Question about LG Shine KE970 Cellular Phone
Changing Ring Style
Is there an easy way to change the ring style from a tone to vibrate? I find that I have to go through all of the menu options to do so. Other phones I've had allow you to push 1 or 2 buttons.
Scroll down and it takes you straight to the ring styles and u can pick it straight from there x
Posted on May 21, 2008
  • 3 Answers
A long press down on the star key on your keypad will toggle it back and forth from tone to vibrate without having to go through any menu options.
Posted on Jun 23, 2008
MOTOROLA W376G...turn off phone on ringtone
Hello!
Set phones ring style as "Vibrate then Ring" , "Vibrate" , or "Silent" to avoid the power on alert.
I set my ring style to "Vibrate then ring" so that I dont have to change the settings everytime I turn it on or forget to so when I receive phone calls or alerts it still rings & then I dont have to go back and change the settings again when I turn tha phone off so that is dosent have the power on alert.
This is the Only way I have found to turn the phone power on tone/alert off.
Change Ring Style:
-Go to Main Menu
-Settings
-Select Ring style
-Then choose change, & set it to the ring style you want.
Feb 21, 2010 | Motorola Mobility W376 Cell Phone
Phone does not ring when call comes in on my Motarola Razrv3 cell phone. It vibrates but no ring. The ring volume is set on 7.
1st make sure that your phone speaker is not malfunction, to do this just play any ring tone from your phone to check whether there is a sound come out from the phone speaker.
If there is no problem to hear sound from phone then have to check the phone setting, to do this just PRESS and HOLD the button #, a shortcut to toggle between RING mode and VIBRATE mode. Or goto Setting>Audio>Style Detail, and change the alert type such as sound or music. Make sure u are not in the Silent style mode.
YBC (/\)
Oct 21, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Cannot find volume
You can change the Alert type by going to Tone setup:
Select Menu > Settings > Tone
Here you will have the option of changing the ring type. you can select Ring only or Ring and Vibrate or any other available options as per your choice.
Hope this information is helpful.
Your comments and ratings are highly appreciated. Please do not forget to rate this solution.
Thank you for choosing Fixya
Oct 16, 2009 | Nokia 2610 Cellular Phone
How do I change the ring tone on my Motorola V6. It is a loaner and there is no instruction book. I can't stand the ''hello moto'' when it rings.
go to the phone settings and then go ring styles and select the style then select line 1 and press button change and then select any tone if u want......or.......
as well as u can try go to phone multimedia section and select sound and then press _ok_ and select any song and go to the option menu and select apply as a ring tone then press _ok_.......
Aug 22, 2009 | Cell Phones
My Motorola Razr won't ring or vibrate when receiving an incoming call except when plugged in to the charger
Turn off the ringer id function in settings, ring styles, load detail, ringer id's off.
Hope this helps
Jan 11, 2009 | Motorola Mobility RAZR V3
Motorola w377
Like most of the W377, this one's very odd. The only way I know how to do this is to switch off all Key tones. Key volume is part of the Ring Style menu, so:
>Settings
>Ring Style
>Ring Detail
>Change
> On the Detail menu use the 4 way selector arrows to cursor down to Key Volume
>Change
>0
>Ok
>Back out
NB The Ring Style settings for ALL ring parameters (Ring Volume, Line 1, Text Msgs, Voicemail, Alarm, and Key Volume) change whenever you select a different Ring Style, so you can set up one ringtone in Loud Ring but get a different one for Soft Ring, a different one for Vibrate and Ring, a different one for Vibrate then Ring, etc.
For the sake of sanity (and to avoid the alarm waking me up with a loud blast of Bach when I wanted a quiet 'Ding') I have set the same ringtones etc in all of the above profiles.
BTW whenever you can't find a menu you need, try pressing the black round button (OPEN MENU) in the middle of the 4 way selector arrows - it opens submenus that can't be accessed any other way.
Hope this helps.
Jan 02, 2009 | Motorola Mobility W377 Met Silver/Pink...
Won't Ring
check the settings in your phone book. this happened to my phone and all of the personal ring tones were set to vibrate. I don't know how this happened. I went into each contact and changed the ring tone to none and I am back in business
Sep 15, 2008 | Motorola Mobility W385 Cellular Phone
MOTO PEBL MESSAGE AND RING TONE
i think this is what you're going for...Go to SETTINGS, then RING STYLES. Whatever ring style (ie, vibrate, silent, vibe & ring, vibe then ring, loud, soft), underneath is the detail for it, which you can then change (bottom right of screen).
So right now my phone is:
"Style: Vibe & Ring" and underneath that is "Vibe & Ring Detail"
Under the details, you can change your ring tone by scrolling down to the "Calls" option and choose change (bottom right of screen). And to change your message tone, just go to "Messages" and then change (bottom right of screen).
Hope that helps!
Apr 08, 2008 | Motorola Mobility PEBL U6 Cellular Phone
Key pad sound
open ur phone menu first. then go to settings,open settings, then select ring styles,then select second option it can be as ??????detail.(???? = type of ring style u have selected,whther it is loud, soft, vibrating .vibe & ring or silent). just select second option,then scroll down and look for key tone type, select it and choose it as off, ur annoying keypad will silent. thanks best of luck.
Feb 24, 2008 | Motorola Mobility W375 Cellular Phone
Unable to remove icon from screen
that was under your ring style.change it to vibrate so the orange bell will disappear
menu>ring style>style>vibrate
Sep 04, 2007 | Motorola Mobility MOTORAZR maxx V6...
LG Shine KE970 Cellular Phone Logo
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
