Question about Lexmark X5150 All-In-One InkJet Printer
Solution Center The Solution Center has red outline on all subjects. This must mean there's something wrong, but WHAT?
  • 47 Answers
Well when all else fails i would suggest uninstalling and reinstalling the solution center. After using the add/remove programs icon in control panel then reinstall from either the cd or from this link:
Posted on May 29, 2008
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Its a 2004 61 inch big screen projection tv and the subject on screen has three colors outlining it green red blue on the outer portion of subject on screen
Tv have a problems known as a convergence pictures problems,it is dead.Tv have R,G,B colors lines mis alignments,have colors shadows pictures or 3D pictures look alike?The tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts on the tv convergence board must be replaced to repair it.To solved tv pictures convergence problems.The shop will cost u like $300-350 for parts and labors.
Jul 05, 2011 | RCA R61WH76 61" HDTV
Thereis a red outline around the subjects on my bush TV
the antenna in god direction?
open tvbehind cover,,,,,,thir is 3 rings around crt neck,,,every one for adjusting one cplour[R,G,B]ROTATE THE R ONE WHILE WATCHING,THROUGH A MIRROR,,,,,,YOU MUST ADJUST FOCUS FIRST,,,,,,,for tech it will be easy by using battern generator
Jan 07, 2011 | Bush WS6671 28" TV
Taking pictures with my Sony super Steady Shot camera DSC-H2 What if I want the focus to be on something that is not in the center of the lens?
On my Sony DSC-H1,I just depress the shutter button HALFWAY,with the subject in the center.then recompose the shot as you'd like it( center), and the subject will stay in focus.
Aug 31, 2010 | Sony Cyber-shot DSC-H2 Digital Camera
Red and Green and Yellow lines inthe Picture
Is this an LCD TV or and LCD Projection TV.
This sound like a convergence problem that sometimes can be adjusted in the user menu. Definintely can be adjusted in the Service Menu.
May 18, 2009 | Philips Televison & Video
Pictures are blur
Your pictures are blurry because the camera did not focus properly on the subject.
First, turn on the camera in any picture taking mode (or video mode), then look at the screen or viewfinder. There should be four white corners in the center of the camera display. This is your targeting area.
1. Aim the camera at your subject so this center area is directly on it.
2. Press the shutter button lightly, not all the way down. Wait for a second or two WITHOUT RELEASING YOUR FINGER. If the white corners turn green, keep the finger on the button and press it all the way.
(Once the screen flashes black, a picture is taken and you can release the finger).
If the targeting area turns red and blinks, then the camera has not focused. You can to try to focus again by following step 1 and 2. If a picture is taken when the targeting area is red, then the picture will be blurry.
If there is no targeting area, then you can still focus by aiming the camera at your subject. Now follow step 2. A green box will appear on the subject, then a sharp picture can be taken.
The red arrow that flashes means that the pictures or videos are being written onto the memory card.
Also, try to be steady when taking pictures, because slight hand movement can cause blurry images too.
Page 25 in the DMC-FZ7's english manual will also explain how to focus.
Jul 18, 2008 | Panasonic Lumix DMC-FZ7 Digital Camera
Powershot A80 problem: green and red lights around subject
Recharging the batteries seemed to solve it. Although I had not received the low battery warnning and this phenomenon had not occurred at other times when the batteries were low, it seems to have fixed the problem.
Jun 29, 2008 | Canon PowerShot A80 Digital Camera
Double outline "red" around images
Hi you have bad convergence ic stk modules ,Cost for repair center to fix is 250.00. call your local repair center ask there prices on convergence ic repair. It is a very common problem every 3 to 5 years .Our service center does a lot of these.
thanks doctor video 1987
Jun 01, 2008 | Toshiba 42H83 42" Rear Projection...
Red outlines in the picture
somewhere in the tv menu there is a place to make video adjustments. one should be for aligning the color guns. one is for red and the other two are green and blue. it will give you a cross in the center of the screen. it should also give you prompts to adjust the lines for centering and to save changes. this happens eventually on all rear projection tv sets.
May 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Lexmark X5150 All-In-One InkJet Printer Logo
32 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
