Acoustic solution lcd tv
Ive had this tv in my front room for 4 months with no problems, i have moved it from the front room and put it on my wall in my bedroom and for some reason the sound is fine and you can see the picture but its mainly green with no other colour in it, the only thing ive used different is the power lead which is off a plasma not an lcd, would this make a difference
  • jackie1969 May 23, 2008
    this helped very much thank you
  • 4,234 Answers
This sounds like the unit is expecting component video input (RGB) rather than composite (yel). Check the settings on the set. The power cord makes no difference.
Keep us posted.
Posted on May 20, 2008
No coaxial connected to my wall plate
change wall plate connection must be busted
Feb 27, 2015 | Cables To Go Televison & Video
Bcoiradas@aol.comhi ibe got some blue little blobs appering on the screem and some little lines coming from them . please help ive got a samsung le40m87bdx
Hi, A lot of these LCD screens have the same problem (strip of white,blue,red) lights on the screen.
Try this move the TV to another room to rule out any interference. Check all connections on back.
Good luck.
Aug 04, 2011 | Samsung LE40B553 40 LCD TV
Not sure if anyone has come across this problem before. I have had 3 tv's in my son's room and all 3 different models including old one alba 19 inch lcd and another all just stopped working....
jotvguy just wondering, is there definitely power in these outlets ? Have you tried a lamp or something else to prove you have power at the wall outlet?
Jul 11, 2011 | Televison & Video
How to install a home theater
Follow these steps:
•Plan out your setup. Before you start unpacking speakers and moving furniture, it's a good idea to have a placement scheme in mind.
Consider the location of the outlets in your home theatre room. If possible, choose a room powered by a single circuit breaker to reduce the risk of damage due to the overload your home theatre system might cause. Supplement the number of outlets with power strips.
Place your TV. The television should be placed where it can be viewed straight on. The center of the screen should be aligned with the eyes of a seated person.
Place your speakers before you start hooking things up. If there are hearing-imparied people in your household, place the speakers so that someone could sit directly next to at least one speaker.
Position your central channel speaker above or below your TV. If you put it on top of your TV, make sure the front edge of the speaker is aligned evenly with the front of your TV screen.
Place your front left and right speakers at equal distances on either side of your TV. The height of your left and right speakers should match the height of your central channel speaker.
Put your surround speakers at equal distances to the left and right of where you would normally sit and view your TV. Do not point your surround speakers directly at your viewing position. Try pointing them toward the back of the room or toward the ceiling.
Place your subwoofer to the side of the room, about halfway between your viewing position and your TV. You can adjust the bass reaction of your subwoofer by moving it closer to a wall to increase the bass, or by moving it away from a wall to decrease it.
Connect your speakers and theater system by running flat speaker cables down the length of your baseboard or lower portion of your wall. Consult your owner's manual for exact instructions.
Mar 13, 2011 | Philips 55PFL7505DF7 55 in LCD TV
I have 2goodmanGKS9 gas furnaces(propane) installed on 27 Dec 2009. Both units are working. One is in the basement adjacent to the rear outside wall. Lower unit heats about 1200 square feet. Lower...
well lets start with the 2" pvc pipe. that is a combustion air intake it does not put air into the room, i hope. this is a 90% furnace and they should have installed it that way. there should be 2 pipes to the outside the other is combustion gases. the dust problem maybe caused by the air return pulling the air to that room. the bedroom normaly does not get the trafic that the rest of the condo it would not have as much dust.
Feb 10, 2011 | Goodman Heating & Cooling
I have anrca hdtv model # R56WH76 and I don't know how to set it up with my cable. I have the dish network box in the living room but this rca tv i have in my room with the cable coming out from the...
To watch Dish Network in your room there a couple of different ways to do it. Unless that cable coming out of your wall is connected to a Dishnetwork reciever its useless.Now if the reciever in your living room is a dual tuner dvr than you can run a cable from one of the two outputs to your bedroom. In this scenario you can watch different channels at the same time. If it isnt a dual tuner then you can actually put a splitter on the cable coming out of the box to the tv(has to be on cable coming out of the reciever) and run it to your bedroom. In this scenario both tvs will show the same channel.In both cases you need a UHF remote(dual tuner DVRs come with one UHF and one infrared) that will allow you to change channels while in your bedroom. If you want HD programing on both tvs you will need to contact Dish Network to get a second reciever. its $7 more a month for a second reciever.
Dec 19, 2010 | RCA R56WH76 Projection Television
I have constructed a hall for the purpose of meetings. But now there is too much of echoing within the hall. even without loud speakers. With loud speakers, it gets worse. How solve this problem of echoing
Excessive room echo is caused primarily by two things - hard surfaces and high ceilings. The worst materials are glass, marble and concrete block. Next to this is drywall. The more hard surfaces you have, the worse the echo will be. For example an entirely drywall room is much worse than one with drywall walls and an acoustic tile ceiling. The sound simply bounces from the back wall, to the front, to the ceiling, to the floor, back to the walls, floor, ceiling and so on. The solution of course is to reduce the amount of hard surface area.You need to coat the wall with some sort of acoustical wall treatment. Carpet on the walls will work or you can purchase materials for that purpose. How much to install and how much area to cover will require experimentation. There are many choices and this is just one.
An online search will provide many options. Search will the term "Acoustical Wall Treatment"
Oct 08, 2010 | Hammering
Acoustic solutions lcd tv astv15id last used 2 months ago perfect ,switched on today perfect picture but no sound
Hi I know this was posted months ago but the answer may help others, I found the capacitor C852 1000Uf ,35v was bulging at the top which is on the power supply board the number C852 is for the acoustic solutions model lcd42762f1080p tv (but this info would apply to most acoustic tvs: WHEN TESTED THE CAPACITOR ON THE ESR METER READ OK, but cos it was bulging at the top I knew it was faulty, it seems that it was breaking down under load hope this help regards celestica
May 18, 2010 | Televison & Video
Televison & Video Logo
253 people viewed this question
Top Televison & Video Experts
