Question about Sony VPL-ES1 Multimedia Projector
Reset after using emergency close feature
Hi I have had a sony es1 come back from site needing a new bulb(apparantly) I installed new bulb and reset timer but no joy, lamp still not working. I have since found out that the projector lost power and used the emergency mode to retract tilt and close the cover.
is there a reset procedure as manual says contact sony after using this mode.
at the moment the projector powers up raises tilit etc and after about 30seconds lamp/cover led flashes once and then after another 30 seconds lights atays alight and projector switches off.
  • 3 more comments
  • jimmac123 May 20, 2008
    Hi They suggested I call a company called techworld based some where near me in Surrey. They Have not returned my call as of yet.
  • vesnakim May 26, 2008
    Is there a fuse inside ? My projector does not react at all, as igf there were no power supply.
  • jimmac123 May 26, 2008
    thanks
    I have sent it to a company for repair, If they are good and tell me what the problem was I will let you know.
  • vskrt Sep 23, 2008
    how to reset the lamp hours
  • Marnus Jacobs
    Marnus Jacobs May 11, 2010
    Hi there
    Have you tried calling Sony's support yet ?
  • 563 Answers
Hi jimmac123
Where exactly in the UK are you ? I'll try and locate another - more helpfull company.
Posted on May 26, 2008
I have a Sony VPL-ES1. After I had moved my beamer from the first to the second floor it won't power on. It's connected to the power well. I've had this problem before but I would like to know...
ensure that the projector goes through the cool down cycle, for example the fans stop running, before you unplug it. Unplugging it will cause it to into power failure mode which will not allow the lamp to turn on until the bulb reaches ambient temperature. it will also extend the life of that very expensive bulb. take the extra time to let it shut down before you unplug it.
Jul 02, 2011 | Sony VPL-ES1 Multimedia Projector
I have tried to download the driver for my Canon Selphy ES1 photo printer but nothing happens afterward the download finishes. I've lost the disc so can't use it!
You can download the drivers and manuals for your printer at the official Canon site
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=359&modelid=14226
Generally, you need to disconnect your printer before you install the driver, plug in the printer after installation. Things should work fine from there.
Let me know if you need additional help. Thanks.
Nov 12, 2009 | Canon SELPHY ES1 Thermal Printer
When the SONY VPL - ES1 projector is turned, the lamp cover opens , no light and after a while lamp cover closes. Mounted on the ceiling, it has happened after it was working well previously. Lamp has...
definately a lamp problem, for some reason the projector doesnt seem to accept or recognize the new lamp and switches to "safe mode". usually the projector turns off before the bulb explodes...
Jun 11, 2009 | Sony VPL-ES1 Multimedia Projector
I have a projector (SONY VPL-ES1) and the bulb stopped working. Took the bulb out, and not sure if it's blown or not. I checked online, to see if anyone else had similar problems, and sure enough they...
usually the projector powers and cools down. if you restart it it will open the cover, not projecting anything and after 10 seconds it will close again. this happens if the lamp is shortly before the end of the measured lifetime (no fixed hours) to protect the projector. usually if you take it out once or twice it will work for 1 or 2 more times but the bulb is very likely to explode (not destroying the projector but not good anyways)
Dec 30, 2008 | Sony VPL-ES1 Multimedia Projector
Missing additional new pacakage and games after master reset
U HAD DONE MASTER RESET OF THE MOBIL IN THIS CASE U HAD DELETE THE WHOLE NEW PROGRAM AND COME TO DEFAULT JUST GO TO SONY ERICSSON SITE AND DOWNLOAD THE APPLICATIONS IN FREE OF COST FROM RUSHAB
Nov 22, 2008 | Sony Ericsson W200i Cellular Phone
VPL ES 1 LAMP RESET
i have replace lamp but stlii no picture coming through
Sep 23, 2008 | Sony VPL-ES1 Multimedia Projector
Blue Bleed
Hi there
Does this only happen once a signal is inserted ?
Does it happen on both PC & Video signals ?
Have you tried using a different cable yet ?
Apr 16, 2008 | Sony SuperLite ultracompact Project...
SONY VPL-ES1 DATA PROJECTOR
I have same problem. There is light on power led. 2 hours of standby doesn't work..
Dec 11, 2007 | Sony VPL-ES1 Multimedia Projector
The projected picture is "weak"
I think some of the lamps only run to about 1000-1500 hours anyway, so it will be weak. I put a new one in thats only done about 200-300 and it still seems weak to me. I think this projector is just poor quality.
Oct 13, 2007 | Sony VPL-ES1 Multimedia Projector
I have fitted a new lamp but the projector is not coming on
Hi Try to locate the reset button if there is one and then reset it. This may reset the lamp time feature and allow the unit to power up. I hope you didn't touch the bulb? Also Make sure the bulb has been seated properly and the case is closed. Have a Great Day !!
Apr 28, 2007 | LG LP XG22 Multimedia Projector
Sony VPL-ES1 Multimedia Projector Logo
429 people viewed this question
Top Sony Office Equipment & Supplies Experts
shaun taylor
Jaime Hernandez
Are you a Sony Office Equipment and Supply Expert? Answer questions, earn points and help others
