Question about Vacuums
Changing belts on Hoover wind tunnel U6401
I need to change the belts on Hoover Wind tunnel vac. It's the vacuum where I work, so I have no manual.
thanks for any help,
Mike
    President:
  • 1,673 Answers
Take off the bottom plate covering the brush roll, 4 screws. There are 2 belts, if you replace both, put the V belt on 1st, then stretch the flat belt over the motor shaft, then over the bigger pulley along side the V belt.
Posted on May 20, 2008
How to change a belt on a Hoover wind tunnel
It depends largely on the model. Do you know the model number? you can get any hoover replacement belt here:
Replacement Hoover Vacuum Belts
Dec 09, 2009 | Vacuums
How do you change the Hoover wind tunnel belts?
If you turn the vacuum over there will be (4) screws that hold on the base cover for the roller brush. Remove the screws and the cover and you can get to the belt(s). You can get replacement belts here:
Hoover Windtunnel Belts
Nov 18, 2009 | Hoover Company Wind Tunnel U53019 Upright...
We've changed the bag and we are still not getting good pick up. It seems to leave small paritcles and bits of fuzz.
Did you change the belt? If the belt is worn or stretched it won't pick up well. You can get replacement belts here:
Replacement Vacuum Belts
Nov 16, 2009 | Hoover Company Wind Tunnel U53019 Upright...
How to change the V belt on hoover wind tunnel U6435-900 ?
Below I have listed a link to the manual which has instructions and a link to the V belt you need.
Windtunnel Manual
Windtunnel Replacement Belts
Nov 03, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Change belts on a Hoover Power Drive Wind Tunnel Series 900 vacuum
Try calling Hoover directly toll free at
1-800-944-9200 M-F 8 AM - 7 PM EST.
Sep 08, 2009 | Hoover U6437-900 / U6439-900 Windtunnel...
Filter in Hoover Wind Tunnel Vacuum
Definitely not. Do not use water or any liquids to clean it. Te normal use life is 2-3 years keeping it maintained. You can clean it dry with the dust brush from your vac attachments. place in a plastic bag and tap it some folks even us an air compressor to blow out the impacted dirt. you will only want to use the Hoover brand, other generic brands dont fit as well.
Jan 17, 2009 | Hoover U6630-900 WindTunnel Bagless...
How to replace belt on Hoover Wind tunnel vacuum
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=831441
Generic problem for all Vacuums
Posted by dinosir on Jul 25, 2008
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. All you would need to do is to remove the bottom plate by screws, clips or levers and that will get @ the belt(s) – some Hoover WindTunnels have one and the self propelled models have 2 – you can cut off the belts or slide them off and 1st you need to hook the larger belt onto the brushroll & if you have 2 belts hoof both onto the brushroll pulley and then use a belt puller or a screwdriver with a hook on the end and pull or stretch the belt(s) onto the motor pulley and then track the belts in a straight line and replace the bottom plate and then start up your vacuum. The recommended belt change for a vacuum is every 4 to 6 months for the best cleaning. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jul 25, 2008 | Vacuums
Wind Tunnel Model: u6630900
Need a manual for Hoover Vacuum Cleaner, Wind Tunnel Model:u6630900
May 21, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and...
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=563001
posted by smithcarolj1 on May 01, 2008
I bought a Hoover Wind Tunnel in January 2008. At first it worked great though very noisy. Now it will not pick up small fuzz on medium shag carpeting. I have checked the bag, the filter, the belt, and obstructions and there are none. Plus the noise level has increased. What is wrong?
I am very dissatisfied.
Sorry you are having a problem, using the Hoover Windtunnel is a very good vacuum. Reading youre description, the belt is one of the main reasons you are not picking up the small fuzz on a medium shag carpeting. The belt change on the average , if you have one or 2 belts should be changed every 4 to 6 months as a rule, and the brushes need to be in good shape as well, if those two are working well you may have a bad seal on the motor or a broken fan blade(s) and that would decrease suction and you would need to replace the fan. Also check the gaskets if they are broken or damaged or pinched and letting air through the suction will leak out. These are some of the items to check for, so feel free to contact your local vac dealer. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
8 a.m. - 7 p.m. EST
Thanks, Don The Vac Man
Go Ahead. Use Us.
May 01, 2008 | Vacuums
Vacuums Logo
352 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
