Question about Kitchen Ranges
Kitchen aid gas oven m.kgsa906pss00
After self cleanig my display has no light (noting) and the dor is lucked i reseted circut brakers and nothing happened
  • 1 more comment
  • Anonymous Nov 19, 2008
    You need to replace the thermal fuse on the bacl of the oven. This oven sucks!
  • joerugg Jan 28, 2009
    my stove just did the same thing
  • dre0652 Apr 05, 2009
    After starting the Self Cleaning mode the Display went blank and the Oven Door stayed locked. The Burner Igniters still work on the Stove Top and I tried reseting the power to the unit but this did not fix the problem.
What ssolves this problem is an air flow kit. Part # 8191178. The company realized too late that there was a blockage problem underneath the over and that it would blow the stat. The insulation around the door also has to come out. Do not do this yourself but have someone who has done it before. The company knows about it so your guy can call them but tell them to be persistent. Not all of the engineers are as knowledgeable as others, at least according to my fabulous service guy.
Posted on Jan 09, 2010
You will need to replace the thermostat fuse.... this is a known problem with this KA model, but they refuse to acknowledge it. You'll need to unplug the unit, remove the back panel on the oven and replace the fuse. It's part number 8300802 and will run you about $60-70. Here is a picture of the fuse: [IMG]http://i114.photobucket.com/albums/n256/Olivia-Bolivia/IMG_9737.jpg[/IMG]
Posted on Apr 29, 2010
Why is oven door locked after self-cleaning mode?
How To Fix Oven Door That Doesn't Open After Self Clean ...
www.partselect.com/...Stove-Oven/Door-Will-Not-Open-After-Self-Clea...
How To Fix An Oven Door That Won't Open After A Self Clean Cycle ... This may reset the control and allow you to unlock the door. If you still cannot unlock the .
Repair - Dead oven after self clean mode, blank display ...
? 9:38
https://www.youtube.com/watch?v=UylZKwzAPow
Feb 22, 2014 - Uploaded by Random Repair
Repair - Dead oven after self clean mode, blank display, locked door Kitchen Aid Whirlpool How to repair an ...
Nov 26, 2015 | Kenmore Kitchen Ranges
Oven door won't close
You should not have been able t force the oven open when in self cleaning mode since u did I am sure that you have damaged the locking mechanism and the solenoid lock inside the top of the oven that sets the lock when doing self cleaning.
this is not a huge problem but it needs to be fixed most likely not by u call an appliance rpair shop in your area and it should cost no more than $150 to fix
Feb 12, 2018 | KitchenAid KGSS907SSS Gas Kitchen Range
My Kitchen Aid stove KGSA906PSS00 has had multiple problems. Had relatives here who spilled lots of water on top. Since then my oven will not heat past 260 degrees F. Stays in preheating mode and will
The water has damaged the control board which will need to be replaced. Here is the part to order. Here is a diagram of the the unit. The board is number 33.
The part comes with a 365 day, any part, any reason return policy.
Nov 20, 2012 | Kitchen Ranges
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Aid Gas Range Architect Series II-self cleaned the oven; it is done the oven is cold but the door is locked and nothing works on the control panel.
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
Self Cleaning Oven Problem
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 25, 2010 | KitchenAid Kitchen Ranges
Kitchen aid oven blackout after using self clean. Waiting for repair. $100.00 service call. $ 70 part fee. From what I read on the internet this will just happen again. Anyone know of a way to solve this...
this is probably the thermal fuse replacement fix (see my other posts for easy replacement directions)..
i'm sure kitchen aid wont recommend this but if you slip a thin piece of cardboard or non combustable insulation material between your replacement thermal fuse and the oven wall, you may not have the problem again..
good luck
tpug
p.s. i'm trying to source an auto-resetting thermal fuse for this application... if i find one, i'll post knowledge for everyone..
Jul 15, 2009 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen Aid Double Convection Oven stopped during Self Cleaning
same thing happened to me yesterday took all day to figure it out was the themal fuse on the back of the oven the part number for my kitchen aid is 8300802 if you want the doors to unlock and reset the display you can take the leads off the fuse touch them together and the door will unlock however it is best to change the part took me 5 minutes once i knew what to look for
you have to remove the back panel and you will see the part with the number on it cost me 50 dollars but better than the 8o bucks to have a sevice guy come and do it next time i self clean i will pull the stove away from the wall to help keep it from ver heating
Feb 01, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
Kitchenaid KGSA906PSS00
I recently encountered this issue after trying "self clean" on my KitchenAid oven for the first time. I wish I had read these forums and simply avoided the feature. KitchenAid was, of course, completely unhelpful since my warranty was expired. This is the first they've heard of the problem; perhaps search engines are prohibited within the KitchenAid community and they are unable to view the complaints of thousands of other customers as I have... but I digress.
The solution was straight forward: Don't worry about the locked door for now and pull the oven away from the wall. Safety first: unplug your oven and turn off your gas valve. Now remove the back panel. There is a sheet metal strip near the top of the oven that must be removed before the back panel comes loose. With the back panel removed, look for a circular device with a blue and white sticker on it and the part number: 8300802. This is a thermal fuse that blows when the oven gets too hot (apparently "too hot" is a subjective measure as normal operation during self clean will cause this issue). You can check it with a multimeter if you have one... a failed fuse will have a high resistance. To ensure this is your only issue and to immediately unlock your door, adventurous types can bypass the fuse by connecting the two wires that connect to the fuse and hold them together with some electrical tape. WARNING: never operate your oven in this manner. This is a quick test to verify resolution of the issue; not a permanent fix. Apply power to your oven and presto, your door will unlock and your front panel will illuminate.
Now, use the aforementioned search engine KitchenAid has never heard of and search for your new fuse: 8300802. I got mine for $34... you can probably find it for cheaper but my patience was wearing thin by the time I got to ordering a replacement part.
Oh, and one last step: never ever under any circumstances use the self clean feature. Do not take the easy route like I did: get your Brillo Pad and your Easy-Off and get dirty, you lazy bum.
Dec 05, 2007 | KitchenAid KGRT607 Gas Kitchen Range
VDSC365-6B
a part of your latch assembly is malfunctioning.check this along with your oven sensor.
Jun 18, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Kitchen Ranges Logo
378 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
