Question about Samsung RS2630SH Side by Side Refrigerator
Won't automatically restart to keep temp down on either side
Hi. I actually have a SRS616D.. with water, ice as for the 2630 and also a beverage compartment door in the fridge side. The fridge appears to behave fine and comes down to temp and turns off. But it won't come back on automatically and the temp display remains at the target temp. When the fridge is turned off and on again it displays actual temp and then runs until target temp is reached.
I have reasonable technical knowledge and basic electrical test gear (multimeter and CRO). If I can get access to a circuit or logic diagram I might be able to figure it out for myself but I expect one of you will go "Yeah - that's ..."
Thanks for looking at it. Doug
Hi.  I have the same problem.  As a temporary measure, I've bought a wall timer that I've set to turn off the fridge every 3 hours for a few minutes.  At least I don't have to constantly pull it out from the wall. Good luck. I'm still looking for a permanent solution !
Posted on Jun 03, 2008
Water keeps running and the ice maker isn't making ice
The ice maker will not make ice with the water running in contently this keeps the water temp to high. Turn machine off, cut water supply off to machine, remove water inlet valve, ether take valve apart and rebuild it or replace the water inlet valve. Reassemble in reverse order and machine should make ice.
Jun 29, 2014 | GE Monogram ZDI15C Automatic Icemaker
Ge monogram side by side refrigerator ice maker flap not closing and developed ice use hair blower to remove but still keeps happening
Take the ice out look at the flap from the inside...hopefully an easy fix may have to order a new flap moisture gets in there again to vfreeze after you use the blow dryer
Aug 25, 2013 | GE Monogram ZDBN240NBS Stainless Steel...
Water won't dispense
Which pump did you replace? Are there a few?
May 13, 2013 | Electrolux 25.9 Cu. Ft. Side-by-Side...
MagicChef Beverage/Wine Cooler keeps getting ice build-up on inside back panel
Ice build up wil accor if the evaporater blower goes out and does not crculate the air. If you have the model number off the tag I can be of more assistance, with the mobel number I can break the unit componants down in a diagram
Oct 07, 2012 | Refrigerators
We have an stainless steel side by side Electrolux fridge and the freezer sise is fine but the fridge side keeps getting too warm reaching temps of 70 degrees...We adjust the temp settings and it sometimes...
On a side by side unit, the freezer actually cools the refrigerator side of the unit by the use of a "damper" door or switch. Check this between both doors for any ice blockage or damage and go from there. You might need to contact a professional to diagnose the entire unit if you don't "see" any issues.
Jul 21, 2012 | Electrolux Refrigerators
Our automatic ice maker will not quit dripping in the freezer. It keeps clogging the ice maker with icicles and large blocks of ice. Essentially, it keeps "freezing over." We have defrosted it...
if it keeps filling and overflowing you have a bad water valve on the back of the fridge.the part number is WR57X10027 and the valve is around 75 dollars.first thing lift the arm or shut off the ice maker so it won't leak anymore,you're missing a few letters off of the model number so when you call your parts store give them the full model number,open the fridge door,look up on the right hand side wall up near the ceiling and give them the model number to make sure you get the correct valve,shut off the water supply to the fridge,then have the new valve next to the old valve when you remove a water line from the old valve just connect it to the new valve,do this until everything is changed out and the new valve is in place,turn on the water supply and you can check the ice maker to make sure it doesn't overflow.you can manually start the ice maker by grabbing the plastic arms of the ice maker and pull them forwards slowly until the arms start to advance on their own,you'll hear the water valve fill the ice maker and then you can watch it fill to see if the water is filling it correctly and i'm sure you'll be fine with the new water valve installed
Jun 05, 2011 | GE Monogram ZDI15C Automatic Icemaker
I have a Maytag side by side refrigerator model PSD2450GRW. The ice maker will not make ice but the water comes out front just fine. The freezer works and the ice maker is at the ON position. Thanks for...
Hi and welcome to FixYa, I am Kelly. Usually when an ice maker slows or stops ice production it is a symptom of an aitomatic defrosting problem. The freezer must maintain 14 - 16 Deg F for the ice maker to make ice. Any temp above that an ice production stops. If the freezer is in the 14 - 16 deg F temp range then the problem can be the thermostat in the ice maker or the inlet water valve.
Here is simple test you can do at home to see if the inlet water valve is working:
1. Unlpug the unit for at least 10 minutes.
2. Remove the fiber board cover on the back of the unit.
3. Locate the inlet water valve and SWITCH the 2 connectors on the inler water valve.
4. Open the freezer door and hold the light switch button depressed. (or tape it down)
5. Take a glass and attempt to draw water through the door. Do this just long enout to realize water is going into the ice-maker.
^- NOTE the water will actually be going into the icemaker and the water valve is good!
If you have water going into the ice maker when you try water in door then the problem is either an automatic defrosting problem or an ice maker problem.
MAKE SURE TO RESTORE THE INLET WATER VALVE CONNECTORS to their original positons!
The ice maker can be tested using this link:
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
If the icemaker checks out good then the freezer is too warm and there is some reasonthat the freezer is warming up. Usually this is caused one of the following:
1. Defrost control board. Item 13 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48135&diagram_id=28489467#d28489467
2. The defrost element and thermostat. Item 12 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48135&diagram_id=28489469#d28489469
The wiring diagram can be found here:
http://www.appliancepartspros.com/partsearch/frame_diagram.aspx?diagram_id=28489477&pkw_=basket&model_id=48135&NewWindow=1
Here is how I would approch troubleshooting on your unit:
1. Check out the icemaker using the american appliance link above.
2. Do a manual defrost by unplugging the unit and placeing a fan blowing into the freezer compartment for just over 2 hours. (Makes a water mess!)
3. Return the unit to normal service for a few days.
If it starts making ice..... you have an automatic defrost problem or... the evaporator fan is not running at full speed.
One last note... anytime you unplug the unit you must wait about 15 minutes for the cooling system to stabilze or the compressor will NOT start.
Thanks for choosing FixYa,
Kelly
Jan 27, 2011 | Maytag MSD2756G Side by Side Refrigerator
The temperature alarm is beeping and the fridge and freezer continue to get warmer.
Hi i have a jenn-air side by side ice & water dispenser and the ice & water bottons keep beeping and flashing, what does this mean
Jan 26, 2010 | Jenn-Air JCD2389G Side by Side...
No Ice on GE Side by SIde -TFX25JRYF-WW
Usually there is a big metal frame-switch that controls the flow of water. It is located right above the ice tub. If your ice tub is full the ice cubes push this metal switch up so as to stop water supply. If you remove the ice tub out, chances are that you have accidentally pushed the metal switch all the way up until it clicks and stays there. In this position, the ice mold water flow is permanently stopped.
Insert the tub again in its position slowly. Before fully inserting it, pull the metal switch down inside the empty tub. With the switch down, insert the ice tub back into position.
If that does not apply for your refridgerator, look for a similar water flow switch to turn back on the water flow.
Hope this helps
Mar 07, 2008 | Refrigerators
Samsung RS2630SH Side by Side Refrigerator Logo
122 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
