging/returning to sony.
3. Then go through the initial setup and then run a full Format via System > Format. (will take approx 3 1/1 hours). You may need to have our AV cables ready if your using HDMI (in case HDMI isn’t detected after initial reset).
Hopefully this will solve your freezing problems.
Mar 15, 2010 | Sony Playstation 3 (PS3) Console
Will not power up although there is 240V AC at the input. Power switch on the front will not work
So, maybe try 120V AC......  Or can you set it for 120vac or 240vac?  Set it to where it should be.
Jul 12, 2009 | Sony STR-DE315 Receiver
ASUSP4SD-VX Can not figure out how to configure plug for front USB panel to motherboard, when using this mothervoard in a generic case.
your motherboard only supports USB v1.1, make sure those are they type of connectors on your case, and if so, open this document and go to page 2-16 for diagram: http://dlcdnas.asus.com/pub/ASUS/mb/sock478/p4sdr-vm/e1104_p4sdr-vm.pdf
if the case only has USB v2.0 plugs, you cannot connect them.
Jun 28, 2009 | Computers & Internet
Sony vaio wireless keyboard is locked, can not type. a symbol of a lock is showing on the mini screen that has a "1" in it. Please help.
Hello Vince...don't you just hate when that happens...it drives me crazy...Try this trick i learned...maybe it will work for you too.
Power down the lappy...remove the power supply. Hold the power on button down for a good 60 seconds. Reinstall power supply and boot up. I know this will work on a Dell..HP and Acer laptop....maybe we can add Sony to the list. If it dosen't work...i have a tech. manual i can dig out and we can try again.
Good luck...i hope this helps
May 18, 2009 | Sony VAIO Wireless Keyboard Kit...
No sound
Have you got the speakers on as in the AorB speakers button? It should be located on the front of the amp.
Dec 30, 2008 | Sony STR-DE898 Receiver
Kv40xbr800 standby flashes 7 times, sony 40" Hello. I hope some 1 can help. I've a 41" rear project Sony TV ModelKP-41T65. One day it just decides not to turn on. When you turn on thepower you hear the...
7 blinks on a sony indicate that high voltage has exceeded 33K and the set is going into safety shut down. Check your Horizontal and rgulator circuits. Something in those circuits are causing the increased voltage.Hope this helps let me know if I can help you further.
Dec 02, 2007 | Sony KP-41T65 41" Rear Projection...
Sony VAIO VGC-RA710G PC Desktop Logo
89 people viewed this question
Top Sony Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Computer Links
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
