Question about Sewing Machines
Juki DDL 227
just wanted to know what size range of needles the Juki DDL 227 is suitable to take, can it sew canvas? And is this machine a high speed machine? Where can I get all the information specs for this machine?
  • goldgem Oct 09, 2008
    Hi I was also wondering up to what size needles does it take ? Something bigger than a 16 for sewing canvas etc would be useful, but as I dont have a manual and have never used a machine before it is hard to find info on this. Also stich length does this pose a problem when sewing canvas as it only goes up to a 4 which is small. Thankyou
  • reddawnhrt May 11, 2010
    I have this machine, recently purchased, and I have run #'s 16 and 18 needles , and have sewn leather and vinyl. It will sew canvas well, but this machine has a short stitch length, so, if you want anything larger than a #4 stitch, this isn't the machine for you.
crappy_focus
  • 51 Answers
SOURCE: manual for Juki DDL 227
http://www.sewingmanuals.com/Sewing_Machine_Manuals/Juki_Industrial.htm
go to this website, your model is the 2nd on the list, it gives you the option to download, or get the CD version.
Hope that helps!
Posted on Feb 11, 2009
SOURCE: juki stuck needle
check settings
Posted on Apr 28, 2008
  • 13 Answers
SOURCE: juki ddl-227 industrial machine
Before all else. Turn off machine!
(1) break screws on the hook loose.
(2) tighten one back up very skightly, one you can reach when the needle bar is at its lowest position.
(3) lower needle bar to its lowest position.
(4) loosen the screw just tightened.
(5) position the tip of the hook behind the needle hole. the tip should be as close to the needle hole as possible without actually touching the needle
(6) tighten screws
(7) slowly hand turn the machine (depress the foot pedal to disengage clutch brake on motor) several revolutions to make sure the needle doesn't hit anything on the hook.
(8) if it passes this test, try on a scrap of fabric
Posted on Dec 15, 2008
  • 5 Answers
SOURCE: threading juki DDL-227 machine
There is a free download threading diagram for the DDL-227 here:
http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Juki_Sewing_machine_threading/Juki_552_553_555_227_Threading_Diagram.htm
Posted on Mar 23, 2009
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
Posted on Aug 20, 2009
Have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather have a Juki 8700 what type of needle do I need to sew leather? Also what kind of leather foot do I need?foot do I...
hi there
regarding your inquiry about JUKI machine model DDL-8700 , first your machine type was what ? DDL-8700/SS ( for light to medium material , DDL-8700/HS ( for jeans and can use to sew light to medium lather, type of needle is DBx1, size for lather was 18 and you can use thread number #30 and #20. one more thing you want to change your presser foot to teflon presser foot ( please see attached photo for that presser foot you want to buy.
if need more information please ask
thanks and best regards
ASHRAF ABOZID
CAIRO - EGYPT
aabozid@hotmail.com
Mar 07, 2015 | Juki DDL-8700
Juki DDL 227 top needle keeps breaking
Needle breaks
1.the needle is damaged
2.the needle is not correctly inserted
3.wrong size needle for the fabric
4.the wrong foot is attached
5.the needle clamp screw is loose
6. Top tension is too tight
7. Machine could be out of time
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Oct 08, 2012 | Juki Sewing Machines
What needle type is used for the juki ddl 555?
Regular sewing machine needles. Choose the needle type and size according to the type fabric or thread being used.
http://www.euronotions.com/pdf/Schmetz_Sales_Guide.pdf
Mar 18, 2010 | Juki DDL-8300
How to fix timing on a juki ddl-555 sewing machine
Hi, if your ddl-555 sewing machine the needle doesn't grab the string from the top and bottom; and it can't sew the fabric. Do you know what to do/
Sep 14, 2009 | Juki DDL-8300
Manual for Juki DDL 227
Hope that helps!
Feb 11, 2009 | Juki MO-644D Mechanical Sewing Machine
My thread is breaking when I'm sewing on my Juki DDL 555
MAKE SURE YOU HAVE THE RIGHT NEEDLE FOR THE THREAD YOU ARE USING, AND THAT THE SAME THREAD IS ALSO IN THE BOBBIN. CHECK UPPER TENSION, BY PULLING SLIGHTLY, IF IT'S TIGHT, LOOSEN THE UPPER TENSION.YOUR THREAD MAY BE THE WRONG SIZE OR TYPE FOR THE SPEED YOUR SEWING., and the needle your are using( sorry about the caps lock)
Oct 18, 2008 | Juki MO-644D Mechanical Sewing Machine
Sewing Machines Logo
917 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
