Question about ASUS WL-500B Wireless Router
Wireless wl-500b routing problem
How to configure WL-500B connected to adsl router.
Minha internet tá caindo direto e não consigo entrar no modem
Posted on Jun 05, 2008
Sitecom WL-342 Wireless Router won't access internet.
Make sure there is a network cable going from your ADSL modem into the WAN connection of the router.
If the ADSL modem is wireless, then it is also a router in whihc case you will want to bypass the WL-342 all together.
Thanks,
Pat
Apr 01, 2010 | Computers & Internet
I am not able to properly set up my network with an ASUS Wl-500B
Both routers need to be on the same IP scheme and subnet i.e. 192.168.0.X subnet 255.255.255.0. First, unplug the Asus router. Next, make sure you have connection to the internet by hooking directly to the Apple router. Once you've established a connection to the internet plug the Asus router into the Apple router but go LAN port to LAN port.
Mar 23, 2009 | ASUS WL-500B Wireless Router
Connecting 2 routers (ASUS WL-500W and D-Link DSL-G604T Wireless)
This will give you a "Double NAT" setup. Meaning, Your D-Link router is connected to the external internet address assigned to you by your internet service provider. More than likely this is a DHCP address you do not control. Your D-Link router is then translating the address to the 192.168.1.x network. This is the first NAT translation. You are then connecting the ASUS router to DLINK, causing a second NAT translation. (Internet ADSL --> D-Link WAN Port --> D-Link Lan Port --> ASUS WAN Port --> ASUS Lan Port to computer/server/etc. ) If both of your routers are giving out DHCP addresses, then this is all that is required.
Nov 22, 2008 | ASUS WL-500W Router (WL500W)
ASUS router not working with VOIP in use
check your settings if you allowed more than 1 computer to connect to your router.
Nov 15, 2008 | ASUS WL-500B Wireless Router
Cannot through ASUS WL-530G connect to internet
I've settle my problem. Set the correct VPI and VCI provided by ISP.
Nov 12, 2008 | ASUS WL-530g Router
Wl-500b disconnects regularly
Is it a standard Router from ISP? they are usually of lower quality.. I don't use them massive difference all around with connectivity if you use Cisco Tp link etc.. When I changed mine I had permanent connection at 40 mbps down and 9 mbps up, old router from ISP 32 mbps down 1.3 mbps up..
Aug 09, 2017 | ASUS WL-500B Wireless Router
ASUS WL-500W not connected to the internet
how your ADSL internet service provider, lock connection from any his machine ? Or your ISP dont provider for IP ADDRESS for DHCP or your ASUS dont set up get IP from DHCP.
Check this information.
Good Luck!
Mar 27, 2008 | ASUS WL-500W Router (WL500W)
A new router, recognizes the printer (HP Photosmart) and still won?t print from a distant location on the network.
I?m not sure about this one, but I think you should make sure there?s permission to access (share) the printer in the router and/or printer settings. If the printer is connected directly to the router, check if it?s in the right port and you?re not sending a print request to a different port. If that doesn?t help try to set it to another port in the router.
Feb 22, 2006 | ASUS WL-500B Wireless Router
ASUS WL-500B Wireless Router Logo
120 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
