Reprogramming my remote
I dont seem to have a code search button
  • 5 more comments
  • gadon Jun 01, 2008
    I have a Sanyo 32" t.v. and one for all remote that I do not know how to get the right codes for the remote to make the t.v. to work.
  • Anonymous Jun 02, 2008
    only a who input button
  • Doverking Sep 16, 2008
    i dont know how to prgram the remote to my t.v.s
  • Anonymous Oct 05, 2008
    cant find code search button
  • Anonymous Oct 22, 2008
    cannot find the code search button
  • Anonymous Dec 24, 2008
    WHERE THE CODE SEARCH BUTTON ON THE REMOTE?
  • peach34 May 18, 2009
    i need hep i dont have a code search button
I have a oneforall remote control i need to program my rca vhs can you help me find code
Posted on May 20, 2008
Well you see i have a philips remote and i had the same problem
what you should do is...
1.press the code search button until red indicator stays on
release the code search button
2. press and release the desired mode button{t.v or dvd ect.}
the red indicator blinks then stays lit
3.enter the 3 digit code from th code tables/after that red indicator turns off
press channel up
then it should program.... i hope i could help you
Posted on Sep 28, 2008
3 Suggested Answers
SOURCE: rcr430s programming
I had the same problem and was able to find the manual online. Here is the link, I hope it helps!
http://157.254.235.130/public/RCR430S_REVA.pdf
Posted on Nov 18, 2007
  • 87 Answers
SOURCE: MY REMOTE DOESN'T HAVE A CODE SEARCH BUTTON. HOW
It might notbe able to be programed.You might have to buy a progamable remote.
Posted on Oct 17, 2010
I have an HTR-2 NAD remote. All the buttons except for the ON button are working. is there anyway to fix this?
Remote controls have an operating code which entered right will cause all functions to work. However if you were given the wrong remote or it doesn't have the right code, certain buttons will not work.
Check that the appliance it operates is the right model for the remote. Some remotes will allow reprograming others are fixed. If you can reprogram it will be just a question of finding out which code the amp uses and entering that. You can search online for the codes for your model.
It's not uncommon for the wrong remote to be sent out when first sold. Some people don't know it's wrong as the remote works nearly all the functions, just not all.
Aug 02, 2014 | NAD Audio Players & Recorders
Tip
How to reprogram your remote number 1 question
number 1 answer google it as in need codes for philips remote it should then have several listings find the one that looks like your remote select it then it should show the codes for alot of tvs find your with the instructions it gives you on how to reprogram your remote using those codes if the codes dont work for you it should tell you how to do a scan search with your remote
on Feb 25, 2010 | Audio Players & Recorders
Reprogram rca systemlimk 3 for toshiba
Manually turn on the TV. Find the three-digit code for your TV.
Press and hold the CODE SEARCH button until the INDICATOR LIGHT lights, then release the CODE SEARCH button.
Press and release the TV button (The INDICATOR LIGHT will blink then remain lit).
Enter the code using the Number Buttons. After your code is entered, the INDICATOR LIGHT will turn off.
Aim the remote at your TV and press the ON•OFF button. Your TV should turn off.
These are the proceedings. If you want more details check this link.
Dec 24, 2012 | RCA Universal Remote Control
I need a code to progam this remote to control a zinwell zat857 dtv converter box! please
OK, I have a Zinwell box that was working perfectly until a friend tried it in his new apartment. Two problems (a) he misplaced the remote over there, and (b) he reprogrammed it so it now only gets four crappy channels instead of the previous fifteen.
Will try to get him to search for remote. Meanwhile ar 4am:
I have two universal remotes, old Magnavox and newish Ptimesat. Primesat looks good but doesn't seem to have search fubction -- does it> Tried to get Zinwell to work on Aux wth code 591 but no luck, Search on Magnavox got one partial result but failed again. Help?
(b) Is there any way to reprogram the box manually, without a remote? I want my channels!
Nov 14, 2010 | GE RM24948 Remote Control
I have and RCA RCR311ST Universal Rmote Contro which I can not seem to find the Cole Selector button to program my Orion TV any ideas?
I can help you reprogram your RCA RCR311ST for all your Orion TV. The folks at RCA did away with a code search button for this model and you must press a combination of buttons to setup programming more.
Please review my Fixya Tip posts for:
  1. Searching for the proper codes, or
  2. Entering the codes you have looked up for your Orion TV on this remote's device code list.
I hope that helps.
Jan 20, 2010 | RCA RCR311S Remote Control
I need to reprogram my jumbo remote to my tv and dont know how or any codes.please help?
I recommend using the auto-search function of your remote to find the codes for your TV.
To have the remote try each TV code it knows one at a time, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Press the ON/OFF button slowly and repeatedly until the TV turns off. The LED will blink once each time you press the ON/OFF button.
  5. Once the TV turns off, press the ENTER button to store the code and the LED will turn off.
I hope that helps.
Nov 27, 2009 | Innovage Jumbo Remote Control
Reprogramming to my symphonic tv
What is the brand name of the Remote? You might be able to download or print off a manual from the manufacture's website, if they have one. but try this first, turn the TV on and push the code search button (If there is one) and press the TV button and aim it towards your TV, this should make the remote begin searching for the codes. If that doesn't work, try this, push and hold the code search button, usually the light above or below the button flashes 3-4 times then stays on, then push the TV button, it should flash once and then also stay steady, next input the code for symphonic, they are:
0906, 0520, 0324,0247, and 0004. Enter each 4 digit code and wait for a response. Usually the TV will trun off after the correct code is pushed. Sometimes you have to push the TV button again to complete the programming.
May 01, 2009 | Televison & Video
Reprograming
http://www.remotecodelist.com/remotes/magnavox/Philips-Magnavox_PM525S.pdf
This is the user's manual for a Phillips remote control. There is a list of codes in it. They should be rather universal. There's also instructions as to how to program it. I believe that there is a way to program it without using the codes.
Programming with Code Search
1. Manually turn on the device (TV, VCR, etc.) to be controlled.
2. Press and hold Code Search button until the red indicator stays on. Release the Code Search button.
3. Press and release the desired mode button (TV, VCR, etc.). The red indicator blink, then stays lit.
4. Press the Channel Up button repeatedly (up to 300 times) until the device could be controlled changes channel. The red indicator blinks, then stays lit. If you accidentally overshoot the code required, press the Channel Down button to backtrack through the library until the device changes channel. Pressing Channel Up changes direction to forward again. Press and release the Mute button to install the code.
Hope this helps :)
Jun 20, 2008 | Philips Televison & Video
Televison & Video Logo
715 people viewed this question
Top Televison & Video Experts
