-   actually by mistake i set a bios password ofmy inspiron 1525 laptop & now i have forgotten so please suggest me any solution
-   Guest
Dec 20, 2008
-   cant even get in in safe mode-   onairq107
Jun 17, 2008
-   I have two problems,the first ,when I started my laptop,It ask me enter Password,but I don't know the password...
the second The DVD in my laptop can't read the CD,It tries detected but it can't see the CD,DVD,and ordered me please insert the CD...
If you can boot the system, BIOS password recovery is usually easy. The first thing you will want to do is to use a BIOS password cracker to recover the actual password. There are a large number of BIOS password crackers available from a variety of sources. Some BIOS crackers only work with certain BIOS versions and some work better than others. You may have to try a number of crackers before you find one that works.
Some BIOS’ have pre-installed backdoor passwords that enable access to the system if you have lost or forgotten your password. Attempting to regain access to the computer by using one of the following backdoor passwords should be your first step if you have lost or forgotten your BIOS password and cannot boot your computer. If you are able to regain access to your system by using a backdoor password, you can then use a password cracker to reveal the stored password or enter the BIOS setup to change the password. These backdoors are more likely to work on older desktop systems. We are not aware of any name brand laptops or notebooks that have backdoor BIOS passwords.
At boot-up note the BIOS provider (Award, AMI, Phoenix, IBM, etc.)
Here's a link to several approaches http://www.tech-faq.com/reset-bios-password.shtml
there are several software solutions that can solve this - you'll need to create a boot disk and reset the password.
I have an older latitude laptop and the screen goes dark shortly after the computer is turned on....
(More)
I have an older latitude laptop and the screen goes dark shortly after the computer is turned on. What do I need to do. It has window XP if that makes any difference. Thanx
