Booting from a CD
I want to install Black XP through formatting but on boot up there is no boot from CD option even though the CD is in the drive.
  • 1,944 Answers
Did you make sure in your computers BIOS that boot from CD is before boot from hard drive?
Posted on May 20, 2008
How do I install my 22w2 to my Dell Computer with Windows XP 2002
Windows install first Available some points:-
A> Fresh Windows XP CD not damage cd, if cd damage may be some file miss and installation after problem show.
B> DVD Rom Drive.
C> You DELL pc support Windows XP.
Installation Process:-
> Insert CD to DVD ROM driver and boot CD.
> If CD not select first boot then open bios and select CD first boot.
> Then follow instruction step by step like language, which drive install windows (C Drive select), format option (select quick format), new user create etc.
Sep 06, 2013 | Westinghouse Electric LCM-22W2 Monitor
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
How to erase operating system on laptop
First you must boot from a CD or DVD or from a floppy disk and not from the hard drive.
Creating a Windows XP boot disk
Note: The Microsoft Windows XP CD is a bootable CD and in many cases you should not need a bootable floppy diskette. Booting from the Windows XP CD will allow you to not only install/re-install Windows XP but will also allow you to troubleshoot it.
Create MS-DOS bootable diskette
When formatting a floppy diskette, users have the option of creating a MS-DOS startup disk, follow the below steps to do this.
  1. Place diskette in the computer.
  2. Open My Computer, right-click the A: drive and click Format.
  3. In the Format window, check Create an MS-DOS startup disk.
  4. Click Start
How to boot from Microsoft Windows XP CD.
1. Restart the computer while it is rebooting keep on tapping on F12
2. In the boot menu option select on CD/DVD Rom the press Enter
3. Computer will restart and you will be prompted to " Boot from CD/DVD press Any key" just press any key on your keyboard. Just the let the Windows Setup files be loaded.
4. Press "R" when you the screen below
5. Press 1 then Enter
6. In the command prompt type format c:/q then press Enter
Note: This will format the drive c: or wipe out the information in the hard drive
Apr 14, 2011 | Dell Computers & Internet
I am trying to install win xp on a dell optiplex 760, but it can't seem to boot from the cd even after I set the boot options to boot from cd. It also can't read the boot files from the usb flash...
unless the usb drive is formatted correctly the computer will not see the files as a bootable directory. if the cd is not reading try usig an external drive or loading the disc into another computer and see if it works.
Mar 08, 2011 | Computers & Internet
Plz send me step by step information for removing win vist to install win xp. on compaq laptops
For ding this you need windows xp cd
put it in your CD ROM
then press F10 to get into bios and under advanced boot priority change your first option to CD and restart ,it will ask to boot from CD,press enter
You will setup process of windows xp,it will ask you where you want to install windows xp,choose drive where windows vista is installed (c:) ,then first choose the option of format this drive using NTFS,it will format your windows vista and will start installing windows xp and in an hour's time it will be done
Aug 02, 2010 | HP Compaq Presario V2000 Notebook
Wiped old PC clean with blanco.installed win xp on old pc got response.turned it off black screen stating, blanco starting_ How do I fix
Blanco is a data cleaner utility that erases everything from a hard drive so data cannot be recovered. Unfortunately, this includes the MBR - or Master Boot Record. The MBR tells the comptuer BIOS how to access the hard drive and use it to boot up.
I would suggest performing a full FORMAT of the hard drive so the MBR will be recreated. If you are installing Windows XP from an install CD, you will be given the option of which drive to install the OS to. Delete all partitions that show up, create a new partition and then choose the Full Format option (not the Quick format).
If you are using a restore disk, you may need to download a boot floppy or CD and format the drive first. Boot to DOS, type in
format c:/
Where C: your hard drive.
You can get a boot disk from...
Apr 30, 2010 | Computers & Internet
How do I re-format Acer 4200 TravelMate hard drive?
Windows Reinstallation Disk option:
Insert Windows Reinstallation disk into tray, Boot to CD/DVD-ROM by pressing F12 at initial boot screens, delete existing Windows partition, re-create partition, and then follow steps to reinstall Windows. This will lead you to an option for formatting hard drive. I recommend choosing the full format versus the quick, from this point you can let windows install, or just shut the computer down when the format finishes. You will have to watch the progress, though, if you don't want the install to commence.
Boot disk option:
For XP, 95, 98, or ME, follow the instructions at this MS article page. It will walk you through creating a boot disk that will allow you to format.
You will need a floppy disk or CD
Apr 03, 2009 | Acer TravelMate 4200 Notebook
Can I foramt Vista Partitions using xp cd?
Yes, Insert the Dell XP disc, and when your computer first stars, in the right hand corner there should be setup and boot devices. Choose boot devices and run off the disc. After that, there will be an option to Format All your drives, (even some you might not know about :P). From there you can install XP onto your laptop.
Jan 28, 2009 | Computers & Internet
dont mind it...
if you want to install xp to your computer while you are using utimate vista you can install it...
but you must have a large space of memory to install xp, tnx anyway hope that i can help...
Jan 08, 2009 | Microsoft Windows Vista Ultimate Edition
I have 2 drives C:\ and D:\ Im trying to reinstall my windows but my c drive would not allow me to do so. Instead I could only do so on D:\ Now I have three options during bootup: c:\Windows, D:\Windows...
Insert the xp CD in the drive.
Where it asks you to choose a location to install xp, just delete both the partition. (default button D)
Then make two fresh partition and install xp in the first one (that is C).
This will solve your problem.
Oct 14, 2008 | Computers & Internet
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
