Question about Fisher and Paykel (IWL12)
Washing machine fills with water but wont spin or even turn!!!!
Hotpoint washing machine, no blockage in the pipe, but the drum will no turn or spin the clothes, it drain ok tho???
  • 3,741 Answers
It doesn't spin If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
It doesn't pump or spin If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
  • If the motor is running, your washer probably has a frozen pump pulley or a broken pump belt. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. If the pump belt is broken or looks quite worn, replace it--but be sure to check the pump pulley before you change the belt.
  • If the motor isn't running, the lid switch may be defective. If so, the washing machine can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
It pumps, but doesn't spin If your washer pumps out the water but doesn't spin, check these:
  • The lid switch may be defective. If it is, the washing machine doesn't spin. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washing machine to get to the switch. If it's defective, you need to replace it.
  • The motor coupler may be broken. Many Whirlpool®-manufactured washers use a small, relatively inexpensive motor coupling. It's plastic and rubber and is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. You may need to replace it.
  • A belt may be broken. Many washing machines have one or two belts. If a belt is broken or badly worn, you need to replace it with a genuine belt from the manufacturer. (Some washing machine belts are designed with special characteristics not found in automotive belts.)
  • The clutch may be worn. If your washer is a GE, it may use a clutch to come up to the proper spin speed. As the clutch wears out, it may prevent the unit from spinning well or at all. If the clutch is worn, you need to replace it. For this job, you probably want to hire a qualified appliance repair technician.
  • The drive motor may be defective. Many washer brands use a reversing motor. For agitation the motor runs in one direction, for spinning and draining, the other. It's possible for a motor to burn out in one direction and continue to operate in the other. If this happens, you need to replace the entire motor.
  • The transmission may not be shifting properly. Older washers produced by Whirlpool® have a transmission with an electro-mechanical shifter. If the shifter becomes even partially defective, the unit may drain the water but not spin. This is a complex system, if your washer has a shifter problem, you may want to hire a qualified appliance repair technician to repair it.
  • The spin bearing or basket drive may be worn or seized. These components allow the inner tub to spin freely inside the outer tub. When this is the problem, you usually hear a loud sound during the spin cycle. Call a qualified appliance repair technician.
It spins only with the lid closed For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up.
Posted on Oct 01, 2009
  • charlymonty Oct 01, 2009
    In a front-loading washing machine the agitation is provided by a drum in the center of the washer. If this drum does not spin the agitation cannot occur and the clothes will not be cleaned properly. If the drum is not spinning, make sure that there are no clothes jammed around the drum or stuck in the drum assembly. An unbalanced load can also cause the drum to stop spinning, so unload the washer and carefully load the clothes back in before calling a repair person. Make sure the washer is sitting perfectly level--if one of the feet on the bottom of the washer has come loose this could unbalance the washer enough to cause problems with the drum.
  • 36 Answers
The problem is your drive belt is broken. a home depot or lowes will replace the belt at a cheap price. thank you for using fixya
Posted on May 01, 2009
Why does the drum of my hotpoint Ultima washing machine keep filling with smelly water when turned off
It sounds like it is not pumping out or you have a blockage on the outlet pipe .
Jan 03, 2018 | Hotpoint Washing Machines
Fills when not being used
where the water pipes plugs into machine it has a water stop valve there. turn water off at mains and unscrew pipe. it may have a blockage of some sort keepng the valve open. hope this helps
Feb 14, 2012 | Hotpoint First Edition WMA22 Front Load...
Please help the washer fills up and turns the
Seems like a blockage or maybe pump worn out. Fill machine and take grey outlet pipe on rear of machine. Place this pipe as low as possible into a bowl. If water flows free from this pipe then your pipes are not blocked and most likely you will need to change your pump. Before you try this just put machine onto spin and ensure this will work when machine is almost empty
Mar 12, 2010 | Hotpoint Aquarius WF220 Front Load Washer
Machine will not drain or spin
Machine wont go to spin while water still in drum. Check outlet hose to see if you have a blockage. to do this take the outlet pipe and lay it into a bowl on the floor, if water flows out then it is likly to be your pump not working.
Feb 14, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
When hotpoint aquarius starts washing cycle, water comes out of soap dispensing tray. is there a blockage in the pipe to the drum . i allways use liquids instead of powders, so i find a pipe blockage as...
It could have over filled, or the drum is turning too fast, or there is a blockage in the dispenser hose. To accessw the hose, remove the top cover, and give the hose a good squeeze to clear any possible blockage.
There is little else it could be, so I am afraid it is a process of elmination.
Good luck.
Jan 25, 2010 | Hotpoint WMA64 Front Load Washer
Washer won't drain.
My washer fills up with water and goes thru the wash cycle but when it's time to drain, it just sits there and clicks.
Oct 17, 2009 | Tecnik TKL9260 Front Load Washer
Hotpoint WT540 1400 spin Washing Machine stuck on cycle
Could be a sticking water level switch, which controls the water level, or a blockage in the hose to the switch, or a trapped or split hose to the switch. the hose in question is about 6mm in diam,and goes from the sump hose to the pressure switch,if u remove the hose from the preesure switch chamber, check for a blockage there, and blow down the hose to see if it is clear, u should hear the switch click if it is clear, if no click and hose is clear, then I wud say the switch is faulty.
Plz rate my comments.
Thanks
Dec 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Not draining and flooding my kitchen!
hiya
first off norah, you will need to check the pump filter as there is probably a blockage in there.
secondly guest, sounds like a faulty pressure switch or even a small hole in the pressure pipe, thats why your machine will not stop filling.
hope these help
please dont forget to rate the helpfulness of this reply thanks kj
Jun 09, 2008 | Hotpoint First Edition FEW12 Front Load...
Hotpoint - wont go into spin!
two possible causes motor commutator is damaged thats the bit the brushes sit on.put your finger on the commutator turn slowly and feel for raised segments or damage if there are any then this is you problem. if that is ok check you brushes have a good length and can make contact. if this is ok then check you card for damage.the filling/water level problem could be due to the limit switch pipework blockage at the base thats the small plastic pipe usual blocked into drum very common in old machines. hope this helps
Dec 01, 2007 | Hotpoint WMA30 Front Load Washer
Washing Machines Logo
94 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
