Maxtor diamondmax plus 9 6y080l0
Bios does not recognize my hard drive correctly, only recognizes the family (calypso).
it tries to boot but hangs in boot mode then it says slave hdd error,and carries on booting but only using primary, think the firmware is corrupted. can anyone help me found the firmware but not sure how to get it to the hard drive and reprogram please help thanks . SATA hard drive is recognized by Bios, but only that there is something there (will not list storage size, cylinders, etc...) Removed other hard drives and tried to install WinXP on SATA drive, windows installation came up with the "No mass storage device found" error. Any ideas?
  • 4 Answers
IDE AND SATA CONTROLLER PROBLEMS ON MAXTOR DRIVES.UNINSTALL CONTROLLERS AND REBOOT,DO NOT PLUG IDE DRIVE IN.THEN REBOOT AGAIN PLUG IDE DRIVE AND LOOK IN DEVICE MANAGER IF DRIVE IS RECOCNIZED CORRECTLY.(ASUS BOARD) OR INTEL CHIPSET PROBLEMS.
Posted on May 20, 2008
Romulus Name for Maxtro D540X
U can do one thing , convert your HDD using ide to usb or sata to usb converter and connect ur HDD via usb and check what happens....
Dec 26, 2013 | Maxtor DiamondMax D540X 40 GB Hard Drive
I have a quantum fireball lct20 40gb hard drive that I am attempting to install as a slave drive in a Dell Dimension 2400 desktop, and while it works in other computers, I keep getting the BIOS detection...
Maxtor CrystalMax 1080
Maxtor Fireball 531DX Ultra ATA 100
Maxtor DiamondMax 16
Maxtor DiamondMax 1750 Ultra ATA 33
Maxtor DiamondMax 1750A Ultra ATA
Maxtor DiamondMax 17 VL Ultra ATA 66
Maxtor DiamondMax 20 VL Ultra ATA 66
Maxtor DiamondMax 2160 Ultra ATA
Maxtor DiamondMax 2880 Ultra ATA
Maxtor DiamondMax 30 VL Ultra ATA 100
Maxtor DiamondMax 30 VL Ultra ATA 66
Maxtor DiamondMax 3400 Ultra ATA
Maxtor DiamondMax 36 ATA 66
Maxtor DiamondMax 40 ATA 66
Maxtor DiamondMax 40 VL Ultra ATA 100
Maxtor DiamondMax 4320 Ultra ATA
Maxtor DiamondMax 536DX
Maxtor DiamondMax 60 ATA 100
Maxtor DiamondMax 60 ATA 66
Maxtor DiamondMax 6800 Ultra ATA
Maxtor DiamondMax 80 ATA 100
Maxtor DiamondMax D540X-4D
Maxtor DiamondMax D540X-4G
Maxtor DiamondMax Plus 2500 Ultra ATA
Maxtor DiamondMax Plus 40 Ultra ATA 100
Maxtor DiamondMax Plus 40 Ultra ATA 66
Maxtor DiamondMax Plus 45 Ultra ATA 100
Maxtor DiamondMax Plus 5120 Ultra ATA 33
Maxtor DiamondMax Plus 5120 Ultra ATA 66
Maxtor DiamondMax Plus 60 Ultra ATA 100
Maxtor DiamondMax Plus 6800 Ultra ATA 66
Maxtor DiamondMax Ultra ATA
Maxtor DiamondMax Plus 8
Maxtor DiamondMax D540X_4K
Maxtor DiamondMax D540X_4L
Maxtor DiamondMax D740X
Maxtor Fireball 541DX
Maxtor Fireball LCT20
Quantum Fireball CR
Quantum Fireball CX
Quantum Fireball EL
Quantum Fireball EX
Quantum Fireball LCT08
Quantum Fireball LCT10
Quantum Fireball LCT15
Quantum Fireball Plus KA
Quantum Fireball Plus KX
Quantum Fireball SE
Quantum Fireball ST
Quantum Fireball LM
Quantum Fireball AS
Maxtor DiamondMax Plus 9
Maxtor DiamondMax 10
Maxtor DiamondMax 11
Feb 22, 2010 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Maxtor DiamondMax Plus 45 7200 RPM 30.7 GB HDD suddenly makes clicking sound when started and will not be recognized by Win XP OS. The drive had been working flawlessly. Any suggestions?
Clicking sounds is an indication that the platters have a bad device internally. Once that happens the hard drive is no good, run the serial# on Maxtors website to see if its still under warranty, gd lk
E
Aug 01, 2009 | Maxtor DiamondMax Plus 45 (53073H4) 30.7...
DiamondMax 21 80-GB ATA/100 Hard Drive didn't get recognized as 1st drive or 2,3. do i need any software.
Use a partition manager to see if the drive is recognized. If it is not recognized, you may not have the jumper setting correct. If it is a master drive, set the jumper for master drive. same for slave or cable select
May 05, 2009 | Maxtor Fireball 541DX (2B020H1) 20 GB Hard...
Hard drive spins up but windows does not see it
Depending on your PC make model and BIOS it may not auto recognize the second drive, check those settings. and or it might not support the drive size, in which case look for a BIOS update for your system. You also might want to use "cable select" on the switches even though you set it to slave it may not like that.
Apr 24, 2009 | Maxtor DiamondMax Plus 8 40GB 7200rpm...
Maxtor Diamondmax plus 9 HDD Error on boot up
Maxtor were taken over by seagate some time ago - try downloading and running the Seagate diagnostic tools "SeaTools"
http://www.seagate.com/gb/en/support/downloads/seatools
Jul 23, 2017 | Maxtor DiamondMax Plus 9 160 GB Hard Drive
If you have you primary HDD set on Cable select, and the secondary HDD is set on anything other then Cable select (with the jumper settings on the back of the HDD) then there will be an error.. Also, if you primary is set to master/slave and the same for the secondary, it will cause problems.
Another thought, if one of your drives is SATA and the other IDE, if the IDE is set to master, there may be an issue as SATA HDD's will try to post as the master drive
Mar 24, 2008 | Maxtor Hard Drive
Mon PC ne reconnait plus mon disque dur
I have a maxtor 40gb DiamondMax Plus 8, and suddenly, my computer only recognizes over my hard drive. I work on XP, but the hard drive is in my computer for at mons three years. Not a problem before. It is partitioned. Can I chdisk from DOS, or else. Thanks for your help.
Dacha
That is what you wrote: Check in menagment console if you found there.If not check IDE CABLE if it is put in corectlly and check electricity!
Jan 05, 2008 | Maxtor Hard Drive
Computers & Internet Logo
644 people viewed this question
David Payne
David Payne
