Acer PD100D Projector
Hi Dave.
I see that you have replied to someone technical request for help with an overheating projector, I have the same fault and have cleaned out all the dust but it still has the fault, warning overheating, You say that it my be the fan or the sensor, can you tell me where I can get replacements.
Regards
Roger
  • Anonymous Nov 16, 2008
    Seen this as well (not on my unit).
I'm actually in the same boat.
I'm going to start my parts search today.
It is a shame that this model seems to have this issue--everyone reviewing it says how awesome of a projector it is except for this one fault.
In most of the reviews I'm reading, the people that run into this problem often run into it pretty much out of the box, so they get it repaired under warranty. This one that I'm dealing with only recently started doing it, far out of warranty. So I'm kind of up a creek.
I'm going to start disassembly and looking for part numbers today.
Posted on May 20, 2008
Acer p7280 projector lamp goes out after 10 min., and red error lamp light up.
The lamp must be ok
the ballast may be fault
or the mainboard is fault
Have a nice day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Lampdeng Limited
Jerry
Jun 18, 2014 | Acer P7280 OEM Projector Lamp
Compaq MP2800 DLP Projector
If the projector is not getting a source it might go on standby maybe check where you plug it in.
Projectors require quite a bit of power and should be on a single loop/outlet not hooked up to a powerbar with more things on it.
Hope that helped.
Dec 26, 2007 | Compaq MP2800 Microportable Projector sps...
My new projector, Acer p1100, gets overheated very fast. In just half an hour after I turn it on, gets overheated in front, on the right side of the lens.
Are the filters clean and I came across one with the exhaust fan the wrong way around. Make sure there is lots of air blowing out of the exhaust.
Mar 15, 2011 | Acer P1100 - DLP Projector 3D
Why does my projector keep shutting off
The LEDs usually indicate a likely fault, for which you need to consult the manual after noting the sequence, timings and colours.
In many cases this problem is caused by overheating or a faulty lamp. It's worth checking the LEDs before purchasing a lamp as it will probably cost at least £100 which is wasted if the fault lies elsewhere.
If overheating is the problem then you could clean the filters and see if this helps.
Feb 20, 2011 | InFocus IN2104EP Projector
HI I WANT SERVICE CODE OF INFOCUS LP600 ASKC175
I am not exactly sure what service code you are searching for, what is happening with the projector? You turn it on and immediately it's looking for a code? Please let me know and I can help
Tim
Sep 13, 2010 | IBM Office Equipment & Supplies
Acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to...
acer pd100d does not receive signal from pc or laptop, changed cables too. only shows white screen with acer logo and no signal, worked until yesterday, buttons dont respond and cannot reset the unit to factory defaults. please help
Dec 24, 2009 | Acer PD100 Multimedia Projector
Connecting my xbox 360 to a sharp projector
video plug to yellow video in jack, audio to red and white.
Jul 12, 2009 | Sharp Notevision PG-B10S Multimedia...
My Acer PH530 overheats and shuts down after 15 minutes.
Mine does the same. When it was still under warranty I kept sending it in to get it fixed, but Acer never fixed the problem (rather they caused more problems). I sent it in for repairs 4 or 5 times, but eventually the warranty expired (after they told me they would extend it from the dates of the repairs). I haven't found a solution. If you do please let me know. Anyway, I don't recommend this projector to anyone else. AND, I certainly don't recommend Acer's customer service. Their warranty is worthless.
May 08, 2009 | Acer PH530 DLP Projector
ACER PD100D Overheating
I found that by using the menu to reset to factory defaults fixed the issue. It appears to be a combination of settings that causes the issue. I have created this situation a few times while trying to get more accurate colors from the projector.
Jan 05, 2009 | Acer PD100 Multimedia Projector
Dell 1100mp projector
need to buy the right projector lamp for dell 1100mp
May 28, 2008 | Dell 1100MP Multimedia Projector
Televison & Video Logo
144 people viewed this question
Top Televison & Video Experts
Electro Med Services...
