Question about Microsoft Xbox 360 Console
Xbox 360 hi! i accidentally plugged my xbox 360 into a 220 v plug and now it doesn't work. is there hope of ever fixing it? if so, how? thanks.
  • Nuclearbomb May 11, 2010
    did you plug it in in europe?
    Sergeant:
    Champion:
  • 427 Answers
It is probably fried. I would have it repaired by some who knows how to fix it.
Posted on May 22, 2008
I plugged my Xbox 360 into a 220 volt plug via transformer and the plugs short circuited now every time I try to turn on the Xbox the fuses in my house short circuit.
The whole AC port might have to be replaced. I know VideoGame911.com can repair that issue, and they also give you a warranty if you were to have the same problem when you get home! Hopefully it works out for you! =/
Mar 18, 2013 | Cars & Trucks
I plugged 110 volts xbox 360 into 220 volts outlet. and it's dead. what will i do?
Unless the item has internal fuse, it is burned up.
Look for product manual.
Many times, there is a glass fuse rated for unit voltage.
Replace fuse.
Each fuse has specific markings.
Oct 17, 2012 | Microsoft Xbox 360 with Kinect
My Microsoft Xbox 360 Pro's power brick wont turn
You can try to Reset the AC adapter by following steps below.
1. Unplug the xbox 360 AC adapter at both ends (from the back of the system and from the wall outlet or power strip).
2. After you've waited a full 2 minutes, plug the AC adapter back in on both ends and check to see if the power light comes on.
If this doesn't work it's probably fried from the power surge.
Jul 31, 2012 | Microsoft Xbox 360 Console
I have a red light on the fourth player spot
Remove all the cables (composite/component, power, you know, anything that plugs into the console) and let it sit for a minute or so. Plug everything back in. If it still doesn't work, remove the hard drive and attempt to start the xbox. If it works, the problem is with your hard drive. If it doesn't work, the problem is with the xbox itself. Regardless, you'll have to contact xbox customer support to fix either of these problems.
Aug 23, 2011 | Microsoft Xbox 360 Console
We are residing in Quezon City, Metro Manila, Philippines. My 11-year old son accidentally plugged in our x-box 360 with kinect to a 220watts power outlet. My wife bought our x-box 360 last month 4th of...
Usually warranties will only cover normal failure of a device. Since the damage was caused by user error (plugging it into the 220V outlet), you will most likely have to pay for the repair. If that is the case, it doesn't matter how long you have had the device, Microsoft will always repair them if you pay for it.
In other words, the warranty will cover manufacturer hardware errors while it is valid. It is Microsoft's way of saying that their device will work at least this long without problems or we will fix it.
Just call up Microsoft's XBox support line and ask them where to send it for repairs.
Good luck getting it fixed!
John Vickers
Aug 14, 2011 | Microsoft Xbox 360 Console
When my xbox is plugged in ether by components or av all i get is mode not surported???
If you are using one of the older models of the Xbox 360, not the one of the "Slim" versions, make sure that the switch at the base of the Component/AV cable where it plugs into the Xbox is on the right correct output. If this doesn't work it is most likely a problem with the TV settings. Try using it on a different TV and see if that works.
If this doesn't work give me some more information and I'll try to help you out.
Apr 30, 2011 | Microsoft Xbox 360 Console
I Accisentally plugged My 110 Volt xbox 360 into a 220 volt outle
The reason for this is the power overwhelmed the circuit boards and burnt them out you may need to talk to someone up the Game shops or go to support.microsoft.com and see what other people think. even if microsoft tell you to DONT send it in for repair as it gets rattled in the post and rattling the console causes the Open Tray Error an extremley annoying error. hope this helps
Apr 08, 2010 | Microsoft Xbox 360 Console
I Accidentally Plugged My Xbox 360 into a 220 v socket can i still fix my power supply
Ah that sounds dangerous. Well technically everything can be fixed, but it would be easier and probably cheaper to just buy a new one.
Jan 18, 2010 | Microsoft Xbox 360 Console
Wireless problems
Here in Denmark, lots of people are well tired of this router.
It often loose internet connection, but a hard-reset fix the problem most times.
Maybe you just have to unplug the power for a few seconds and then plug it back in, - wait for a minute or two until all the lights are on.
If this doesn’t work, please respond, and well find another solution.
/Teis
Dec 01, 2008 | NetGear WGR614 Router
Microsoft Xbox 360 Console Logo
46 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
