Question about AppleWorks 6 for mac
Mail Merge won't print
I've been having this problem for almost three years now. Time to see if anyone knows a solution. One of my favorite features of AppleWorks is the easy-to-use Mail Merge. When I finally completely made the jump to OS X and converted AppleWorks 5 files to AppleWorks 6 I discovered any Mail Merge simply would not print. This happens with any document that attempts Merge with a database that was Saved As from AppleWorks 5 to 6.
Before I spend a month of my life regenerating these databases fresh in AppleWorks 6, might there be another solution? Heh, I don't even know if regenerating the databases will work. Thanks!
    Problem Solver:
  • 12 Answers
Try sending the file to a PDF or another printer.
Posted on Dec 30, 2009
  • 34 Answers
AppleWorks is a quirky and hopelessly outdated product. I am aware that a few people have an extreme fondness for it however.
It should only have taken minutes to import data, but don't do it in AppleWorks - they stopped making it years ago and it is unsupported and non-standard.
I have just taken two AppleWorks databases, - one older and one newer that needed to be combined. I exported them as tab delimited text and then imported them into Excel (You could use Apple Numbers - the modern equivalent to AppleWorks). Because the to db's had different headers, I imported them into two different Excel docs first and moved the columns around so the matched first, them copy each column over to the 'master' excel sheet.
You can either use the basic database tools in Excel, or once your data is combined and in this kind of data form, it is easy to import a .xls, or .csv into a new database program, such as Filemaker.
If you do copy over the data to Excel, any merge function - for label printing etc. has to be done in Word (or at least up to Word 2004). I was thrown by this until I realised you have to do this. Once a merge doc is set up with the right labels, it worked beautifully. Typical MS though it is a wholly unintuitive process.
Copy and importing data should be done with attention to care obviously. Make sure you have your original AW files backed up before you start.
Posted on Sep 12, 2009
Use mail merge in Word to print only envelopes?
Have you tried going to http://support.microsoft.com? Use this link which should call up some step-by-step demos on how to work with Word's mailmerge features.
Dec 20, 2014 | Microsoft Office Word 2007 Full Version...
How may I do a return address label--all 30 labels on 5160 Avery template without typing the address 30 times
Hi Jan,
You can use the option Mail Merge In Microsoft Word to print Return address.
If you are Using Windows 2003, Follow the link below
http://www.wikihow.com/Mail-Merge-in-Microsoft-Word
If you are using Windows 2012, You will find Mail Merge option under Mailing tab on top - Create Mail Merge option
Regards,
Sean
Apr 22, 2013 | HP Officejet 6310 All-In-One InkJet...
NEED TO KNOW HOW TO PRINT MORE THAN 1 ENVELOPE AT A TIME. DO LETTERS AND ENVELOPES ONCE A WEEK BUT THE PRINTER WOULD ONLY PROCESS 1 ENVELOPE AT A TIME AND I HAD TO DO THAT ONE MANUALLY.
Hi there !
For printing bulky letters or documents of the same format, I suggest you use the MS word mail merge document. You need to set up the mail merge document and the data of the file. For examples, the list of names, addresses telephone numbers and others should be input to the envelops.
Here's how to create mail merge document file.
1. Open a new blank MS word document or if you have a format already in a MS word format, just use it as default letter.
2. Go to menu bars (Home, Insert, Page Layout, References, Mailing, Review and View) and choose Mailing.
3. From Mailing, click on select recipients, choose use existing lists and find the excel document files that stores all the information like list of customers, company names, addresses, telephone numbers and others.
4. Open it and select table will appear and just click ok to merge it automatically to your default envelope.
5. Now you need to set up or format your envelope. from the Mailing menu, Insert Mail Merge Field will appear and click it to display the headings of your data source. Put the headings wherever you want.
6. After that, press preview result to display the datas. Save your work and it is finished
7
Jan 06, 2011 | Lexmark X 546dtn AllInOne Laser Printer
How do I print just one mailing label without running through an entire sheet time I print using an Epson LQ-590 and printing from the mail merge option in MS Word (MS XP)? In other words, when I print...
I assume you are using a sheet of labels, such as the typical 3 x 10 sheet. Word sets up the mail-merge document for printing the whole sheet, so if you print just one or two labels, you will `waste' the rest.
One way of using that sheet over is to create a mail merge that contains blank `dummy' addresses. It is rather involved and at best time consuming, and considered not worthwhile to save a partial sheet.
I service printers, and personally do not recommend that any label sheet be re-used. The printer curls the paper, in some cases fuses it, and causes the corners of the labels to be exposed, and possibly get caught in the printer (I have removed a lot of labels from inside printers)
Oct 18, 2010 | Office Equipment & Supplies
THe printer will not fold the merged leters
There is no Tri fold feature on this model!!
you can only do half fold in booklet mode if you have Sadlestich Finisher installed. Panasonic color models did not come with trifold feature.
I am a trained professional on Panasonic color copier
I can provide any help you need with this model
Apr 10, 2010 | Panasonic DP-C264 Copier
Word 2007 problems with mail merge labels
YES, you have conflict with other program installed. Reinstall will not solve the problem, great solution is upgrade your Microsoft Office from 2007 to 2010 and surely you can print all the document once it is change to new office 2010.
Nov 23, 2009 | Microsoft Office Professional 2007 Full...
I have several address stored in Excel. Now I
You don't need to print labels in Excel. You can use the mail merge feature in Word to do so. Use the Excel file as the data.
Nov 06, 2009 | Microsoft Excel for PC
Mail merge tri fold printing
Whats the weight of the paper? Try a lighter weight paper. Also, did it do it when you first got it? If No, it is called a limitation, it can't be done. If it did have your service tech come out and clean or replace the feed rollers or clutchs.
Feb 04, 2008 | Panasonic DP-C264 Copier
How to create mailing labels in Microsoft Works
With a Microsoft Works Word document open, select: Tools>Labels>(the list of available label types will pop up, select the label sheet you're using) then select: Tools>Mail Merge>Open Data Source...
Don't know how it could be simpler.
Dec 18, 2007 | Microsoft Works 8.0 for PC
EDITING RECIPIENT LIST IN MAIL MERGE
Where did you select your recipient's list from? Use Existing, Out Look Contacts, or type your own? Let me know.
Oct 02, 2007 | Microsoft Office Standard for PC
AppleWorks 6 for mac Logo
402 people viewed this question
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
