Back to:
Tags:
IBM External Floppy Drive
Thinkpad 365x Ext Diskette Problem
By Rogers - usenet poster
I bought an external diskette drive
p/n 10H3980 - fru 10H4056
cable
p/n 46h/8096 feu p/n 74h0219
I get a general error when doing a dir b: and write protect when
formatting b:.
I can find no reference to configure a diskette, and the diskette was
formatted 1.44MB in a drive on my other system before using it.
Any ideas would be quite welcome.
Thanks,
Hackmann
Sent via Deja.com http://www.deja.com/
Share what you know. Learn what you don't.
I have the same problem.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Aug 11, 2005
Not Rated (0)
Reynolds
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
Have you tried running IBM's diagnostic utility? To get to it, you
need to enter the setup while booting. I don't remember if you have to
hold down the f1 key or the esc key while booting. I think it is f1.
With the floppy drive connected, run the diagnostic test on the entire
system.  For some reason, the test with show two floppy drives on the
computer, but only one will be tested. This is correct.  (I think the
other one is if the computer has a built in floppy instead of CD ROM).
Another thing to try is to go into device manager and remove the
floppy drive controller, restart the system and let Windows re-detect
and install it.
I'm still baffled as to why your floppy is configured as the b drive.
I've had my floppy drive replaced twice on my 365xd due to problems
similar to yours. Twice I had problems similar to yours that weren't
related to a hardware problem. Once it was corrected when the floppy
drive controller was removed and reinstalled. The second time it was a
conflict with some anti-virus software (I believe it was Mcafee Virus
Scan). That was solved by going to Norton (or a newer version of
VirusScan).
Incidentally, I don't work for IBM nor am I a tech support person.
I've owned a Thinkpad 365 for  2 1/2 years so my suggestions are from
experience.
Hope this helps.
Bob
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Thinkpad 365x Ext Diskette Problem:
I don't want to Accept this solution
Solution #2
Not Rated (0)
2Pansy
Rating: 0%, 0 votes
Are you sure the external diskette drive is drive B?  I have a 365xd
and the external diskette drive is drive A.
Bob
Thank You!
Solution #3
Not Rated (0)
Bray
Rating: 0%, 0 votes
In article <37a4ef50.46366 @news.alt.net>,
  bubsy @pop.mindspring.com (Bob Grabowski) wrote:
When I dir A: (with the drive ready) I get drive not ready;  No sound
can be heard when I dir a:
When I dir b: (without changing the diskette) I get a general failure,
after the light on the drive comes on and it makes some sounds.  I get a
write protect error when I format B:, even if the diskette is not write
protected.
Hackmann
Thank You!
Can you Help with these Floppy Drives problems?
Floppy Drives
1. if a rectangle has a length that is 3cm less than four...
Floppy Drives
A positive number is 5 times another number.If 21 is added...
Floppy Drives
back lite is ok, but no data on display screen
Floppy Drives
The community concert hall is hiring a new agency to sell...
Floppy Drives
The monthly cost (in dollars) of a long-distance phone...
Loading problems.
Repair Service
Find Floppy Drive Repairman Near You:
Browse the Repair Directory
Repairman, Get Listed FREE
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
