Back to:
Tags:
Omega 4000 Juicer
Omega 2.0 Electronic Problem
By Reynolds - usenet poster
Hi There I have a 2.0 Litre Vauxhall Omega  99/s the electronic Problem
light came on today is ther any one who can guide me what to look for.
The light only came on when the car nearly ran out of petrol.
I have refilled the tank and have checked the plugs etc to no avail.
I would be grateful for any help to solve my problem or where to go in the
Wembley area.
Thanks
Mo.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 07, 2005
Not Rated (0)
Beresford
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
"Muhammed Butt"
I assume you mean the "Engine Management System" (EMS) warning light.
Unless you have access to the TEC2 equipment, then a trip to your local VX
dealer is requred to diagnose the fault that is logged.
Has anything else happened (revs limited to 4000rpm, etc.)?
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Omega 2.0 Electronic Problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
Perkins
Rating: 0%, 0 votes
There has been no other problem you can still drive the car with no problem
but the light that stays on is annoying , when you go over 4000 revs in
first gear it does start to judder,
I am trying to get hold of the local dealer to diagnose the problem.
Any more ideas please, i do't want to end up with a nasty bill.
Thanks
Mo.
Thank You!
Solution #3
Not Rated (0)
Ross
Rating: 0%, 0 votes
The fault does appear to be intermittent i covered about 100 miles today in
the car and the light stayed on most of the time and also disappeared.
Hopefully i will be able to post some more info as I am taking the car in to
Vauxhallsin Burnt Oak Edgware (London) to have the car tested.
Once again thanks for the info.
Mo.
Thank You!
Solution #4
Not Rated (0)
Lizzy
Rating: 0%, 0 votes
The EMS can either be intermittent, or stay on.
SInce it is ON all the time, I would arrange to have this seen to ASAP.
The fault could be anything from ABS sensor failure, to airbag fault.
With some engine sensor failures the engine is placed in safe mode, such
that you cannot rev above 4000rpm, but this does not appear to be the case,
so sounds more like an ancilliary accessory rather than an engine component
that has failed...
Thank You!
Can you Help with these Juicers problems?
Juicers
Where can I get new parts for this machine? Thanks Gail
Juicers
I was juicing beet tops when my juicer started rattling...
Juicers
Braun Citromatic MPZ9    HELP! Ordered part from...
Juicers
hi, i searching to buy a manual juicer. so,i had seen...
Omega 4000 Juicer
Hi! I just received my order of the omega 4000 juicer....
Loading problems.
Repair Service
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
