Question about Insignia Computers & Internet
Need Backup Disk for PC. - Insignia Computers & Internet
  • Insignia Master
  • 13,433 Answers
Hello, you can buy DVD disc from local shops and backup your images and other files on them.
If thats not it please clarify your problem.
Posted on May 22, 2008
Restore recovery disk
Hi Billy,
depends on what you mean by restore. Assuming you have windows installed, you can make a back-up by going to START > Control Panel > System and Security > Create a backup
(the path above may be a bit off from the wording, the PC I am on at the moment is not an english version.)
Then on the left side there is a link to create a recovery disk or create a backup. the recovery disk option only makes a bootable disk to start your computer if your windows cannot start. This only gives you an enviroment where you can try to fix windows or to restore a backup that you created beforehand with the second option above.
If you create a backup, there are two things to keep in mind... what type of data do you want to back up and how often. You can put check marks on all data that you want to backup (Note: the more data you backup the larger your backup file will be). If you plan on restoring a corrupt windows with the backup you should include "System State".
Restoring from a backup file a.k.a. backup image will ONLY give you back the files that were on your computer at the time you made the backup... that means everything that you created after you made the backup will be lost.
Hope that helps.
May 16, 2014 | Dell XPS 200 PC Desktop
Harddisk not showing on pc
is the disk backup or in the pc internal hard-disk if external no need software download just get another pc or use recovery software to get your data from it and then format and re backup your data
Jun 27, 2017 | Buffalo Technology DriveStation HD-HC500U2...
Need a new hard drive but have no windows vista disk
You don't.
Do you have backup software? If so, do a "disk and partition" backup. This essentially creates an image of your system, even if you have multiple hard disks. Decent backup software (I won't mention any brands except the one I use: Acronis) will allow for a boot time recovery of your entire system, either by inserting a post-bios command -- which will appear on your screen before windows startup with a message like "Press F12 for system recovery", or you should press whatever key your system allows for boot order and boot from the recovery disk you can create from the software.
You can even now immediately create a Windows backup to an appropriately sized USB mounted disk (even the terabyte ones are relatively cheap) and a Windows Recovery Disk...the recovery disk should be inserted and use boot order F-key...good luck
Dec 28, 2013 | Gateway DX4200-09 PC Desktop
Do pc run slow due to hard disk fail
If you have hard disk problems then this can cause many other problems on your computer, including impacting on performance due to the resources which are used in handling and trying to correct the disk problems.
I would strongly recommend that you make a full backup of your computer while it is still working and before the hard disk fails completely.
If you are using Windows 7 then you can do this using the Windows Backup process to make a System Image backup which can then be used to recover your system provided the image is written to either an external USB hard drive or to DVD discs.
If you have a different version of Windows, then you should try using one of the free Backup programs such as Easeus Todo Backup or Paragon Backup & Recovery Free - the links for these are below:
http://www.todo-backup.com/
http://www.paragon-software.com/free/
If you want to replace the failing hard disk yourself (after you have made a full backup as advised above) then see the Dell Inspiron 580 Service Manual for details on how to do this.
Jan 06, 2012 | Dell Inspiron 580 Desktop Computer (Intel...
How do I format a cd disk for back-up?
You should not need to format a CD disk when doing a backup, the backup software that you are using should require a blank (aka unformatted) CD to be inserted and will do any formatting necessary when writing the backup data to the CD disk(s).
Jan 01, 2012 | Microsoft Windows XP Professional for PC
Recover data from my backup
Which operating system and what data do you need to recover ???
You can create a backup disk with Microsoft Windows 7 or any other version of the operating system.
This disk will contain the files, programs and settings that you chose to save during the backup operation.
Yet, this disk does little good for you if you do not know how to retrieve that backup data.
Luckily, Microsoft offers a simple process for restoring this data to your operating system.
Even a basic computer user should have no problem restoring her backed up data from a backup disk.
Insert your Windows 7 installation DVD into your optical drive.
Reboot your computer and press a key to boot from the disk once prompted.
Click "Repair your computer."
Choose the hard drive that contains your copy of Windows 7.
Click "Windows complete PC restore."
The latest backup data will be selected by default. I
n the event you wish to restore earlier backup data, press "restore from a different backup."
Click "Next."
Your computer will now restore the backup data into Microsoft Windows 7.
Sep 27, 2011 | Gateway 506GR PC Desktop
How to create backup disk in a netbook
  • In Control Panel, click System and Security (System and Security), and then click Backup and Restore (Backup and Restore).
  • In the left pane, click Create a system recovery disk (Create a system recovery disc);
  • Insert a blank CD in the DVD, and then click Create Disk (Create Disc).
  • The disc is created is a few seconds:
Jul 03, 2011 | Microsoft Windows 7 Ultimate for PC
Where can i get a backup disk and windows vista disk from
you can get a vista disk on ebay or a site called digitalsunrise.ltd ....i think you should have backed up your pc first before you can use a backup disk not sure about that as far as i know a back up is a disk with your files written to a cd or dvd that you have done through backup and restore on your control panel..hope this helps best of luck
Aug 06, 2010 | Sony VAIO PCV-W600G PC Desktop
Need operating software for Acer Aspire M1610
http://support.acer.com/ look up tech support call them and let them know that you lost your restore disk and they will mail you a copy.
Oct 26, 2009 | Acer Aspire 1640Z Notebook
Error 507
Hi
The Error 507 is generally a result of an I/O problem with the target device.
Some possible causes of this error are:
  • Target device is full.
  • a "bad spot" on a CD-RW disk (possibly cured with a reformat).
  • a loss of connection on a network disk (especially with wireless networks).
  • a firewall blocking access to a networked backup device
  • out of date driver software for a CD writer.
  • hardware problems with the a disk, disk controller or network.
The error will also occur if attempting to save a backup file greater than 4gb on a disk formatted with the FAT32 file system. You must use the NTFS disk format if files are larger than 4gb. Alternately, all of our backup programs allow you to save the backup file in smaller 'chunks' to avoid the 4gb limit of FAT32.
Feb 26, 2008 | Encore Easy PC Backup (24105) for PC
Computers & Internet Logo
18 people viewed this question
Top Insignia Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Carlos L. Burgos
Carlos L. Burgos
Martin Clarke
Martin Clarke
Are you an Insignia Computer and Internet Expert? Answer questions, earn points and help others
