Question about Video Game Consoles & Games
My playstation 3 analog sticks are becoming more stiff and are sticking in every position except the centre, which causes major problems when trying to stay still in games.
  • 4 Answers
Yeah my controller started sticking up and not centering properly when released. I tried everything to clean it up but nothing worked untill I went to the local electronics store and got some contact cleaner with lubricating oil. (MG Chemicals - Nu-trol contact cleaner with special lubrication oils) Open the controller ( see youtube) the analog sticks cannot be taken apart but if you push the stick up you can squirt the base and work the cleaner/lube into the base. I squirted a bit on all 4 sides (left, right, up , down) working it in making a circular motion with the stick. Worked quite well and is the only thing so far that works at all. These seem to be sealed units (the sticks) with no way to open the business end to clean up the contacts. I put a toothpick under the tracing sheet to help with evaporation of the cleaner. Hope this helps.
Regards, Mike in Victoria
Posted on Dec 16, 2008
Analog problem
Do you mean it the analog stick turns left or it turns left in-game?
Jan 30, 2014 | Sony Dual Shock 3 Controller for...
Dont know how is become when playing soccer my player keeps moving forward without me even controlling
Your analog stick is dirty, where it sits on the motor peg and it's causing your stick to be read as moving instead of standing. clean controller.
Aug 13, 2013 | PlayStation Gioteck Ps3 Sc1 Wireless...
Analog Sticks Inverted on PC
Yeah, I don't use third-party controllers on my PC, just the Xbox controller. I'm sorry that you have this problem with other controllers.
Jan 16, 2013 | PDP Rock Candy Controller For Playstation...
Left analog stick drifting left
Hello Iwn666,
There could multiple things wrong, and hopefully nothing serious. Here is a complete list of some problems and solutions that can be wrong with the analog stick.
1. The Left analog stick may be sticky. If you eat greasy foods while playing your Xbox 360 console, try to avoid this from now on. Grease from food particles may slip into the analog stick, and make it sticky, causing the analog to move constantly to one fixed position. Please look at the next problem and solution ahead before attempting to remove your controller with a screwdriver. Here is a complete guide on how to access the inside of an Xbox controller.
http://www.ehow.com/how_5410334_fix-xbox-controller.html
2. There may be a simple glitch in configuration. Try turning off your Xbox 360 controller by holding the Xbox Guide button for approx 4 seconds untill a menu comes up. Select "Turn off controller". After doing so, try turning on your controller again. If the problem persists, there may be a greasy analog stick, or an object that broke that holds the analog stick together. Go back to problem/soltution #1.
Nov 12, 2011 | Microsoft Xbox 360 Controller
My analog move on it"s owne
This is usually the result of a loose screw on the back of the PSP behind the analog stick, or dust on the analog stick receiver itself. If it is an older PSP, you can try to open it up and clean the analog stick yourself (after tightening the two screws behind the analog stick, of course) but if your PSP is newer, I wouldn't recommend it, because any attempts to open the PSP will VOID YOUR WARRANTY (if you still have one).
BE CERTAIN YOUR PSP WARRANTY IS NO GOOD BEFORE YOU ATTEMPT TO TAKE IT APART YOURSELF AS YOU WILL VOID YOUR WARRANTY.
Open PSP 1000: http://www.ehow.com/how_6085376_open-psp-1000-repair.html Open PSP 2000: http://www.ehow.com/how_6548290_open-2000-psp.html
May 16, 2011 | Sony PlayStation Portable (PSP) Console
WHY IS MY ANALOG STICK DRIFTING EVEN IF I'M NOT USING IT?
it may be that it's stuck in a position try pushing it in to the centre and pushing down on it.
Dec 24, 2010 | Sony PlayStation Portable (PSP) Console
The analogue joystick isnt working properly. the character wanders off in wrong direction on its own.
simple, get a replacement joystick module and install it on your psp. i did a couple. the psp really isnt that intimidating to take apart. compared to an xbox 360 or playstation
Dec 01, 2010 | Sony PlayStation Portable (PSP) Slim...
Controller Problem
most probably the controller's carbon button inside the controller is already worn out and is sticking on the controller's printed circuit board (PCB) there are some replacement carbon button that can be bought for a cheap price
or
if you are using an analog controller, check if the analog stick is loose in feeling, this might affect the controls as well because good working analog sticks are a little stiff when pushed
Jun 30, 2008 | Sony PlayStation 2 (PS2) Console
Control stick eternally up!
use a flat object to pop off the pad, clean around it & replace it. if it still sticks turn it round.
Oct 04, 2007 | Sony PlayStation Portable (PSP) Console
ANALOG STICK intenrnally broke
You could try to dissasemble it carefully and see if it the stick has simply just become dislodged but it sounds more like something has broken inside the housing, Possibly just as easy to buy a replacement if you can be bothered to repair it, There not overly expensive nowdays.
Sep 21, 2007 | Sony PlayStation 2 (PS2) Console
Video Game Consoles & Games Logo
193 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
